I have a new dell computer. Sometimes when I turn it on the desktop image has shrunk and is only covering about 4/5ths of the screen. Then if I turn it off it will sometimes return to full view on it's own. I am not changing any settings. Why is this happening? How can I adjust the settings so that the desktop image remains covering 100% of the screen?
    President:
  • 2,961 Answers
This could be the monitor, check for an auto set settings button on the monitor as the settings in windows would not have changed.
Posted on Sep 15, 2008
How do I get screen out of shrink size
Carol Taege,
Press control + to increase screen size. Control - to reduce the screen.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Mar 04, 2015 | Dell Computers & Internet
Dell 1905FP powers up but screen goes black after a few minutes
The monitors inverter seems to be failing. If you look up close, can you see a very faint image of the desktop?
You should think about getting a new monitor it might be cheaper than repairing.
Feb 14, 2014 | Dell UltraSharp 1905FP 19" LCD Monitor
My dell desktop asking for a password
If you want to create a new Basic Input/Output System (BIOS) password on a Dell Optiplex 745, reset the password. Resetting the password also applies if you want to remove an existing BIOS password. BIOS passwords are used to add an additional level of security to your machine. Without the correct BIOS password, your Dell Optiplex 745 will not complete the boot process. The password can be reset whether you know your current password or not.
Turn off your Dell Optiplex 745. Start the computer. Press "F2" the moment the Dell logo appears on the screen. You will only have two to three seconds to press the key. Enter your BIOS password. Navigate to the "Exit" screen. Select the "BIOS Password" setting. Enter your BIOS password and a new password if desired. Do not enter anything in the "New Password" box if you want to remove the BIOS password completely. Press "Enter" to save your password settings. Reset Forgotten Passwords Turn off your Dell Optiplex 745 and remove the power cord from the computer. Disconnect any external hardware and cables. Slide the release latch located on the back of your Optiplex 745. Lift the cover as you slide the latch. Hold the cover firmly and pivot it back on the hinges. Remove the cover from the hinges. Find the "PSWD" jumper on the motherboard. This is a two-pin jumper and should be clearly labeled. Use a flashlight and magnifying glass if you have trouble locating it. Remove the jumper from the motherboard. Replace the cover and slide it into place until the latch snaps into place. Reconnect the power cable and restart your computer. Shut down the computer after it has completely restarted. Disconnect all cables and remove the cover again. Replace the PSWD jumper. Replace the cover. Reconnect all cables and restart your computer.
b> Clearing forgotten passwords http://phubner.eng.ua.edu/Files/Optiplex 745/advfeat.htm - wp1117484
Mar 20, 2013 | Dell OPTIPLEX 745 PC Desktop
My font size has suddenly shrunk on my screen. Plus I am only getting a very small window available for computer games and am not able to scroll across from left to right. How can I get it back to full...
Right click on the desktop and select "Personalize" from the sub menu.
Personalization window will open up so select "Display" from the bottom left hand side.
From there you will be able resize the desktop icons to a resolution that your comfortable with.
Regards.
Jun 28, 2010 | Dell Inspiron 1545 Notebook
HELP! Laptop screen has shrunk... black border on screen.
Big Lebowski - this refers to an issue with a laptop.
No CRT on a laptop.
It is more likely a driver issue.
Go to dell.com, look for support, put in your service tag & update the graphics drivers.
Nov 16, 2009 | E-Machines eMachines Desktop PC
This D1025TM, horizontal distortion from active-off state
If it it part of a Win98 system that makes it well past its best, some20 years old.
Time for a new one.
Jun 24, 2017 | Dell 17" Monitor
How to remove the outside casing of a dell computer
  • The steps are:-----
  • Shut down computer.
  • Ensure that your computer and attached devices are turned off. If your computer and attached devices did not automatically turn off when you shut down your computer, turn them off now.
  • Disconnect any telephone or telecommunication lines from the computer.
  • NOTICE :---- To disconnect a network cable, first unplug the cable from your computer and then unplug it from the network wall jack.
  • Disconnect your computer and all attached devices from their electrical outlets, and then press the power button to ground the system board.
  • Lay your computer on its side with the computer cover facing up
  • If your computer cover has a cover latch, slide and hold the cover latch.
  • Grip the indents on the computer cover, and slide the computer cover toward the back of the computer.
  • Place the computer cover on a level surface.
  • An additional image:----
http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/rmvcvr4.jpg
Thank you. ( the image is in the above link ).
Sep 17, 2009 | Dell Dimension 3000 PC Desktop
My screen goes blank immediately after initial DELL startup image
You can either try to reset the BIOS, or have the restore cd fix it for you. By the way, what does the message say?
Nov 27, 2008 | Dell Dimension B110 PC Desktop
Computers & Internet Logo
David Payne
David Payne
