Question about Bosch 24 in. SGS45E02 / SGS45E08 Exxcel Free-standing Dishwasher
BOSCH SGS6302GB I took the front door cover off my dishwasher and 2 clearish plastic grommits fell out from the bottom (each side) of the door. I cant see how they fit back in. Can you help me?
  • Anonymous Mar 31, 2014
    The 2 piece front bottom part fell off and i can't figure out how to put it back on. (just under the opening door)
  • 39 Answers
Hi nikkij
It is simple to put them back on. the plastic pices fit on the bottom of the hinges. there is a cut out where they fit in. when you look at the door at the bottom you will see the hinges and the cut outs, the plastic pices fit in the cut outs flat side in. hope this helps
Posted on Sep 21, 2008
Over-level water error
The sensor is on the outside of the unit on the left side. slide the unit out of its location, taking care not to pull apart the fresh water hose, drain hose or electrical wiring, the sensor is on the left side, a small clearish plastic box with a rubber hose connected to the bottom, it's probably filled with crud which blocks the plastic float from moving up and down, the float covers and uncovers 2 small electric eyes, carefully remove the box and clean the crud out with an old toothbrush and it should work find, did for mine, good luck
ps, try not to soak the 2 small electrical pc boards on the sensor, if they do get wet, dry them well before reinstalling
Dec 18, 2013 | Samsung DMT300RFS Builtin Dishwasher
Whirlpool dishwasher door falls open fast when opening. plastic part came off, but don't know where it is from
remove the bottom access covers on the bottom of dishwasher. turn on the dishwasher with water valve in off position so you can here the motor running,while its on, find the breaker and turn off power.you will here motor stop. disconnect power wires from power box on right hand side,then disconnect water line open the dishwasher door and at the top remove screws holding dishwasher in place. pull dishwasher out from bottom.you may have to adjust bottom adjustable screw legs. pull it out and check sides where springs are for the door to open and close. it may have came loose.
Feb 27, 2013 | Whirlpool Gold GU2275XTV Builtin...
I have a Bosch dishwasher, model SHU9915UC/U11. The spring mechanism on the detergent door cracked, and I bought the part to replace it. I took the front cover off of the dishwasher to determine how to...
Hello! This is Guru...Saailer...I have your information...Due to size limitations I'll need your e-mail address in order to send it to you...Send an e-mail to me and I'll send an exploded view diagram and parts list...Guru...saailer...
Saailer@ec.rr.com
Jan 23, 2011 | Bosch SHU9915UC Dishwasher
Do you have any schematics to put the front plate back on
They go in the lower section of the door panel to prevent it from bowing and popping. If you look at how the insulation is cut you will see, I think they face sideways. You may also have an imprint on the sheetmetal of the door about 4" up from bottom if I recall
Sep 06, 2009 | Bosch SHU9950 Dishwasher
Shu9950 white plastic shims
Hello Folks.
Just spent the last 45 mins on my back under the SHU 9950's door, with a kettle of (cold!) water sitting just above the soap dispenser - the door will spring back up with the front removed. Basically there are three "components" to the shim: the flat side, the short comb side and the longer comb side. The way that worked for me was, with the door elevated about 20 degrees, I slotted in the top five flanges, having already placed the shim in the middle of the insulation cutout area on the door-front, flat side against the door, long comb closest to the door-front's side. You should push the short comb flush up against the insulation, so that the shim will be clear of the two door pieces when you fit them together. The shims seem to serve 2 purposes: preventing the door from torqueing as well as allowing the door to open perpendicular to the unit. Good luck!
Sep 19, 2008 | Bosch SHU9950 Dishwasher
Door seal replacement
This video will show you how to change a door seal on this Bosch classics 1200 WFL 2463GB/12 FD
Jul 24, 2008 | Washing Machines
Bosch SGVV53E03GB/55 cannot get panel door off
I have an SGV53E23 so don't know if this will help. My door is screwed but also held in place by 2 double sided sticky pads about half way down. They stick like the proverbial so try easing the door off one side at a time and look down to see if you can see any sticky pads. If so firm but gentle easing will get the baby off.
Jun 20, 2008 | Bosch 24 in. SGV53E03 Built-In Dishwasher
Door clips fell out
IF THE CLIPS ARE BLACK AND ABOUT 1 1/2 INCHES BY 2 1/2 INCHES THEY GO ONTO THE HINGES AND THE DOOR GOES OVER THE TOP OF THEM, YOU MAY NEED TO LIGHTLY FLEX THE SIDES OF THE PANEL TO GO OVER THE HINGES. THE TOP OF THE PANEL SHOULD SLIDE UP INTO THE CONSOLE BEFORE THE BOTTOM WILL GO IN. HOPE THIS HELPS YOU OUT
Feb 07, 2008 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Bosch 24 in. SGS45E02 / SGS45E08 Exxcel Free-standing Dishwasher Logo
292 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
