Question about Toshiba Computers & Internet
Toshiba Satelite M10 cooling system not working
Hi all,
I have a Toshiba Satelite M10 laptop. Keeps having a system warning "A problem with the cooling system has been detected. PLease turn off ur com and return it for service"
That's not all. It is getting slow and laggy and the CPU usage is constantly at 100% !!
Furthermore, the laptop shutdowns by itself once in a while. Not sure if it's becoz it is overheating.
Can any one help me please?!!
    Scholar:
  • 60 Answers
If you DO NOT hear the fan running, have it looked at by a professional. Your fan may have died. If you can hear the fan running, blow out the fan exhaust port in the opposite direction of normal air flow. Especially on lap tops, the heat sink cooling fins become completely clogged with dust. When this happens the processor overheats causing it to run slow and eventually shuts itself down to keep from going super nova. You should blow it out at least once or twice a year. Also, if you use your laptop on the couch or in bed, place it on a hard surface like a cutting board or something similar that will allow air to flow underneath the computer. This will also help prevent dust from the cushions or blankets and such from clogging the cooling fins on the heat sink faster than usual. Remember blow it out in the opposite direction of normal air flow. You want to blow the dust out the same passage it came in through.
Posted on Feb 21, 2009
  • 23 Answers
Chances are, one of your fans went out. Remember that you have 2 fans in there, one main fan and one cooling your processor. Once you find out which one it is, open 'er up and replace it w/ one that you can buy on ebay for around $20-$30.
Posted on May 14, 2009
Toshiba laptop l645 cooling system problem
  • You can try a can of liquiod air first and blow out the dust inside the fan and you can also add more cooling thermal paste to the heat sink above the CPU.
  • There is an youtube video that will show you this procedure if you are technical savy.
Jan 08, 2013 | Toshiba Satellite L645DS4037 Notebook PC
Toshiba Satallite Pro M10 PS630E-G206C-EN on a new HD, clean install of XP Pro but system drivers all missing and cant find the disc. Suggestions on a complete driver download location please? Cant get the...
As you have access to another machine (as you have posted here!), go to the Toshiba site, and find the drivers for your laptop.
(There are three M10 laptops showing, this is one of them: Driver for Toshiba Satellite Pro M10-S405, or you could choose from: THIS PAGE, where you can choose the exact model).
Download them to a USB stick, or write them to a DVD/CD and keep them safe in case you need them again in the future.
Hope this helps.
Jul 31, 2011 | Toshiba Satellite Pro M10 Notebook
Hi, I have a new Toshiba Satelite L500 laptop. From the moment I started to work with it, following message began to appear: Warning: A problem with the cooling system has been detected. Please turn off...
first you should install an independent system temperature monitor like speed fan and check if your computer temperature is ok .If the temp is ok then it is not as much of a worry but more of an annoyance if it shows the computer is hot take it back to service immediately either way they should fix the problem under warranty.
I hope this helps Andrew A
Apr 01, 2011 | Toshiba Satellite Laptop Cooler
Toshiba Satelite Pro M10 doesnt boot
dvd drive you can remove from the backsdie opening the cover but display problem is becoause of faulty ram and the battery .remove the battery and try to on and clean the ram and fix it.
Jan 20, 2010 | Toshiba Satellite Pro M10 Notebook
Toshiba Satellite Pro M10 - system cooling
Unfortunatly, it is time to replace the cooling fan. It is fairly easy to replace if you know your way around the pc. If not, a tech should be able to replace it in about 1 hour.
Good Luck
C2Solutions
Aug 19, 2009 | Computers & Internet
What is the compatible ram for my toshiba satelite pro m10?
go to tigerdirect.com...find 1-800 number call them they will know what u r looking for
Jul 18, 2009 | Toshiba Satellite Pro M10 Notebook
I have a Toshiba Satelite Laptop with a bad cooling fan
Contact Toshiba Parts  here http://www.tacp.toshiba.com/customersupport/parts_accessories.asp
Feb 16, 2009 | Toshiba (K000016310) Cooling Fan
Toshiba cooling system
If u have a laptop (that's what i found out that toshiba Qosmio is ) then is no problem that the fans stop (as long as the temp. is within the normal working margins ). U might have a setting problem - a bad software, managing the cooling system; - a bad BIOS setting regarding system temperature protection; - or the temperature detectors malfunctions, and must be changed (if possible)
Jan 14, 2008 | Toshiba (K000016310) Cooling Fan
Computers & Internet Logo
1,381 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
