Question about Zebra Printer 140-751-00000
Label problems on a Zebra 220XiIIIplus
I am having an issue with this Zebra printer only printing half of a lable. I have chaged the label top from one extreme to the other and I don't see any other parameters that would affect this. I am using sentinel s5 to compile info from codesoft and a text file I used for variable information. Thanks in advance for any help in this matter.
MattCapi
  • 155 Answers
Check the parameters of length and width of printing in the printer, if you are right, then the program or its driver has a print area smaller.
Posted on Mar 10, 2009
Can't get the Zebra S4m printer to align? How should I trouble shoot this? Sonya
I am assuming you mean misalignment of lable top or start of print moving on label.
check sensor for lable debris.
if OK then perform media calibration:
Enter menu and scroll to ADVANCED
press enter and use password 9999
scroll to MEDIA and RIBBON CALIBRATE
Remove a few labels and remove ribbon
Press right arrow to continue display CALIBRATING PLEASE WAIT.
When complete reload ribbon and labels press right arrow printer will feed approx 39"
printer should now print OK.
Aug 08, 2011 | Zebra S4M Thermal Label Printer
Half of the labels information is printing
I'm assuming you mean half is showing up as you go across the label. If that is the case and it's a very clear line where the print is cut off, then check the print width setting through the front panel of the printer. Press SETUP and look for setting called MAX WIDTH. It should be set to 104MM (4") which is the width of the print head. It is set to something smaller if the print is being cutoff.
If the print is fading away as you go across then that it is a print head balance issue. Look at the print head pressure dials on top of the print head assembly to make sure they are set evenly.
Hope that helps !
Apr 14, 2010 | Zebra Z4Mplus Label Printer
Zebra 105SL print only half of label
This can happen if your page size in your driver is not set to the actual label size. It can happen if you have old .dll driver files mixed with your mew driver installation.
This is what I would do:
Uninstall the driver completely - delete the icon in Printers and Faxes. Drop down the file menu there and choose server properties and remove the driver for all Zebra printers from the Drivers tab. Go into the LCD menu of the printer and load defaults. Go back into the LCD meny and look at the page width setting. Your printer has 300 dots per inch, so a 4 inch label would be 1200 dots wide.
Another thing to consider is that you may be trying to printer to a 300 dpi printer from a 203 dpi driver. Make sure that you choose 300dpi when you reinstall. This should work.... If not, repost with more details about your application and driver. I can assure you that this is not a printer problem unless half of your printhead has failed.... unlikely, but possible....
Jan 16, 2010 | Zebra 105Se Thermal Printer
Losing half of top line when printing
Label definition in printer driver may need adjustment. Try calibrating printer, printer on solid green light, hold down feed key & release after light blinks 4 times, (blinks once, twice, three times then 4 times) Download the Zebra setup utility and use it to configure printer.
Sep 29, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Only printing 1/2 a label
recalibrate the printer in the set up.
Don't just do a quick cal from the front panel.
Make sure your driver is the correct dpi zebra driver, either zebra or my preferred seagull scientific.
by .5 of the label, do you mean width or heigth.
If it is heigth, check to make sure you are set for top of print correctly. Also you will have to back feed for a label that short.
Feb 24, 2009 | Zebra 110Xi III Plus Thermal Printer
PRINT WILL NOT STAY ALIGNED ON EACH LABEL-RUNS ONTO NEXT LABEL
Check the tension on the Ribbon Take-up Spindle there is a nut on it that sometimes can loosen or tighten its self and will throw off the lables. Its a nut that has a of couple Hex nuts on the corner, screw the nut to about the 3rd thread from the top of the bolt facing you then tighten the hex nuts on the corners of the nut. Then try printing the labels make sure the media guide also is set to the lable size that is installed.
Dec 19, 2008 | Zebra 105SL Thermal Label Printer
Zebra 170PAX3 not printing the top half of label
If you print a power on test label, see if the print is aligned, id so, use the top of form setttings to get all the print on the label.
As far as a USB, the printer will only take RS232-422,485, and parallel, and you can add the factory Nic card or use an external print server.
Dec 08, 2008 | Zebra 170XiIIIPlus Thermal Label Printer
Prints half of label
Restart your computer. Turn your printer off and back on again. Restart your software for printing lables. When updating the printer drivers, all software needs to be restarted to make sure that the form controls are working properly.
Oct 06, 2008 | Zebra Eltron LP 2824 Thermal Printer
Printing mixup
Your problem is a computer configuration issue, not a printer problem.
Without knowing any details of your system configuration, it is impossible to offer and further advice.
Steve W
LazerTek, LLC
Jul 02, 2008 | Zebra 140XiIII Plus Thermal Label Printer
Z4m small labels
try the pause test if print ok in some and have problems with other lables, is possible the belt.
Apr 08, 2008 | Zebra Z4Mplus Label Printer
Zebra Printer 140-751-00000 Logo
169 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
