Question about Goldstar DH504EL Dehumidifier
GoldStar DH504EL Dehumidifier
Can I convert the unit to only use the drain hose instead of the bucket, so I don't have to empty the bucket? It would be great if the unit kept running and kept emptying via the attached hose eliminating the need for the bucket.
  • ezappia Sep 15, 2008
    MNTech - thanks for getting back to me. It does have a tube (onto which I attached a small piece of garden hose) and I'm using it. But every day the bucket is still full and the unit shuts off. If I take out the bucket the unit shuts off automatically...if I put the bucket in the bucket fills up instead of expelling the water out of the tube...so how do I bypass the bucket so only the tube is being used? Is it possible to take the bucket out and still make the unit run (utilizing the tube for expelling the water)?
  • 1,543 Answers
Your dehumidifier should have come with a tube which would allow you to do this very easily. I beleive the part number is 5214A20027B.
Posted on Sep 15, 2008
  • Carl Schulzetenberg
    Carl Schulzetenberg Sep 15, 2008
    Your original post was very incomplete. You did not state that you had the tube, or that the bucket was still filling. You did not state how you attached your drain hose to the unit. The tube passes through the dehumidifier from the back, by the cord wind up pegs, to the front where it collects the condensate before it can enter the bucket. If it is hooked up properly and you are filling the bucket you have an obstructed drain hose. (kinked?) Please don't rate me as a "thanks for trying" when you have withheld information pivotal to the diagnosis.
My dh504el dehumidfier shuts off and say the bucket is full however the unit is set up to flow out a pipe
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Feb 24, 2011 | Goldstar DH504EL Dehumidifier
The drain hose stopped working on my Whirlpool gold dehumidifier. Now the bucket fills and the machine shuts off. Tried cleaning the filter and clearing the hose. Still the same problem. But the hose...
I had the same problem....raised the unit 3 feet off floor, the drain hose is 4feet long... But the secret to getting unit to drain into hose if unit is set to Continous is...... TILT the unit back about 5 degrees with a half inch piece of wood under front wheels and She will drain into hose instead of bucket.... IF this don't work , I will eat the bucket.........goldiejud@netscape.net
Dec 06, 2010 | Whirlpool AD50USS Dehumidifier
Bucket is empty, fan comes on to start up runs for about 2 seconds and shuts system right back off
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Aug 26, 2010 | Goldstar DH504EL Dehumidifier
I have a Goldstar Dehumidifier DH504ELY7 that doesn't pull moisture out of the room. the fan runs and I think I hear the compressor come on but the air coming out the back is cold and the bucket doesn't...
heatman101
Jun 11, 2010 | Goldstar DH504EL Dehumidifier
Unit just won't work anymore .
I have a model dh404e with the same problem.I was told it is the main control board inside the unit(not dislpay board) but a new board costs around $60.
Feb 20, 2010 | Goldstar DH504EL Dehumidifier
I have a Goldstar GHD30 dehumidifier. I have not used it in awhile. I plugged it in to run it today and it does not turn on. I cleaned the screen and tried different outlets, nothing works. HELP!
Check the condensate collection bucket. If the bucket is not inserted correctly the dehumidifier might think the bucket is full and thus not turn on.
Aug 30, 2008 | Goldstar DH504EL Dehumidifier
Goldstar dehumidifier
The hose connector does not drain the bucket, it drains the condensate before it enters the bucket. Tube passes through back of dehumidifier by the cord wrap area. (you may have to remove a small cover)
Aug 25, 2008 | Goldstar DH504EL Dehumidifier
hey i just got paid by some guy to haul away a broken fan(currently fixing) DH504ELY5 dehumidifier on my model with bucket removed front facing you reach to the far right the orfice there drains to the bucket id only assume just get the proper od hose(even clear) from a hardware store attach it and it should be fine- take back panel off(plastic 6 screws and youll have to gently pry the "clips" out of the steel back-dont worry if one breaks the screws will still keep the back on on reassembly) there is a hole with a foam kinda adhesive tape over it it is perforated for the purpose of an external hose feed it through there and out of the hole thats in the middle of where the power cord winds up for storage-all will be a straight shot on reassembly no twists or turns try that should do the trick and you can keep the bucket on there:)
Aug 02, 2008 | Goldstar DH504EL Dehumidifier
Dehumifier problem
Have you checked to see that fill bucket has been placed back in correct position/orientation?
Mar 06, 2008 | Goldstar DH504EL Dehumidifier
Goldstar DH504el
Check the float switch is not stuck.
Sep 21, 2007 | Goldstar DH504EL Dehumidifier
Goldstar DH504EL Dehumidifier Logo
389 people viewed this question
Top Goldstar Dehumidifiers Experts
Gil Shultz
Michael Youngman
Michael Youngman
Jerry Greenberg
Jerry Greenberg
Are you a Goldstar Dehumidifier Expert? Answer questions, earn points and help others
