Question about Epson Stylus C42UX InkJet Printer
Plastic piece came loose inside printer
A plastic piece came loose inside my Epson C42UX. I was able to get it back together once before and get it working but now I can't remember if the piece had a spring attached to it or what. As you face the front of the printer the problem is on the right hand side in the area where the clear plastic ink tube attaches. There is another plastic piece that is attached with a spring in the back portion of the area. However, I can't seem to get this other plastic piece to fit. I can't remember whether it requires a spring or not. It appears to attach in the front portion of the area I'm referring to. Help.
  • 4 more comments
  • Bzh29 Oct 19, 2008
    seems I got the same issue
    did you fix yours?
    Rgds
  • james fenton Feb 02, 2009
    I have The same problem don't know how to refit part and spring. a picture of the inside would be really helpful.
    I Have the same problem can't figure out how to put the part and spring back into the printer. a picture of the inside a good c42 would help.cheers
  • bi_chan Feb 11, 2009
    I have the same problem with my epson stylus c42 .. but the printer head is stuck in the parking mechanism .. how can I get it out ?
  • Anonymous Mar 27, 2014
    we got the stapler open and there is loose pieces inside a plastic piece and a spring. Is there a diagram so we can see where these pieces belong?
    we got the stapler apart there were loose pieces inside a plastic piece and a spring. Can we get a diagram of the parts so we can see where they go.
  • 353 Answers
The parking mechanism front spring has a tendency to come off in the C4x family of printers. Re-attaching it is a fiddly task not covered in the service manual. The pictures show: a general shot of the parking mechanism from the front; a shot of the actuation lever, illustrating where the front spring attaches to it; a view into the empty parking mechanism compartment showing where the lug is to which the bottom end of the front sprint attaches; a suggested tool for re-attaching the front spring, made from a large paper clip.
Proceed as follows, using a torch where necessary: lift the parking mechanism out its holder; be careful not to detach the drain pipe. Using the tool, attach one end ofPlastic piece came loose inside printer - 50f32be.gif54a980Plastic piece came loose inside printer - 88c5669.gifs=88c5669.gif9145528.gif the spring to the lug at the bottom of the parking mechanism compartment. Remove the tool and leave the spring laying at the bottom with one end attached to the lug. Replace the parking mechanism in its holder, with the actuation lever in place. Now for the fiddly bit! Peer into the compartment to locate the free end of the spring and get the tool on it. Pull the spring until you can put the free end over the lug on the actuation lever. Remove the tool.
Posted on Feb 10, 2009
I need to rewind the spring and starter pull cord. I need to understand how all the parts fit together
I had the same problem. I had to take it apart and rewind it manually. To do this:
Step 1:
There are 4-bolts to remove on the orange plastic section the screw into the motor housing (one of them is hidden inside the orange plastic housing, you'll see an opening for it). There are also 3 screws in the black plastic exhaust housing that screw into the orange plastic housing, find those and remove.
Step 2:
Carefully remove the engine from the plastic housing. I didn't disconnect the throttle cable or the electric wires (points) just kind of worked around them.
Step 3:
The mechanism is kind of crappy. There are two black pieces with a spring in the middle, and a metal disc on the bottom with a ribbon coil on the underside of it. The top plastic piece is what turns the flywheel when you pull the cord. The spring in between connects the two plastic piece. This is probably what popped out. There is a piece sticking up on one end, which inserts into the hole in the top black plastic piece. If you remove the little guardrail things you can probably remove just that piece. KEEP TENSIONS ON THE PULL CORD. Once you remove that top black piece, it should start to recoil.
Step 4:
If it did recoil, put the spring back in the top plastic piece, and then put the plastic/spring combo back into the the bottom plastic piece, there is a little groove for the bottom of the spring to slide into. Then put the little guardrail screws back on. Make sure the big metal wire thing hasn't slipped down into the shaft of the weed whacker. That needs to go back into the motor, as it is what gets spun and in turn spins the strings. As you start to put the motor back in, you may have to pull on the pull cord a few times to get the flywheel and plastic piece to line up. Once you hear the motor start to catch, then you should be able to wiggle it back into place and put back all of the screws. Then give it a shot. If it pulls out again, you may have to drill a new hole into the top black plastic piece for that spring to slide into (this is the crappy design part).
Step 5:
If the pull cord didn't retract, you need to remove the other two pieces (lower black plastic piece and metal disc with ribbon). The metal ribbon has a nub on the outside that hooks onto a plastic piece in the bottom of the orange plastic housing. You'll need to wind it around once or twice to "charge" the ribbon, then wind the string back on the black plastic piece. The black piece should slide into the center of the metal disc and catch the inside of the ribbon. Once you get these two together, again, make sure the metal ribbon piece is wound once past normal and then you have to slide both parts together down into the housing catching the metal ribbon loop over the orange plastic nub. It's tricky, it took me a few tries. Once you get that you can try and test the pull cord, you'll see it pull out and feel it retract due to that metal ribbon. Then go back and do step 4, where you put the upper black plastic piece with spring back into place and replace the little metal guardrails.
This whole thing took a few tries, and the pull cord still gets stuck out. It's a major pain to say the least, but after the 5th time fixing it, you'll be a real pro.
Aug 16, 2009 | Homelite Mighty Lite Lawn Trimmer
HP Laserjet M3035xs ADF Assembly?
The blue plastic piece is the clip that holds it all together. Facing the front of the printer. Open the top cover of the ADF. Flip the assembly with the green and blue plastic to the left. Hold the the squarish looking plastic frame in your hand so that you can see the black gears, with those to the back of the printer and the shiny silver shaft with the roller on it to the right. Now locate the notch on the piece you flipped back that has the blue plastic clips sticking into it. The silver shaft snaps in there. It does not feel right, but if it does not fall out when you close the adf door, you've got it. If there are other pieces loose, perhaps I can get you a few pictures from the one we have in the shop right now.
Apr 02, 2009 | HP LaserJet M3035xs MFP All-In-One Printer
I need to know how to open my EPSON printer
You could have a bad ink cartridge, remove it and look close to see if you fix it.
or if the printer dropped or bumped hard, there could be a plastic tab/cartridge that can glued..
Mar 18, 2009 | Epson Stylus C42UX InkJet Printer
My epson stylus C42UX printer cartridge is getting stuck
It sounds like the print head is jamming on the parking mechanism (usually because the actuation lever is stuck in the up position). Turn the printer on, and as soon as the print head moves, pull the power cord out of the back, or switch it off at the mains. You should now be able to move the print head over to the left by hand out of the way. Now look in the "parking bay" at the right hand end where the print head parks itself and see if there is a plastic arm sticking up. If there is, gently pull it towards you and it should spring down. Now turn the printer back on and it should operate normally. If it happens again, repeat the process a few times to see if it clears the problem. Otherwise it means the parking mechanism is gummed up with dried ink and needs a good clean (see below), or some other mechanism fault.
If you see that the whole parking mechanism itself has moved up to block the way, this means a spring has come off. To get this back on again requires the printer to be dismantled - as does the cleaning job above! If you want to have a go at doing this yourself, please report back for help on this.
If neither of these apply, please report back for further help.
Nov 24, 2008 | Epson Stylus C42UX InkJet Printer
EPSON STYLUS C42UX PRINTER.
You say you have downloaded the SSL utility. Install it and right click the ssc icon in the system tray (bottom right corner of the screen). Select reset protection counter. This will restore your printer to a working condition.
Oct 05, 2008 | Epson Stylus C42+ InkJet Printer
Epson C 44 ink jet printer loose white L shape plastic part.
ONE OF THE ARTICLES IN, www.fixya.com/support/t262916-printer_carriage ,GAVE US SOME GOOD INFORMATION. IT REFERS TO A PAGE IN A PARTS MANUAL THAT WAS IN PDF FORM, WHICH WE HAD TROUBLE DOWN LOADING. WITH THE DOWN LOADING OF AN UP DATED ADOBE, WE MANAGED TO VIEW IT. THE ASSEMBLY THAT THE WHITE PLASTIC L SHAPED PIECE WAS MOUNTED TO WAS HANGING DOWN, AND HAD COME LOOSE. THE PLASTIC L PART GOES ON ONE OF THE SHAFTS ON THE LITTLE WHITE PLASTIC CARRIER, THAT MOUNTS INTO THE SLOTS. NOTE THEIR IS A SMALL SPRING THAT IS ON ONE SIDE AND IT ATTACHS TO ONE OF THE SHAFTS ON THAT SIDE OF THE WHITE PLASTIC CARRIER. PUT IT BACK TO GETHER IF THE PARTS AREN'T BROKEN AND THE PRINTER SHOULD WORK. I FEEL IT WAS THE SPRING COMING OFF OF THAT SHAFT THAT ALLOWED IT TO COME LOOSE, AND SHUT THINGS DOWN. GOOD LUCK
Jul 27, 2008 | Epson Office Equipment & Supplies
C42UX problem
An unknown printer error has occurred. Turn the printer off, disconnect the interface cable and turn the printer back on. If error disappears, turn the printer off, reconnect the interface cable and turn the printer back on. If error continues then printer needs service. If printer returns to normal the issue is resolved.
Jun 09, 2008 | Epson Stylus C42UX InkJet Printer
Cabling problem??
perhaps that the cable isn't put in the way it should , but it could also well be that you need a chip resetter for epson cartridges to let it recognize the cartridges correctly
Apr 30, 2008 | Epson Stylus C42UX InkJet Printer
Printer cartridges
Hi:
I solved this problem; there was a white plastic "piece" stuck upwards and all I did was push it back down. Now the cartridges are able to go all the way to the right and the printer is working properly. Looks like I need to replace the cartridges now, that's all.
Thanks.
Lori
Feb 18, 2008 | Epson Stylus C42UX InkJet Printer
I have had the same problem, my solution was taking a hammer to the stupid thing and buying a lexmark!
Dec 10, 2007 | Epson Stylus C42UX InkJet Printer
Epson Stylus C42UX InkJet Printer Logo
195 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
