Question about Dryers
Maytag dryer model MDE9420AYW
How does the flange on the idler pulley face, towards the front or back of the dryer.
2 Suggested Answers
rickzilla
  • 706 Answers
SOURCE: how to install the belt on a Maytag Dryer modek MDE9420AYW
This should give you a few ideas on how it works.. Hope this helps...
Posted on Sep 13, 2008
Replace belt whirlpool dryer WED7500VW
remove the front panel on the dryer, get the old belt and take it and the model number into your local shop to get the proper belt, put the new belt around the drum with the groves towards the drum, replace the front panel. on the lower part section of the dryer on the back there will be a panel you remove it see the motor, reach in and place the belt around the pulley on the motor then carefully force the tension idler down towards the floor till you can place the lower section of the belt into the pulley on the tension idler and release the idler. you can now run the dryer, as the drum turns the belt will place itself. hope this helps.
Oct 16, 2016 | Whirlpool Dryers
What is the belt diagram from the deck to the motor for a mower?
1st, Unplug the Dryer from the Power Supply.
You will need the Exact recommended Replacement "Idler Pulley".
With the Belt Ribs Facing Toward the Dryer Drum, position the belt on the tell tale Ring Mark on the Drum letting the Belt Hang Down below the Drum.
Place The New Idler Pulley into the Slots on the Inside Dryer Bottom located near the Motor Mounted Pulley.
(Face The Idler Pulley Toward The Motor Mounted Pulley)
(Hold the Idler Pulley in place in the slots)
Take the "Hanging Belt" & run the Whole Loop "UNDER" the Idler Pulley & then
Attach the "Belt Loop" "AROUND" The Motor Mounted Pulley.
That should do it.
Put the rest of the Dryer Back Together...Done!
Good Luck,
Vinnie
Sep 20, 2014 | Dryers
Replace seal around tumbler
unplug the dryer, pull out from the wall 6 inches, remove the screws at the lint filter, use putty knife to pop the clips at the seam between the top and front(one on left front and one on right front and an inch or two in) , remove the 1/4 inch hex head screw one on left , one on right, tip front forward, unplug the door switch, remember where the wires went, lift the front panel off. Remove belt by reaching under drum and grasp the idler pulley and pull it to the right and slip the belt off the motor pulley, use belt to lift the drum and pull out from cabinet. Remove old felt. do not get adhesive on you it is hell to get off. Use disposable gloves if possible. put glue around the tub, install the new felt, the fold face toward the back so that you can see the stitching. Allow 15 minutes for the adhesive to set up. Reinstall the drum, make sure the ridge of the drum is seated to the rollers in the back, put belt on the line where it has been riding and run hands around the belt making sure it is not twisted and the ribs are facing the drum. install the idler pulley in to the slot in front of the motor, pull belt through the idler pulley, pulley idler pulley to the right and re install the belt to the motor pulley. Re install the front of the dryer by inserting the clips on the inside of front in to the square holes on the cabinet front edge, re install wires for the door switch, the ones you remember where they went, put the screws back in to hold front panel, snap the top back down, put the screws back in at the lint filter area, Done! Wait about an hour before you run it to allow the adhesive to fully cure. These instructions are for most Whirlpool, kenmores made by whirlpool, roper, and kirkwood dryers. If this is not what you have contact me. Good luck.
Feb 04, 2014 | Kenmore Dryers
Replace a belt on indesit dryer
Hello.
Tools needed to solve the problem
(A)Standard screwdriver,New belt
1 Unplug your dryer to disconnect power to the unit.
2 Remove the screws that hold the dryer top in place using a standard screwdriver. The screws are located along the top and sides of the dryer. With older models -- 1996 and older -- the entire top comes off the dryer. For new models, the timer and console stay in place while the rest of the top comes off.
3 Remove the screws that hold the front panel and door in place using a standard screwdriver. The screws are just inside the door at the top front left and right sides of the dryer. The front panel on older models will move to the right side and on newer models the door will move to the left.
4 Remove the existing belt by pulling the idler pulley to the right. This will take the tension off the belt and allow you to pull it away from the motor pulley.
5 Install the new dryer belt by wrapping it around the top of the drum and allowing it to fall around the circumference of the drum. The grooves of the new belt should face down toward the drum. Rotate the belt around the drum to ensure there are no twists in it.
6 Connect the new belt to the motor pulley. On newer models you can access the motor pulley on the front underneath side of the dryer. Pull the idler pulley to the right and loop the belt around it. On older models you can access the motor pulley through an access panel on the back of the dryer. Pull the dryer away from the wall and remove the access panel using a standard screwdriver. Repeat the same steps as on a newer dryer to install the belt around the motor and idler pulleys.
7 Replace the front panel of the dryer and the screws that hold it in place.
8 Replace the top of the dryer and the screws that hold it in place.
9 Plug the dryer in and make sure the belt works properly before trying to use the unit.
Thanks.
Nov 07, 2011 | Indesit W 123 Front Load Washer
How do I replace the heating element in Maytag Dryer SDE2606AYW Serial# 12508837EN
1.Unplug the Maytag dryer from the dryer electrical outlet and pull the dryer away from the back wall.Use a putty knife to press in the locking clip between the front and top panels.While pressing the clip in with the putty knife,lift the top panel up to unlock it from the clip.Raise the top panel into the service position allowing it to rest on the back hinges.
2.Locate the door switch connection on the inside front right corner of the Maytag dryer.Press the locking tabs in with your fingers and pull the wiring harness away from the door
switch.With a Phillips-head screwdriver,remove the screw on both inside corners that secure the front panel to the sides. Lift the front panel up and away from the dryer.
3.Use a Phillips-head screwdriver to remove the four retaining screws that secure the drum bulkhead to the front of the side panels. Remove the bulkhead from the dryer.Reach under the drum and pull the idler pulley to the left to release the belt tension.Remove the belt from the motor and idler pulley. Lift the drum up and out of the dryer unit bringing the belt with it.
4.Remove the two screws that secure the heating element to the rear bulkhead with a Phillips-head screwdriver.Disconnect the heating element terminal wires by grabbing them with needle-nose pliers at the wire leads and pulling them off of the terminals.
5.Place the new Maytag dryer heating element into the dryer and slip the wire leads over the terminals.Secure the heating element to the rear bulkhead with the retaining screws.Lift the drum and belt and place the drum back inside the dryer cabinet.Route the belt around the motor and idler pulley.Shift the idler pulley back to the right to apply belt tension.
6.Reattach the front bulkhead to the dryer using the four retaining screws.Position the front panel into place and secure it to the sides with the retaining screws.
7.Bring the top panel back down and push the front corners in to engage the locking clips.Push the Maytag dryer back into its working position and plug the power cord back into the dryer electrical outlet.
Aug 28, 2010 | Maytag SDE2606 Electric Dryer
Maytag neptune dryer makes a loud squeaking noise
This noise will normally come from a defective idler pulley. Access to the idler pulley varies by model, if your dryer has a lower front panel (kick plate) start there. It should lift up and off or it may be held in place with a few screws or snaps; it may also have a catch at the edges or center gap between the kick panel and main panel. To release the catch, push a putty knife, wrapped with masking tape, into the gap and push back the catch. The next easiest access point is the rear panel. The rear access panel is held in place with several screws along the outer edges. The last resort method of access is the removal of the entire front panel. The front panel supports the front of the drum and so removal is more difficult. Front panel removal varies. In general, access is gained by lifting the top (remove the lint trap screws first), removing the screws that secure the front panel, and detaching the panel from the drum.
When reaching into the dryer be careful of sharp edges on the cabinet and interior supports. Reach in to the belt and give it tug. It should be taught and have only a little give. The belt should go under the idler pulley and over the motor pulley. Lift the idler pulley toward the motor to relieve tension on the belt and remove it from the motor pulley.
Turn the idler pulley wheel, it should turn smoothly, quietly and without any wobble. Inspect it for cracks or uneven wear. If the idler pulley does not maintain proper tension or is damaged it should be replaced. Depending upon your model, the entire assembly or just the wheel or bearing may be replaced. Check the bearings as well for excessive clearance also(roller bearings)
Sep 29, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag dryer mde308dayw, grinding noise, the rollers at the back of the dryer still have an inch of rubber on them, the sound appears to be coming from the bottom of the dryer, near the pulley, your...
A few things to check. Have you pulled drum, something could be caught between drum and body of dryer in the felt seal area. Or bearings in rollers could be worn. Also check belt tensioner way be worn. Thats all there is to a dryer has to be one of these.
Sep 20, 2009 | Maytag MDE308DAYW Electric Dryer
Whirlpool #ler5636ez2 need diagram for belt instalatiion
Unplug the dryer...
  • Remove the lint trap and the 2 screws holding the vent to the top panel (be careful not to drop them down the vent!).
  • Reach around the back and pull the top panel toward you. Insert a putty knife from the front on each side to release the top panel clips. Lift and flip the top panel back.
  • From the inside, remove the 2 screws holding the front panel to the cabinet. Lift the front panel straight up off the front panel clips (hooks) and swing it aside.
  • You should now have access to the belt.This diagram shows you how to loop the belt through the idler pulley.
To replace the belt...
  • Place the belt (grooves inward) around the drum.The idler pulley fits into the slots on the bottom of the cabinet (in front of the motor) with the wheel or glide facing the left side. Pull the belt through the middle of the idler pulley from the left side and loop it around the motor pulley.
To reassemble, follow steps in reverse.
Let me know if you need more assistance.
Mar 29, 2009 | Whirlpool LER5636P Electric Dryer
Which wa does the belt on a Maytag Atlantis dryer run around the motor and idler pulley. I have the belt groove side down, which is the way it goes in the Atlantis, but I couldn't find a schematic for the...
Hi you're correct in putting it groove side down. Now make a loop, like when you first started tying your shoes with the slack around the drum. Push the entire loop just beneath the idler pulley through the metal channel and apply pressure to the idler pulley assembly. pushing it towards the motor pulley until you can get the loop you are holding over the motor pulley and Waa Laa you've installed your new belt. Good Luck!
Dec 10, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
How to install the belt on a Maytag Dryer modek MDE9420AYW
Sep 13, 2008 | Dryers
Dryers Logo
196 people viewed this question
Top Dryers Experts
