I have a jl audio e1800 amplifier and it goes into protect mode at higher volumes i was wondering what my problem might be
So do i if you have found whats wrong with it let me know
Posted on Oct 26, 2008
What can I do when my amp goes into protect mode? A6450 class a/b Jl audio
Check your speakers wiring to make sure they are not touching. This will make your amp go in protection mode.
Mar 10, 2015 | Jl Audio Car Audio & Video
Why my jl audio 1400d amplifier stays in protective mode?
Check for a speaker wire that come come of , Or a loose grond wire on the amp or where ever you have the ground wire connected two,
Oct 31, 2012 | Jl Audio Car Audio & Video
Jl 1000/1 goes into protective mode with low frequency
Do you have a capacitor????? If not, when its up loud and hitting hard it might be going into protection because of a voltage sag....If it goes below 11.8v they will usually do that.....Get a multi meter and put on the hot and ground of your amp when its playing loud and see what the voltage is dropping to.....If its going below 12v, thats your remedy...gd luck....
May 02, 2012 | Jl Audio 1000/1 Car Audio Amplifier
My JL A6450 won't leave protect mode
there has to be a short in your wiring start by disconecting the speakers and see if it goes off
Jun 19, 2010 | Jl Audio A6450 Car Audio Amplifier
Amplifier cuts off after raising the volume
just a tad is all that it takes to throw it in protect mode so check the gain and the cross over and make sure they are set at a decent level and see if that works a little bit
Mar 30, 2010 | Jl Audio 500/1 Car Audio Amplifier
Bass freezes at a certain volumn and no longer gets higher
JUST CHECK THE CROSSOVER SWITCH, AND MAKE SURE THE SWITCHES ARE IN THE CORRECT POSITIONS
May 22, 2009 | Jl Audio 500/1 Car Audio Amplifier
Protect mode on 475a
Yes if your wires are to small they dont supply enough power to the amp and it will shut down..Also the ground..Check all connections for tightness and that none of the wires are touching or grounding out...Hope this helps you and have a great day
Apr 02, 2009 | Infinity 475A Car Audio Amplifier
Jl audio E6450 cutting out
hi, have you figured out whats wrong with ur amp ...i have the same amp ....and as soon as i finished the connections ...and connect the remote on wire,,, the amp goes on ...making a ticking sound with the green light blinking and the red light staying solid on ...whats the problem please help ....how can i fix this ......my amp is a jl e6450 ....im using a panasonic cd player with a built in amp ....and thats the cd player im trying to connect to the jl amp ...please HELP
Nov 01, 2007 | Jl Audio E6450 Car Audio Amplifier
500/1 turns on and off at high volumes
Make sure that you are using the right Guage wire for that installation. I had the same problem with another amp. I changed both, power & ground wires to 4 Guage and it worked fine after that. maybe that would work for you.
Sep 27, 2006 | Jl Audio 500/1 Car Audio Amplifier
107 people viewed this question
 Grubhead
Grubhead
