Question about Whirlpool Refrigerators
Refrigerator roaring I have a side by side frig. It's making a terribly loud roaring noise. I've continued to turn the cool button back & I've just now turned it off. Any help would be appreciated.
  • 1 more comment
  • gradyp Sep 15, 2008
    The water is not dispensing from dispenser. The noise is coming from the left side bottom where the filter is.
    Thanks.
    We'll try that. Thanks. What about the water not dispensing? We get ice but no water.
  • francis rivero May 11, 2010
    where is the roaring sound coming from?
    drcool
  • 958 Answers
It could be your condenser fan..check the back, remove the cover and check the fan at the back. it could be touching something.
tnx, drcool
Posted on Sep 15, 2008
  • francis rivero Sep 15, 2008
    you get the ice from the ice already in the ice bin. water not dispensing could be a solenoid problem at the back, filter clogged or due for replacement already, dispenser switch not functioning..and many more...
    ice produce could be affected later if the problem is in the water source or solenoid valves or water filter.
    tnx, drcool
Frig is making loud noise when it turns back on to cool.
proberly ice build up around the fan motor.You may have a defrost problem.
Oct 16, 2014 | KitchenAid Whirlpool Kitchen Aid...
The refrigerator strated making a loud roaring noise in the back of the freezer. we are about to leave for two weeks on vacation. Should I be worried or call a repairman?
Remove any perishable items and unplug the unit. When you get back and restart the unit if you do not notice the roaring and that roar comes back again in 2 or 3 weeks then yall have a defrost problem.
Apr 22, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Loud noise under refrigerator
it's a condenser fan, it's located on the bottom ,,at the back of the frig
unplug it first from the wall, & vaccum under neath bottom & around the fan,,then you need to see if the fan came loose from the shaft & if so tighten & also make sure nothing is caught in the fan...
Aug 01, 2010 | Whirlpool ES5FHAXS Side by Side...
Beeping sound coming from control panel model#10656562400
Hi!
Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer.
Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead.
To find out if the fan is causing the noise, just open the freezer door and push any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause which can't be lubricated or repair instead required to be replaced.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 01, 2009 | Kenmore 56562 / 56564 / 565 / 6656569 Side...
Frigidaire Frig side by side making a loud buzzing noise
it sounds like the compressor, or something near it. it is generally the only moving part in a refrigerator other than the door, so would be my first guess. If it is constantly running, but staying cool in the freezer there may be a small leak somewhere or the compressor is losing power, and pumping slower.
Jun 15, 2009 | Frigidaire FRS26H5AS Side by Side...
Load noise coming from freezer
nothing to do with light bulb - noise is probably fan hitting ice that has built up. to check, remove back panel inside freezer and check for ice build up. melt off with a hairdryer and get back to me if i'm right
Nov 12, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerators Logo
102 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
