Question about HP LaserJet 2420 Printer
Creasing and jaming 60 gram paper
We have a 2420dn with duplexing. 2 trays plus manual feed tray 1
Printer has worked well since new but now has developed a problem with thinner paper, 60 gram. It creases the paper with a neat 8mm concertina fold about 160mm from front of sheet, then jams in outfeed.
From tray 2 & 3 it does this every time. with tray 1 it works most of the time, but every so often it creases as described above.
80 gram paper works ok from any tray and all the time!!
Any ideas please?
  • rowlandkw Sep 17, 2008
    Thanks for suggestions.
    I had already set to lowest paper weight and it did not help.
    No evidence of broken flags - but would any paper go through properly with a broken flag?
    As originally said Tray one (manual tray) does work most of the time on 60gram paper both 1 & 2 sided.
  • HP Expert
  • 141 Answers
1. change the paper type setting to the lightest media setting you can find. this will be found in the paper handling menu. make sure that you do this on every tray that you will run the lighter media through. the reason for this change is to adjust the timing and temperature ranges in the machine.
2. if that doesn't help then try printing simplex (one sided) to see if the jamming is still in the same place. if the jam persists then you have a fuser problem, if not then your issue is in the duplex ***'y.
Having said all of this, blow the machine out with canned air before any of this with the toner cartridge removed. the reason for this is not just the obvious cleaning, but to find broken sensor flags. they will look like flat plastic pieces that will be white or gray on one end. if you find one of these flying out of your machine then there is your problem. Good Luck!
Posted on Sep 16, 2008
  • steve shroder Sep 16, 2008
    the word that is starred is the shortened variation of assembly, my apologies
  • steve shroder Sep 17, 2008
    a sticking or broken sensor may work intermittently.
Duplex feed not working
Check the C6200 Device Settings in the properties and make sure that the Duplex Unit is installed.
original?v=mpbl-1&px=-1
Dec 09, 2013 | Brother HL 5250DN Laser Printer
Duplexer problem
There are several thing which may cause unexpected jams in the duplex tray...,
1. first thing to do is eliminate all other possibilities by removing the netCard/Net connection Parralel connection so the machine is Stand Alone. make sure there is paper in the feed cassette 2 ( paper Tray)
press the TICK to enter menu
scroll down to diagnostic- press TICK
scroll down to paper path test - press Tick
scroll down to Source and select tray 2
scroll down to Duplex And select YES
( if the duplex option is not visible here then there is a connection/seating problem with the duplex tray)
Scroll down to copies and select 10
scroll up to print test page and press tick
the machine should now start duplexing 10 pages,
if you get the same error ( 1 page enters then jams)
it could be a dirty/snapped paper entry sensor,( looks like a little plastic match stick that protrudes into the feed path of the paper)
use a can of pressurised air to Blast any dust away from this arm and the surrounding area being careful to follow the Paper sensor Arm back to the sensor and blasting this as well-
Duplexer tray are cheaper than an engineer call out, if the fix above fails , your cheapest option may be a replacement Duplexer tray, available from most HP office equipment Stores as well as Belmonte Business Equipment.
Jul 23, 2013 | HP LaserJet 4250n Printer
I want duplex printing for hp 2420
The only way to duplex print on a standard 2420 is to print the first page, then take that page and re-insert it into the paper tray face up. Then print page 2 onto the back of page 1. If you want to automatically duplex print then you need a 2420DN printer which has the duplexing paper path as well as the formatter board with the duplex firmware.
Good Luck and Thank You for using Fixya.
Sep 23, 2010 | HP LaserJet 2420 Printer
Fix for 13.12 error
Hi
You are getting Error 13.12 due to paper jam at Paper feed 1. It can also happen when the Paper doesn't reach PS2(paper sensor 2).
Please check the picture for more details---
Try printing from Tray 2 or Tray 3, if it fails printing from tray 2 or 3 then Paper sensor 2 (PS2) is bad. To check the movement of flag insert the paper manually in the sensor path.
Remove any paper present in printer and then perform a paper path test using a duplexer. If issue is still not resolved then please remove the duplexer unit and re seat it. After re seating the duplexer your issue will be resolved.
Daniel Scott
Jun 28, 2010 | HP LaserJet 8100dn Printer
Colour laserjet HP cp2025 keeps going into cleaning mode - why ?
Re: CP2025 cleaning at every possible moment Talked to HP support and fixed mine by changing Settings/Paper Handling/Tray 2 Type to "Heavy 111-130g"
All paper handling settings as follows:
Default Paper Size: Letter
Default Paper Type: Plain
Manual Feed: Off Duplex: Off Bind: Long Edge
Tray 1 Size: Any size Tray 1 Type: Any Type Tray 2 Size: Letter Tray 2 Type: Heavy 111-130g
Paper Out Handling
Specify Time and Action Paper Out Time: 0 Seconds
Paper Out Action:
Override
Apr 17, 2010 | HP Color LaserJet 2600n Printer
I want my printer to only use tray 2 but it keeps reverting to Tray 1
Go into the "menu" settings, and under (i believe) "paper settings" (or similar), set "manual feed" to "off"
Jul 20, 2009 | HP LaserJet 2420dn Printer
Duplexer
If you really have an HP 4350dtn (d = duplexer), then the duplexer is not connected correctly. Look at the back of the printer for the duplexer. It prtrudes from the back drop down tray and is used to print on both sides. I would pull it out and push it back in to make sure all connections are tight.
Tray number 1 is the manual feed tray in the front of the unit.
Mar 03, 2008 | HP LaserJet 4350dtn Printer
Duplexer problem
First, the machine always prints the first page first. Make sure you have the right driver (4 plus and not 4)and check the settings in the device settings of your printer driver on the pc. Also make sure the duplex unit is for the 4 plus and not the 4.
May 17, 2007 | HP LaserJet 4 plus Printer
HP LaserJet 2420 Printer Logo
188 people viewed this question
Ben Johnson
