Question about LG Washing Machines
LG wm2077CN display LE error code - LG Washing Machines
  • 3 Answers
There is a hose that runs from the bottom of the tub to a switch at the computer module (think this is a level switch). Hold the <spin speed> and <soil level> buttons at same time, if below 246, then take hose off of switch and blow hard into it until you hear bubbles. The hose is clogged with **** and this will clear it, should start after that and the level should read higher (mine went from ~230 to ~260)
Posted on Feb 22, 2009
My 7 year old LG Front Load Washer Model # WM1812CW displayed ERROR CODE LE(Overload in motor): how can I fix this problem ? The rinse cycle begins, shortly thereafter, the machine stops and the LE code...
Hello & Welcome to FixYa
LE error in your LG front load washer is displayed when either the motor is not working or the control board thinks that the motor is locked up. A Hall Effect sensor is used in these washers which monitors the speed and direction of the motor and then forwards this information to the control board. Hope you understand by now that this LE error is displayed when there is an issue with the motor or when the Hall Effect sensor sends wrong signal to the control. Conclusion is you'll have to check both motor and hall sensor and replace the part# that is bad, usually I have seen the sensor going bad. Please get back to me if you have any other questions.
Kevin
Aug 29, 2011 | Washing Machines
LG washing machine loud and error code LE
Here is a tip that explains what the LE error code means.....
LG Washing Machine LE Error Code or Fault Code
heatman101
Jul 02, 2011 | LG WM2301HW Front Load Washer
Lg dishwasher displays LE error
Display Condition LE = Motor Error
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is
locked.
The rotor of Washing Motor is
locked.
The Blade is locked.
Remedy:
Check the wiring connection.
Replace the cause of restriction.
Replace the Washing Motor.
Replace the PCB.
Additional details in this article: dishwasher/how-to-fix-lg-dishwasher-le-error
Hope this helps (remember to rate and comment this answer).
May 26, 2011 | LG Dishwashers
Dishwashing cycle starts for about 3 minutes then flashing LE light comes on and the machine stops. Why?
The Impeller of Washing Pump is locked.
The rotor of Washing Motor is locked.
Remedy:
Replace the PCB.
Try the following steps:
Unplug the washing machine if you see an LE error on the two-digit display electronic readout. This error indicates a miscommunication between the control panel and wash motor.
Press and hold the "Start/Pause" button on the front panel for five seconds.
Plug the LG dishwasher back in.
Run a cycle. The LE code will clear.
Aug 31, 2010 | LG 24 in. LDF 7811 Stainless Steel...
LG Tromm WM2077CW error code LE
No all you have to do is watch how much and what kind of soap you put in that washer...
http://www.fixya.com/support/r4348161-lg_washing_machine_le_error_code_or
heatman101
Apr 15, 2010 | LG WM-2277HW Front Load Washer
LG WM2277HW - ERROR CODE "LE"
Hello remrama,
Please use this link to access the service manual on your display code message ( page 18 ) elaborates on the cause of that message. You should be able to determine which of the few causes may be the culpret,... http://136.166.4.200/contents/Laundry/WM2277/WM2277xx_Service_Manual.pdf
Hope this helps you..
Regards,
Rick
Feb 22, 2009 | LG WM-2277HW Front Load Washer
Error code LE
Hello and welcome,
locked.
locked.
Remedy:
Replace the PCB.
Jan 19, 2009 | LG 24 in. LD-12BW5 Free-standing...
Problem with LG washing machine Model number wm1480fhd. The machine drum reluctantly turns and in about a few minutes it displays error code LE (flashing).
LE error code: This indicates a locked motor condition. Please check the following conditions. Large loads of laundry can put a strain on the motor causing the LE error code. Try removing some clothing and restart. Excessive suds can cause the LE error code. Make sure the customer is using an HE (High Efficiency) detergent. They should decrease the amount of detergent until the machine washes without suds. A few bubbles can be expected. Areas that have �soft� water will usually need to use less detergent. If you suspect that excessive suds are the problem, let the machine stand for 30 min (motor cool down) and then run a rinse and spin cycle before restarting the load. If these directions are followed and the code persists, the machine will likely need service. .
Aug 22, 2008 | LG Washing Machines
LE trouble code
The LE error code can be an indication of several different issues. The most common cause is over-sudsing in the machine. Many times owners experiencing the LE error code are using regular detergent. It is recommended to use a high efficiency or low sudsing detergent. Overloading the wash with too much laundry may also cause the LE error code. Lastly, a breakdown in the signal between the microprocessor and the motor may cause the error code. This can occur if there is a loose wire, dislodged ball sensor, or if the shipping bolts are removed prior to situating the washer. Good luck!
Sep 13, 2007 | LG 24 in. LDS 5811ST Stainless Steel...
Washing Machines Logo
387 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
