Philips 50PF9966 50 in. HDTV-Ready Plasma Television Logo
Posted on Aug 21, 2017
My philips 50pf9966/12 when i switch on from the side, the front blue light comes on for 2 second, then goes off, and no further lights on the front. when i removed the back, only 1 green led is on with the power socket on, then another green led comes on for 2 seconds, then goes off. the blue light on the front and the green led at the back go on and off together. what is the problem?
5 Related Answers
Anonymous
  • 4402 Answers
  • Posted on Dec 06, 2007
SOURCE: Red light flashing
The TV is in some kind of protection mode, the blinking LED show you an error code.
Try pressing 062596 and then press menu button (do these in quick motion, don't let them to time out while keying)...see what happens
Well I think that if you would have a service manual for this set that would help a lot, I can send it to anyone who wants it via email/gmail. Let me know if anyone want one.
I also heard that this problem appeared with some people because the of the burnt fuse in the TV. To fix that it has to be taken to the tech shop. mecry.gif
And yes I also heard about this issue many times, seems like this TV set is very popular with this kind of problem.
Anonymous
  • 77 Answers
  • Posted on Feb 01, 2008
SOURCE: Philips 42 in. Plasma shut down
The LED blinking 7 times is a code to tell the service tech what is wrong with the TV. From what I've read at other sites it sounds like there;s a good posibility that it is a power supply gone bad.
You probably should call a TV repair shop for assisitance.
Anonymous
  • Posted on Feb 12, 2008
SOURCE: won't power, light goes green 5-10 seconds later red flashing light
Solution Found.
I had the same problem with my 42FD5994. It was working fine, then one day I turned the TV on and the front light turned green for about 5 - 10 seconds and then the TV switched to protection mode (front green light is now red and flashing constantly). I did some research and found out the the power board is faulty. I ordered a DIY fix it kit on Ebay for around $55 (includes shipping). The kit contains 5 high temp capacitors and a new IC chip. It also comes with a good detailed photo of the circuit board the components that needed replacing.
I also spent $70 at Radio Shack for some soldering gear and went to work. It took me 3 hours to replace the 6 components. The IC chip was a pain to remove, but one that was out the rest went pretty smooth. I had to remove two extra blue capacitors in front of the IC chip to desolder some of the leads.
After I cleaned the board with Isopropal alcohol (99% pure) to remove the excess flux, I inspected the solder joints to make sure I didn't solder some runs together. All looked good.
Next I put the TV back together and hooked everything back up. I powered on the TV and the same problem as before. The TV went into protection mode. But this time I heard the speakers pop and the screen buzzed. So I pushed in the power button to reset the TV. Next, I turned the TV back on, but this time when the light was green, I quickly pushed the power button again to power off the TV. I tried the TV one last time. I powered the TV back on, and with the remote I turned the TV on. Viola! It worked. The TV powers on great, and works like a champ. I am guessing that the first time I tried to turn the TV on, the new components needed a minute to energize. I also started the TV cold, I should have plugged it in for a few minutes before I tried turning it on.
So, I was successful fixing my 42FD5594 with the DIY kit on Ebay. I ordered it from California. The company was great, and Everything arrived well protected. I figured if this didn't work, it was time to get a new TV anyway. I can save the $2000 for another day.
Anonymous
  • 138 Answers
  • Posted on Aug 19, 2008
SOURCE: philips 42pf7321d/37 blinking power board question
The probleis with one of the maina boards and trouble shooting would have to be done to see which board is bad.
William
  • 188 Answers
  • Posted on Jul 21, 2009
SOURCE: no picture on my philips 42PF7321D/37
Bad caps in the power supply must be replaced .
It is the switch in the 2006 cavalierfema trailer above the sink I need to put the switch in but dont know what color wire goes where there is 4 prongs on the switch itself but has 2 red wires 2 purple...
With todays phones, it is always best to take a pic of the actual wiring hookup... Go to google, maybe they have a wiring diagram for it.
Aug 13, 2017 • RVs
My phillips 60 inch tv 60pl9200d/37 wont turn on the power button flashes blue
Look in the manual. (Page 4)
Turn the TV on From main supply: Ensure that the main supply is turned on. A blue indicator light on the front of the TV lights up. When the TV is turned on by the main supply, the blue indicator light will blink for 45 seconds. This is the lamp's start-up period. When the light goes off, press the POWER button on the remote control or power switch. Press POWER to turn on the TV.
http://www.retrevo.com/support/Philips-60PL9200D-TVs-manual/id/633ag423/t/2/
Telephone number Philips Customer Care Center: 1-888-PHILIPS (744-5477)
I have a Philips 52PFL7422D/37 52" TV. For the last year now the TV will make a clicking sound like it is turning on but never does. After a couple of seconds to a minute the TV makes another...
I have the same model and the same problem... I am told the power display board is is the issue and may need to replacing. New board costs around $80,or a bad capacitor depending on your paitence.
3helpful
Screen only stays on for 2 seconds at a time
just an update...I have fitted a new cable (pc to monitor) and it has been on for 2hrs now so fingers crossed!
Blue amp light lights for 2sec
bad head unit or look at your ground wire good luck
Philips 42pf9956/37
when the light goes red it should be blinking a two digit code and repeat itself continuosly. slow blinks are the first digit and fast blinks are the second digit
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
