Question about Samsung SyncMaster 753S 17" CRT Monitor
How do you open the moniter ??
Hi i have A SAMSUNG 794S SYNCH MASTER it wont switch on , when you look inside u can c a fuse which i suspect has blown but after removing the screws (only 2 ) i cant open the top part it seems like its sealed shut or the clippers are placed firmly . How do i open it ??
  • Anonymous Apr 10, 2009
    hi i have A SAMSUNG 794S SYNCH MASTER it wont switch on , when you look inside u can c a fuse which i suspect has blown but after removing the screws (only 2 ) i cant open the top part it seems like its sealed shut or the clippers are placed firmly . How do i open it ??
  • Shravan Chakravarty
    Shravan Chakravarty Apr 23, 2009
    My samsung SyncMaster 753S 17" CRT Monitor has full of dust and foreign particles got inside the monitor .How to open the back cover of the monitor . It seems i can open only the bottom of the monitor with screw .I can't open the top of the monitor and it seems there is no screw on the top.So how to open the monitor
  • 20 Answers
With a screw driver pree the openings on the top while you pull the cabinet.
Posted on Sep 20, 2008
1995 Lexus gs300 power windows
check inside the boot where the drivers door swings .
the wires sometimes break inside the boot because of the
drivers door being used the most.Just **** the cover with a razor
blade and check it out.If there is a broken one (or 2) it's best
to pull the harness but you can use a **** connector or solder and tape
but it's a tight squeeze.
Best guess ,odd problem.
Jul 23, 2012 | 1995 Lexus GS 300
All windows will not operate - fuse on inside fuse panel is okay
well since the fuse is good, then I would suspect the master switch box, the multi switch has the power for all windows running thorough it, I would suspect this switch box since the fuse is good.
try pulling this switch box out, and flip it over give each window its power it needs to operate, this will tell you if you have a bad window motor, but I seriously doubt it thoe since its all of them. but the main switch box is the problem.
Jan 03, 2011 | 2003 Saturn ION
PASSENGER WINDOW IS THE ONLY WINDOW THAT WILL GO UP AND DOWN. HOW CAN IT BE FIXED?
If all other windows wont work, I would suspect bad master switch on drivers door or broken wire in harness to drivers door. This wire harness goes through door in boot between inside of door & kick panel. Because of use, opening & closing, wires break or corrode. Pull boot apart look for obvious breaks or green corroded wires.
Jul 01, 2010 | 1991 Lincoln Town Car
Windows wont roll up and down and hazard continues to click even when not on.
These are two separate issues.The most common cause of the clicking is the hazard switch located above the radio.Replacing this generally takes care of that issue occassionally it is a malfunction in the turn signal switch but most likely the hazard switch. If all windows are affected would check fuses first.If the windows roll down from the corresponding switches example rf allows rf to roll down. If not suspect an electrical issue such as fuse or relay.If they do roll down from the switches on the doors but not the drivers door possible a master switch issue.Drivers door contains a master switch that controls all windows.Do the windows work at all?
Jun 06, 2010 | 2000 Pontiac Grand Am GT
My Computer screen goes black at start up. I have a windows xp. I have switched Screens with a working moniter and found out somthing is wrong with the screen. I really need help From, Anynamos
Caps in the power supply will be the first suspect.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 04, 2010 | Rosewill R900J 19" Flat Panel LCD Monitor
On my Dash, when I synch, I want the dash to be master, not PC
hi.my phone is bestel D5000.my messages in box always empty.plese help me.and tel me how can format and reinstall my phone data(software).give ne best help.
Feb 02, 2009 | T-Mobile Dash Smartphone
GeForce FX 5200
If your video card was not working correctly your problem would be evident in other applications as well, I suspect you have a software problem on the computer, most likely with the OS 10 software and possibly a conflict with the version of Quark you are running.
Oct 28, 2008 | Apple iMac G5 Desktop
How to open moniter cover
see on the top of cover where have two hole,leave monitor on it face, unwrap two vit on it back . you can use a small knight to push on it strongly and slowly keep going untill you hear a sound it leaf connect lock on cover monitor. do again with other hole
May 05, 2006 | Samsung 793DF 17" CRT Monitor
Samsung SyncMaster 753S 17" CRT Monitor Logo
316 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
