Question about iRiver Audio Players & Recorders
Hi I have just unpacked the clix 8gb, an upgrade from my 2 gb. with the 2gb it was easy to transfer my playlists from the windows media player to the device. I have not managed to do this with the iriver plus3. Irritatingly and worryingly, the device storage indicator shows 4 gb of usage- when no files are visibly anywhere on the device. whats going on please? Can you please tell me-how to transfer my playlists via the windows media player onto the device? It works perfectly well with the clix2, why not with the clix 8????? many thanks Joe Sedlmaier
5 Suggested Answers
SOURCE: IRIVER PLUS 3 MEDIA TRANSFER SCREEN
My understanding, as a new user, is that IRiver plus 3 only communicates with the player via UMS mode, which is not the default. Windows Explorer and Windows Media Player only communicate through MTP mode. If you change from MTP (the default) to UMS, it will reformat the player and delete all your files.
In other words, do not use iriver plus 3 unless that is the only software that you want to use. Boing back to MTP mode after a sync or download will then delete all THOSE files you just downloaded.
I just say NO to Plus 3.
Good luck.
Posted on Jan 25, 2008
SOURCE: iriver clix2
If you have a song up just click and hold to the right and a bunch of options should show up. The first option should be "play mode" and in there you can choose whether your playlist (or album, depending on how to navigated to the song) will shuffle and repeat.
Posted on Feb 29, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: transfer files from disk to iriver ifp-895
The songs are probably in the wrong format. convert them all to Mp3 format, and try again.
Posted on Sep 04, 2008
dvdcdlaser
  • 1285 Answers
SOURCE: Iriver won't let me upload from CDs and transfer....
go to my computer and open the C drive /create a new folder my music (rename it) ...ok now plug up iriver to pc...again go to start/my computer/ see the iriver drive open it...now you should see all the files on the iriver also...place both window side by side (or top & bottom) and click & drag (or copy & paste) from both iriver and pc...now you can save and copy from either one..........
Posted on Jul 16, 2009
Testimonial: "Brilliant, thanks. I was trying to copy them from the iRiver app, instead of the iRiver folder."
How to create playlist on e260 sandisk sansa pm3 player
this is from sansa website FAQ... check it too for ur other concers... well i hope this is what ur looking for...
How do I create and transfer playlists into my MP3 player using Windows Media Player 11?
STEP 1 – Create a playlist
  1. Run Windows Media Player.
  2. Click Create Playlist located in the top left corner.
  3. Type in the name of your playlist.
  4. Drag and drop music files into the Playlist Window.
  5. Click Save Playlist to save the list.
STEP 2 – Transfer the playlist to your device
  1. Click the Sync tab on the top bar.
  2. Drag and drop your playlist from the left window into the Sync List window on the right.
  3. Click Start Sync.
Sep 13, 2009 | SanDisk Sansa e260 MP3 Player
Playlist dont Show
That player is set up for playlist transfer through Windows Media Player 10 only - you can either: 1) rollback your Windows Media Player to ver. 10; 2) attempt the firmware upgrade by running the Update tab in Philips Device Manager (may not work); 3) reinstall the installation CD - select Repair as your choice - it will add a plug-in that it may have skipped during initial installation. Good luck!
-Tha Mp3 Doctor
Dec 29, 2008 | Philips GOGEAR SA6045 MP3 Player
I can't get a playlist onto my Sansa m240. I tried the method described on this site, and the name of the playlist came up, but said it had no files.
Creating Playlist
To create a playlist for Windows Media Player, follow these steps:
1. Launch Windows Media Player.
2. Clear the List pane by clicking the Clear List pane button.
3. Click the arrow below the Library Tab then select Create Playlist.
4. Type in the name of your Playlist.
Loading Content 14
5. Click Songs from Library then drag them from the Details pane to the List
Pane.
6. To rearrange the songs, drag them up or down in the List pane.
7. Click Save Playlist.
Transferring Playlists
To transfer playlists to your Sansa player, follow these steps:
1. Connect your Sansa player to the computer.
2. Select Sync digital media files to this devices using Windows Media
Player on initial connection.
3. Right-click on Your Sansa Player, then select Set Up Sync.
Loading Content 15
4. Select Personal Playlists from the drop down menu on the left pane.
5. Highlight the playlists you want to transfer to your Sansa player, click Add,
then Finish.
6. Synchronization will start as soon as you click Finish. To see the Sync
progress, click on Sync Results.
Dec 05, 2008 | SanDisk Sansa m240 MP3 Player
2 GB of music disappeared from Menu but space still taken (Clix2)
hi this happened to me when you go on ur iriver playlist right click on all music and click onto database update then hit start button and all will be found!
Oct 13, 2008 | iRiver clix 2nd generation MP3 Player
How do i make a playlist
-Tha Mp3 Doctor
Oct 03, 2008 | Philips GOGEAR SA6045 MP3 Player
Formatting
You should try to upload the newest firmware for your device. Simply go to irivers site, look under Iriver Clix Generation 1 support (I'm guessing you have the generation one... if not, just click generation two). Simple as that!
Sep 21, 2008 | iRiver Clix Digital Media Player
Iriver clix - dowloading music from laptop to iriver clix
If you set up Windows Media Player to autosync to the Clix, then, when you delete songs from the computer (including the wallpaper jpeg), the files also get deleted off the clix. Make sure you have Manual Sync enabled in Windows Media Player (or, more accurately, disable auto-sync).
If auto-sync is already disabled, then you have a good, old-fashioned DB corruption. You can reload the firmware from iRiver's website:
http://iriverinc.com/support/ultra/clix2.aspx.
Sep 07, 2008 | iRiver clix 2nd generation MP3 Player
Snyc & Playlist
I took my computer and the Sansa to the Best Buy store. And for "free" the technician reformated my Sansa and I am happy. Problem is solved. Thank you
Jul 14, 2008 | SanDisk Sansa View 8GB MP3 Player - Black
Iriver mp3 player
Same problem on a 2GB x20 I just bought. Easy to get things into the device, but nothing recognized as playlist either using iriver plus3 or Media Player.
Feb 05, 2008 | iRiver X20 MP3 Player
Iriver clix2
Feb 01, 2008 | iRiver Clix Digital Media Player
35 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
