Question about Sony PlayStation Portable (PSP) Console
PSP Not Loading
Hi ALL:
I have a practically brand new PSP that has been only used 10 times, I basically stopped using it because I lost the joystick to the leftside of the anolog. Since trying to charge it it says that it is charging and then when I unplug the charger and try to start it up it doesnt boot up, the light changes from green to orange. I have even switched the battery with another and same thing happens. Can someone help me and tell me the best way forward with this device?? Please I need some help or advise
Calvin
  • skunkyganja Sep 16, 2008
    i cant get my game to load same thing with the battery
  • 3 Answers
Just remove the battery and memory stick and try it on another psp if the same problem occurs the problem it is because of the memory
Posted on Sep 17, 2008
Umm-m20e stopped working out of no where,its brand new(this happened aft r just few times of useing it)
The power switch, the speed selector, A brush may have failed. The contactor may have a burned contact or not operate at all.
Nov 03, 2016 | Food Mixers
My joystick is not working normally as it use to be.
I know how to solve this so worry not! here's the solution:
1:your joystick may have a little part that is dismembered so buy a new one
2:ask for a assistant to open your psp to put the joystick properly
3:I have the same problem so here's what I do.
good luck
Jul 24, 2009 | Sony PlayStation Portable (PSP) Console
Joystick problems
The only way this can happen is if you have damaged the joystick function area.You have to change the joystick and put another one.
Jul 22, 2009 | Sony PlayStation Portable (PSP) Console
Psp original fat kind wont read disks
you can find a used fat modle on crages list for around 40 bucks, and used fat ones at a place like game stops 70-90. one option i would try is a little rubbing alcohol on one side of a Qtip, wipe the lazer eye very gently with the wet side then dry it with the other end of the Qtip, let sit for about 10 mins and giver a go. (DO THIS AT OWN RISK) =D if your very gentle you wount mess it up, the eye is glass and some times it just gets dusty. hope it helps
Jun 11, 2009 | Sony PlayStation Portable (PSP) Console
PSP joystick messed up
Okay This has happen to me and what it is the joystick is off track. I'm not saying you guys are handling your psp roughly but it does happen. You can try to repair the joystick yourself.
But the best bet is to buy a new one. Doesn't cost much and it is not hard to do. I paid $3 for a replacement. Word of advice if you are buying a generic brand you may want to buy at least three of then just in case one or more of them are doa (dead on arrival) you never know. Will save to time in returning and waiting for a replacement.
If you want please ask and I will post a how to for repair of your OEM joystick. This doesn't always work but what the hell it's worth a shot.
Dec 20, 2008 | Sony PlayStation Portable (PSP) Console
Psp joystick
try replaceing the stick but else i would take it into a store and get it fixed
Feel free to Email me: Thomashedderwick@hotmail.com
Aug 09, 2008 | Sony PlayStation Portable (PSP) Console
Psp
Try to use some proper English and more people can help you..
Dec 25, 2007 | Sony PlayStation Portable (PSP) Console
Psp joystick problems
Good day all
I recently ran into this same problem of a PSP joystick "jumping" or hopping around. Since I'm an electronics engineer I was determined to get to the bottom of this annoying problem, I read all the posts on the site and none helped, but the problem turned out to be much easier fixed than I first anticipated.
First of all I assume that you know how to take the PSP apart and take out the joystick module as well. The Joystick module connects to the PSP mainboard by means of 4 contacts, seperated by a spacer conductor that appears like a rectangular rubber, be careful not to lose this during the process.
Here is why the problem occurs, when you have a faulty joystick module, one or more of those 4 contacts don't connect to the main board anymore, so the when the PSP is trying to measure the resistance to determine the joystick position, it reads a varying value, i.e. the contact is floating.
This happens for mainly 2 reasons, dirt or a faulty module, as stated in the previous posts, the contacts could be dirty, but this can usually easy be seen, and this wasn't the problem in my case, I had a faulty module, but luckily all is not lost.
Here's how to fix a faulty module in most cases. Remove the joystick module from the PSP completely, put that little rectangular rubber on the 4 contacts (clear in my case) aside and keep it safe. There is metal clasp on the bottom of the module, you can simply pop it off with a screwdriver, by slightly bending the clasps on the side and taking it off. Now you should be able to see a VERY SIMPLE mini circuit board with tracks on, on the bottom of the module, you can indeed pop this off too. On this you will see tracks where the joystick sliders move. Put the circuit board aside too. Now look at the now completely open joystick module, you will see the two sliders each having a metal part, each of these metal parts has 2 very small contacts that run on the circuit board tracks that you just removed, most times these small contacts get bent inward and they can't make contact with the circuit board tracks anymore. Just bend them slightly outward again, so that when you put circuit board back, they touch the tracks on the board nicely. Put the circuit board back, it just slips back on, put the metal clasp back, put the rubber back in over 4 contacts on the module and voila, if all goes well you will have a nice working joystick module again. Put it back in the PSP and test it to see if it worked. In my case it worked 100% and saved me a few bucks. Hope this helps everyone. Let me know if it worked.
Oct 16, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
