SOURCE: Unable to have 1280x768 full screen with DVI cable
Use the menu button on the monitor itself to adjust for the screen size in DVI mode. On your SVGA adapter, go to your display properties (right click on desktop) click ADVANCED and change the refresh rate to fix the first problem mentioned.
SOURCE: screen flashes when using dvi input
make sure the cables are tight if they are i would look at replacing the video card.
SOURCE: DVI input on monitor not working
try to reinstall the display card driver . Reboot your system.
SOURCE: I need help setting up the DVI input.
There are two ways to do this.
First and simplest is to simply shutdown the pc, disconnect the analog from the back of your PC and connect the DVI cable to the PC and monitor. When you turn it back on the PC will detect and switch to the DVI.
Second, and better to compare. Connect both sets of cables and go into your display settings, then select advanced options. You should see a GeForce tab in the advanced menu. On that tab there is a multi monitor display setup. Set it to mirror to both screens and apply.
Once it's set switching inputs on the monitor SHOULD work. The problem that makes it a "should" is that both the monitor and the video card have the ablility to sense a connection. So, even with mirroring setup you may have to use the first method as you can't have both connected and operational at the same time.
Give these a try, if you're not sure how to get into the display settings, comment back here with your windows version and I will give you a step by step
Chris
SOURCE: No sound when using HDMI cable but I do have sound if using DVI
Is your computer configured to send sound through the HDMI cable as its output device? This might be a setting within your sound card properties.
Compare internal and external TV tuners that are designed for use with computers. See if the tuner supports HD, DVI, component video, S-video, stereo, surround sound or other features you might like to use. Ensure that any internal devices will work with the expansion slots in your computer.
Purchase a regular TV tuner if your monitor has S-video, coaxial or RCA inputs. These can be seen at the back of the monitor. S-video should be clearly marked; coaxial is a large round port, and RCA inputs are typically smaller and brightly colored. If your monitor does not have these inputs, purchase a special TV tuner designed just for computer monitors. If you would like to use the tuner with your computer and monitor, choose an internal TV tuner. If you're using your computer monitor as a television on its own, select a stand-alone external tuner. Install the internal TV in your computer, if applicable.
Connect the TV tuner to the monitor with the proper cable. Select S-video as the connection option if both your tuner and monitor support it. Choose RCA component video as your next option. Use coaxial only if your monitor and tuner do not have the aforementioned connections. If your monitor has none of these connections, use a standard VGA cable to connect the tuner and monitor.
Connect the tuner's audio outputs to your monitor's speakers. If your monitor has no speakers directly attached, connect external speakers to the TV tuner. This can usually be achieved using regular audio or RCA cable.
Install an HD antenna high on a wall if you will be picking up free over-the-air television signals with your monitor. If you will be using satellite or cable TV with your monitor, simply plug the satellite or cable set top box into the tuner using RCA or coaxial cables. Then connect the tuner directly to the monitor.
Set your tuner to the channel you use to pick up television stations. If you receive free over-the-air television, this channel will be 3 or 4. If you have satellite or cable TV, this station is determined by your television service provider. Check the documentation that came with your system to determine which channel to set the tuner on. You will probably need to change channels using the satellite or cable box rather than the TV tuner.
