Question about HP Compaq Presario V2000 Notebook
Reparar mi computadora
Mi computadora se tarda en subir y abrir el monitor
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 359 Answers
I do not speak Spanish (no hablo Espanol) -- but this is the solution...
Please see this reference, as it is a known and identified issue with this model at HP: http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&dlc=en&cc=us&product=18703&docname=c01087194.
Your issue is most likely a defective machine, and HP should assist you with repairing it or replacing it as appropriate. If you do not one of the specifically identified product numbers, or are in a different location, you still have a solid case for getting it corrected. The documentation is there that the product is defective, and HP needs to correct it for you. Good luck - I hope it goes well!
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred subsequently and/or more details regarding the situation, and I will gladly help you until we have reached a definitive solution. Thank you for using and rating FixYa!
Posted on Sep 26, 2008
Mi monitor SyncMaster T220N, se demora en iniciar
The monitor power supply may have failed.
Jan 12, 2015 | Computers & Internet
Subir volumen en dish
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box.
May 27, 2014 | DISH Network Televison & Video
Tengo un neon 2005 tarda mucho en apagar se le ha reemplazado la computadora 3 veces pero sigue con el mismo problema
Esto suena como un problema con el antirrobo. Su coche ha "AntiTheft" instalado. Todos Chryslers hacer. Asi que si hay un problema con su llave, el coche arranca y luego mueren.
This sounds like an issue with your AntiTheft. Your car has "AntiTheft" installed. All Chryslers do. So if there is an issue with your key, your car will start and then die.
Oct 23, 2012 | Dodge Neon Cars & Trucks
Mi coby no quiere abrir la libreria de las canciones
has puesto las canciones del dispositivo? usted podr?a conectar el dispositivo ala computadora y abrir el dispositivo, cree una carpeta llamada "m?sica" y ponertodas las canciones que desea escuchar en ese pa?s.
Jun 30, 2011 | Coby MP-610 MP3 Player
ACABO DE ADQUIRIR UN COBY MP727, SI ACEPTA LA CARGA POR MEDIO DE LA COMPUTADORA PERO NO RECONOCE EL USB PARA EL ENVIO DE MUSICA
tiene que o?r el equipo hace un ruido cuando se conecta el USB en el puerto. si esto no ocurre, usted tiene un puerto USB muertos. si usted est? escuchando el ruido cuando se conecta el USB a la computadora luego contin?e con el siguiente p?rrafo.
si est? usando Windows XP, vaya a "Mi PC" y el dispositivo debe aparecer como otro disco duro, al igual que tu (Disco local (C:)), disco duro interno. Usted puede abrir este al igual que una carpeta y desde all? debe ser capaz de colocar la m?sica en el dispositivo.
Jan 09, 2011 | Coby MP727 MP3 Player
Mi reproductor MP3 RCA HT103 no logro accesar a el en ninguna computadora. si prende pero no tengo acceso a ningina de sus funciones ni en reproductor ni en la copmputadora, solo se pernde la pantalla y...
Si es la primera vez que usas el reproductor, es posible que este vacio.
Trate de hacer esto:
- connectalo a la computadora usando el connector USB. Espera que Windoes te diga que ha hecho una buena conneccion.
- Cunado esto esta hecho, puedes ver el reproductor en tu computadora como un disco nuevo.
- Copia un par de canciones en formato MP3 a heste nuevo disco (no hagas un folder nuevo)
- Desconecta el reproductor de la computadora (usa el eject USB drive)
- Ensaya de tocar las canciones que copiaste en el reproductor.
Ojala que esto funcione.
Nov 05, 2010 | RCA TH103 (256 MB) MP3 Player
Tengo un problema horizontal en mi monitor dell
que tipo?
fluatuação ou mas pequena que ecran es fonte de alimentacion, com problemas, tiene que reparar-la. normalmente, e um pouco ingrato que se pierde mucho tiempo reparar-la, e o custo de uno novo monitor, normalmente nao compensa reparar-la.
Feb 09, 2010 | Dell P793 17" CRT Monitor
MI PC TIENE BOCINAS PERO DICE QUE NO LAS TIENE Y NO SE ESCUCHA.
Hola si tienes donde poner los cables de las bocinas detras de la computadora y todadia no trabaja entonces tienes que abrirr el control manager y prender las bocinas por dentro el control de volume va a estar en el keyboard la tabla de teclas . buena suerte
Sep 21, 2009 | E-Machines eMachines Desktop PC
HP Compaq Presario V2000 Notebook Logo
158 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
