Question about HP PhotoSmart C4180 All-in-One Color InkJet Photo Printer
Printer jam says carriage jam. there is no paper jammed but printer continues to show that  there  is a jam. i followed instructions to open back door, unplug power , even reset but to no avail? any othe hints
  • 102 Answers
Uninstall the printer and reinstall.
Posted on Oct 31, 2008
Carriage jam
cannot print, msg shows Error carriage jam, Open door, clear carriage jam, and then press o.k. to continue.
paper has been cleared , opened door and even took off back compartment
Dec 22, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Tip
HP Inkjet Printers - Fixing Paper Path Issues: Paper Jam, Carriage Jam, and...
For a printer to work, the paper has to move through the printer. The route that paper follows through the printer is called the paper path. If the paper doesn't pick up (no pick) or something interferes with the paper path, nothing prints. If the paper is stuck in the path, you have a paper jam. Sometimes jammed paper in the printer can lead to the device that carries your ink cartridges back and forth in your printer to get stuck (carriage jam) as well. Sometimes the carriage can stop moving for other reasons.
The videos in the following playlists were created to help resolve these paper path issues. These videos are not short or entertaining but they are complete. They repeat steps (test print) so even novice users can follow these without having to refer back to instructions earlier in the video. The solutions in these videos are what works to solve paper path issues most of the time. Follow the steps completely. Sometimes people shortcut some of the solutions. Avoid shortcuts for accurate troubleshooting.
The steps for resolving paper path issues are specific to your printer. These playlists have videos for about many different models. We will continue adding to the collection or updating the videos when we find new ways to resolve these issues. The title and description of the videos explain what models the videos apply to.
Some of the videos end with a step that explains that the printer needs to be serviced. If your printer is still in warranty and you get to that step, contact HP for help. If your printer is out of warranty, open a new post in this forum and see if others have a non-conventional solution that will help. Also, Google is your friend offering non-HP out of warranty solutions for servicing/fixing a broken printer.
Fixing Paper Jams on HP YouTube
Fixing Carriage Jam YouTube
Fixing Paper Pick Up Issues YouTube
on Dec 04, 2014 | HP Office Equipment & Supplies
I have a Epson stylus CX9400fax a piece of paper is jammed way inside the machine, I can't even see it to try and get it out! I've tried turing the machine on/off numerous time (still not expelling the...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
Jun 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Continue to get clear carriage jam after opening door and clearing or moving the carriage in hp 4215xi
Click here for instructions on resolving carriage jams on the 4215xi. If you successfully complete these instructions and still have carriage jams, your printer likely needs service.
I am an HP employee. I do not represent HP on this site.
May 26, 2010 | HP OfficeJet 4215 All-In-One InkJet...
Stylus CX9400 Photo Printer: paper jammed inside printer...
May 18, 2010 | Epson Stylus CX9400 Photo Printer
Carriage jam
You could try clearing the jam and then removing power from the printer altogether to re-initialize the printer. However, if that fails either the printer diagnostics chip has gone awry or you have a virus.
Oct 28, 2009 | HP Photosmart 4180 All-in-One Printer
Kodak All-in-one Printer has Paper Jam problem
Go to kodak.com/go/itg and follow the step by step troubleshooting. If you still get the same error,Time to contact Kodak at 1800 421 6699 and Your printer will be replaced free of cost.
Sep 15, 2009 | Kodak ESP 5 Printer
My printer made a weird noise and now says "Open door Clear carriage jam and then press Enter". How do I clear a carriage jam? I have opened the top cover and usually the print cartridges move to the...
Issue The error ' Open Door, Clear Carriage Jam, and then Press Enter ' displays on the product. The following symptoms might also accompany this error:
* The product will not print. * Printing stops unexpectedly. * The carriage does not move.
Try the following solutions in the order presented to resolve the issue. When one of the solutions resolves the issue, there is no need to continue troubleshooting. Solution one: Turn the All-in-One off and on again
1. Press the Power button ( ) to turn off the product. 2. Press the Power button ( ) to turn the product on again.
* If these steps resolved the issue , you do not need to continue troubleshooting. * If the issue persists , continue to the next solution.
Solution two: Clear any paper jam A carriage jam might follow a paper jam. Follow these steps to check for and remove any jammed paper. Step one: Check for and remove any loose paper from the input tray Remove any loose paper from the input tray, the output tray, and the automatic document feeder (ADF). CAUTION: Do not remove jammed paper at this stage. Step two: Clear a paper jam from the rear access door WARNING: Always clear paper jams through the back door if possible. To avoid tearing the paper and damaging the print mechanism, pull paper from the printer slowly and gently. Avoid touching the internal components of the printer.
1. Disconnect the power cord from the back of the printer. 2. Remove the back door and remove as much jammed paper as possible.
3.Replace the back door and open the carriage access door. If there is paper visible that cannot be removed through the back door, gently pull it out from the front.
4. Reconnect the power cord and close the printer.
Solution three: Make sure that the carriage moves freely
1. With the product turned on, open the cartridge access door. The carriage might try to move into the access area. If so, allow it to move to that position. 2. Without turning off the product, unplug the power cord from the back of the product. WARNING: You must disconnect the power cord to move parts by hand without the risk of an electrical shock. 3. Look in through either the cartridge access door or the output paper tray to make sure that the cartridges are secure in the carriage and not loose. Also, make sure that there are no obstructions under or around the carriage to block it from moving. 4. Make sure the carriage can move freely across the width of the product by gently pushing the carriage to the left and then to the right. Clear any obstructions found. You might have to reach through the output paper tray to access the carriage. 5. Close the cartridge access door and reconnect the power cord to the product. 6. Press the Power button ( ) to turn on the product.
Solution four: Remove and reinsert the print cartridges Incorrect installation of the print cartridges can cause the product to show a false carriage jam. Follow these steps to remove, and then reinstall the print cartridges. Step one: Remove the print cartridges
1. Press the Power button ( ) to turn off the product. 2. Open the front of the product to access the carriage. The carriage moves to the center of the product.
3. Unlatch the two print cartridge latches, and then raise the latches. 4. Remove the print cartridges.
Step two: Reinsert the print cartridges
1. One at a time, hold a print cartridge with the printed label up, and then slide the print cartridge into its slot. Repeat this step for the other print cartridge.
# NOTE: Insert the black print cartridge into the slot with the gray latch, and insert the color cartridge into the slot with the blue latch. # Grasp the end of the latch on the cartridge slot with your thumb, and then pull the end of the latch toward you. While holding the latch, press down on the top of the latch until it stops, and then release the end of the latch so that it catches under the tabs. CAUTION: To avoid damaging the product, do not force the latches into place.
3. Close the product cover. A message displays on the control panel to align the print cartridges. 4. Press the Enter button to begin the cartridge alignment. Two pages print. Follow the instructions printed on the second page to complete the alignment. 5. Try the print job again.
Jul 08, 2009 | HP PSC 2175 All-In-One InkJet Printer
Carriage jam on hp photosmart printer
The print carriage may get stuck on either side or in the middle of the printer. The Carriage Jam: Open Door, clear carriage jam, and then press OK to continue error message may display on the front panel of the all-in-one.
Solution
The print carriage is the device which contains the print head and moves left to right during printing.
Figure 1: Carriage Assembly
To resolve this issue, follow the steps below in the order presented.
Step one: Print a Self Test
Follow the steps below:
1. Press the Setup button.
2. Select Print Report and press OK .
3. The self-test page should print. If it prints a test page, there is no need to follow the remaining steps, as the error message may be false. Make sure the printer now prints from the computer (if installed on one). If it does not print, proceed to the step two.
Step two: Clear the paper path
Follow the steps below to clear the printer of any jammed paper and reset the printer.
1. Leave the printer on and then disconnect the power cable and the USB or Ethernet cable from the back of the printer. Do not reconnect them until instructed to later.
NOTE: Make sure the printer is on before disconnecting the power cord. Failure to disconnect the power cord from the rear of the unit can cause damage when removing jammed paper.
2. Open the top access door.
Figure 2: Opening the top access door
3. Make note of where the carriage is stuck and look for jammed paper. A paper jam can cause the error message and the carriage stall. Some paper may be jammed in different locations than those shown in the photos below.
Figure 3: Paper jammed on the left side
Figure 4: Top view of paper jammed on the left side
Figure 5: Paper jammed on the right side
Figure 6: Top view of paper jammed on the right side
NOTE: Do not use any tools or other devices to remove jammed paper. Always use caution when removing jammed paper from inside the unit.
If the carriage is stuck on the right side:
a. Check for any paper or object that may be restricting the carriage.
b. Move carriage all the way to the left side.
c. Check the paper path all the way to the right side and remove any paper still in the printer.
If the carriage is stuck on the left side:
d. Check for any paper or object that may be restricting the carriage.
e. Move carriage all the way to the right side.
f. Check the paper path all the way to the left side and remove any paper still in the printer.
If the carriage is stuck in the middle:
g. Check for any paper or object that may be restricting the carriage.
h. Move carriage all the way to the left side.
i. Check the paper path all the way to the right side and remove any paper still in the printer.
j. Move carriage all the way to the right side.
k. Check the paper path all the way to the left side and remove any paper still in the printer.
4. Remove the rear access door or duplexer (if installed) from the back of the printer.
5. Check for and remove any paper still in the printer.
6. Replace the rear access door, and close the top access door.
7. Reconnect only the power cable. If the printer does not automatically turn on, press the Power button.
NOTE: The printer may go through a warm-up period of up to two minutes. Lights may flash and the carriage may move. Wait until this warm-up period is complete before going to the next step.
8. If the Power light is on steady, print a self-test page as done in Step one.
If the Power light is not on steady and the carriage is still in a stalled position, proceed to the next step.
Step three: Plug the printer directly into a wall outlet
Verify that the printer is properly connected to a suitable power source by following the instructions below.
1. Verify that the computer and the printer have a three-prong power plug.
2. Remove the printer cable from any power strips or surge suppressors, and plug it directly into a grounded (three-prong) wall outlet.
3. Try the print job again to see if this step resolved the issue.
NOTE: If the printer prints when plugged directly into a wall outlet while disconnected from any power strips or surge suppressors, the power strip or surge suppressor may not be allowing sufficient voltage to reach the product.
4. If this did not resolve the issue, proceed to the next step.
Step four: Service the product
If you have completed all of the steps listed above and are still experiencing a problem, service your product.hope this helps
Jan 05, 2009 | HP Office Equipment & Supplies
HP PhotoSmart C4180 All-in-One Color InkJet Photo Printer Logo
101 people viewed this question
Seeker5211
Seeker5211
