Question about TechnoMarine Watches
Technomarine original limited pink croc watch chrono stopped working... second hand fell off and is loose inside the casing. where do i send for repair???? or is it not worth fixing and should i purchase another one instead??
  • 109 Answers
You can take it to a reputable watchmaker (NOT a jeweler) and they should have no problem helping you with this problem. It might be that your watch isn't working because the second hand is stopping it from running. Have them CHECK your battery (opposed to just changing the battery) I bet the second hand is the reason your watch isn't working. If you have problems findind help PLEASE let me know, and I will be gald to assist you fher!
Posted on Sep 15, 2008
  • Jason Clark
    Jason Clark Nov 16, 2013
    Do you know where I can purchase this oil separately? I have a Sinn diver.
Second hand quits working (the small second hand)
the chrono second hand only works for one hour then stops,it's only used for timing purposes, see instructions on the link below ..
Apr 07, 2013 | Watches
Please clarify use of the 3 smaller dials and how the hands to each are set and reset
The small bottom dial is seconds counter and there is no option to set or reset it as it is part of the main gear train - it just counts the seconds. Top right dial is 1/10 seconds counter and runs only when the chronograph function is engaged. One full circle indicates 1 second. Top left dial is 30 minutes counter and runs only when the chronograph function is engaged. One full circle indicates 30 minutes, two circles = 1 hour. The big centre seconds hand is actually Chronograph hand and runs only when the chrono function is engaged. So, the chronograph hand and two top dials works all together when chrono function is engaged. To start chrono: push upper button once. To stop chrono: push upper button again (once). To return all hands to zero: push lower button once. There is another option: if you already stopped chrono by pushing upper button, but want to continue counting without returning hands to zero, push the upper button once more and the counting will start from the point where it stopped. You can repeat this as many as you wish - it will count on and on, till you will stop it and reset to zero. Fine tuning of chrono hands can be made by pulling the crown half way out and while leaving in this position pushing and holding one of the push buttons (which one - depends on movement caliber). Watch has an tachymeter function as well (big inner ring). Learn how to use it by browsing through my Tips and Tricks- it is explained there. Rate me, please.
Feb 28, 2011 | Calvin Klein K7547107 Celerity Watch for...
Brand new technomarine watch chronograph csx wont work? do i need to dosomethin to start it??
Change battery. Watch can be brand new, but battery is fitted when watch left production line.
Nov 05, 2010 | TechnoMarine Cruise Watch
Need to adjust zero position on a chronograph watch for second hand and minute hand
mcdevito75 here, Just a guess but here goes, start the chrono, now stop the chrono, the button you used to stop the chrono, press it again to retun to zero. Hope this helps.
Jul 18, 2010 | Watches
How to set up time on TAG HEUER SLR CHRONOGRAPH ? what are the functions of the 2 boutons and 2 crowns ?
The crown at 3 o'clock is used to set the time and change modes. The crown at 9 o'clock is used to rotate the flange at the edge of the dial.
The A button at approximately 2 o'clock starts and stops the chronograph function. The B button at approximately 4 o'clock resets the chronograph.
Lap Timer: When the watch is displaying normal time, press the right side crown to switch to chrono mode (the hour hand will indicate CHRONO). This watch measures lap times, press A to start timing the first lap. Press A again to stop the first lap and automatically start timing the second lap (the hour hand will move to indicate you're on the second lap), and so on. You can measure up to 20 laps this way. When you're fininshed timing laps, press the right side crown to see the best lap time. To reset the lap timer, hold down B for 2 seconds. To switch out of chrono and see the normal time, just press the right side crown in.
Chronongraph: To time an interval that is not a lap, just follow the above instructions, but instead of pressing A to stop the first lap, press B and the watch will show the elapsed time to the nearest 1/100th of a second. Hold B to reset.
Crown at 9 o'clock: This crown rotates the inner flange at the edge of the dial and is used to measure total race time (i.e. the total of all the laps). Simply rotate the crown until the the little start trinagle on the flange is aligned with the minute hand. This way, the total elapsed time can be read at any time, similarly to how a rotating bezel works.
To set the time: Ensure the watch is not in CHRONO mode, if so, press the right side crown in. At this time pull the right side crown out until you feel a click.The position the second hand moves to indicates what is currently being set. If the second hand is at 9 o'clock, you are setting am hours, press A repeatedly to set am hours. Then press B and the second hand will move to 6 o'clock, pressing A repeatedly will set the minutes. So on for year (11 o'clock), month (12 o'clock), and day (1 o'clock).
Feb 25, 2009 | Tag Heuer SLR Mercedes Benz Limited...
How to change the strap of leather to the gel strap technomarine
What is the reference of the watch? On the Cruise collection, the process is very simple: 1.      (To remove band) Squeeze the easy release spring bar to one side until it detaches from the watch case completely, do the same for both bands.
2.      (To attach new band) Take the straps that you want to put on and squeeze the easy release spring bar with your (nail or screwdriver) and insert into little groove, it should snap right into place
3.      Do the same for other band
If you need more information, please contact us customerserviceus@technomarine.com
Feb 13, 2009 | TechnoMarine Red SquareRSQG19
My watch is still working but the seconds hand has stopped
will just go to a technomarine service center to have my watches fixed.....
Sep 26, 2008 | TechnoMarine DTC55C (Size: Unisex Adult)...
Luminox 8152 chrono
If you have your instruction manual it should tell you how to reset the chrono. i have the Luminox 8352 and it says to pull the crown out to the 3rd position. then press and hold both the start/stop and lap/reset buttons for a couple of seconds. you'll see the second hand rotate, then you can single click the start/stop button to manually move the second hand 1 second, or you can hold it and it will continue move for a longer period until time desired. if you need to adjust the other chrono hands, click the lap/reset button and then you can click the start/stop button again. repeat for the minute/hour chrono hand. when you're finished push the crown back in. it might work even though it's a different model, worth a shot? hope that helps. these are really great watches.
Jan 02, 2008 | Luminox Field 821 wristwatch
The watch stops instead of the chrono
On this type of watch the second should not be working unless you are in the chrono mode. The lower dial should be the only indication of the seconds when not in chrono mode. You probably need to have the chrono reset and shown how the functions work. Try a Fossil location they will be able to tell you how to work this watch. It does not sound like this is a major problem.
Dec 03, 2006 | Fossil FS3105 Wrist Watch
Watches Logo
271 people viewed this question
Top TechnoMarine Watches Experts
Ansel Alberto
Ansel Alberto
Stan Ford
Are you a TechnoMarine Watch Expert? Answer questions, earn points and help others
