Question about HP Color LaserJet 2600n Printer
Grey background over entire page.
I get a light grey background on all pages when printing from our 2600n. And recently it also started leaving a 3" blue streak down the middle of the page.
On July 28th trina5901 posted a similar problem, with the solution of not printing labels. I do not print labels. This happens on regular paper - every single page, every single time.
  • 2 more comments
  • rlazy Sep 17, 2008
    Greetings!
    We did recently change the cartridges and they are remanufactured. And the problem did start happening after we installed these, but not right away.
    I am wondering (and now hoping since I've ordered a replacement) if the problem is with the electrostatic transfer belt. We noticed that it looked "dusty" when the problem was only with the grey background on the white paper, but now there is also a large cyan swath down the middle of it that is transferring onto the paper as well.
    If this does not solve the problem, we'll try new original cartidges. Any other suggestions and thoughts are more than welcome!
  • shiloh258 Sep 18, 2008
    I too have the same problem with a gray background covering my entire pages when I print. Lately, I have noticed that some blackish-gray lines appear on the left side of each page that I print. This printer started out doing fine, but we have been ordering non-HP brand cartridges lately. I am very dissatisfied with this printer at this time.
  • rlazy Sep 19, 2008
    I replaced all the toner cartridges, but with remanufactured ones because that's what was on hand. Then I got very bright magenta covering everything! I put the old magenta back in and have a slight background tinge. No more blue streak though.
    I think once I get original hp toner cartridges and replace the remanufactured that the problem will be solved.
    Seems like a lot of problems get blamed on the printer when they are caused by remanufactured cartridges. It will be only originals for me from now on!
    Thanks for the helpful input.
  • PrintDocta May 11, 2010
    Are the cartridges recently changed ?
    Are they originals, or remanufactured (these cartridges are not easy to get RIGHT when remanufactured, and there are so-called remanufacturers that just re-fill, sometimes not even emptying the wast toner (and it's a very small wast toner hopper in these !
    Both faults could be cartridge related.
    Can you borrow a black and or cyan cartridge from anyone to try - see if the problem remains with these - if not that's your answer
If toner is getting onto the transfer belt, it can only get there by either being put there intentionally, or leaking.
Failure of Transfer Belt is normally degraded print quality - usually poor density, or a failure of the support behind the belt (usually puncturing the belt), and scoring a drum.
Posted on Sep 18, 2008
Printer has light grey background after printing
Hi Mel:
Just a thought, is there a "greyscale" setting?
When I try to print I have the choice of Black & White, colour, and greyscale.
Hope this helps.
Cheers.
Jan 26, 2016 | Brother MFC-7440N Multifunction Laser...
Whatever I print looks "dirty",
If the cartridges are not HP brand, that may be the problem.
Try to figure out exactly what color the "grey" background color is.
If it is truly grey, the black cartridge might be the problem.
You can also try a different type of paper.
Some paper may respond to the printing process differently than others.
If you find that the background is a red, the scanner will have to be removed and cleaned.
These models have a tendency to collect red (magenta) toner on the scanner assembly lenses.
Mar 30, 2011 | HP Color LaserJet 2600n Printer
I'm printing on 110 lb card stock and the toner gets crispy..and actually flakes off on the edges and sometimes leaves smears and clumps of black or burnt toner on the paper. It prints fine on 20 lb paper...
could be the fuser but there is a setting for heavy paper or card stock which will slow it down and increase the heat. depends on your model as to where this can be changed.
Jul 27, 2017 | HP Color LaserJet 2600n Printer
HP 2600 is printing with a grey background. I have done several recalibrations and cleaned it but it does not fix the problem.
same as me, I got reduce this effect printing in normal paper as if i where printing transparency paper. The background is lighter now, but still appears.
The other thing I test, printing a blank page it was that with a glosy photo paper with the gloss side to the back i dont get any background. So i suspect it has to do with the tansfer belt ETB rollers.
Nov 02, 2010 | HP Color LaserJet 2600n Printer
HP 2600n grey background
Most Original cartridges are starter cartridges that hold only 1/3-3/4 ink. Drum maybe defective, and this usually causes the grey or black in your printing. Cartridges may need replacement along with the drum. Hopefully this helps
Aug 13, 2009 | HP Color LaserJet 2600n Printer
Kyocera FS-C5015N colour laser printer. -printing grey backgound
it seems very important to shake the toner before using your printer.
it is not too late
remove all toners and shake them well
you will find after a short time that the grey background goes away
Jul 09, 2009 | Kyocera Office Equipment & Supplies
Greyish marbeling on printed page & yellow wash allover page.
Sounds like you're probably running compatible cartridges. I sell a fair number of these cartridges to my customers, and it took a while to find a brand that actually worked. If you're seeing toner all over the place, the cartridges are most definitely the problem.
May 18, 2009 | HP Color LaserJet 2600n Printer
HP Laser Jet 4L Printer Model #C2003
Try lowering the toner density using the printing software or the printer menu.
Feb 03, 2008 | HP LaserJet 4L Printer
Grey shades coming all over the page as well in top back side of paper.
The Developer unit needs to be replaced. It gives background over entire page. If the printer is under 3 years old and is original unit (developer unit) you can get a new one free from Kyocera. Very good warr. from them. Phone number is 1 800438 6482 prompt 2 ; # for the part DV-62. Have your serial # and a status page with you. I work on Kyocera FS printers. Good luck. Russ
Dec 31, 2007 | Kyocera Mita FS 3800 Laser Printer
HP Color LaserJet 2600n Printer Logo
1,314 people viewed this question
Ben Johnson
