Question about Hotpoint WMA64 Front Load Washer
Replace belt Help how do I replace the belt on wma64 Thanx Phil
  • 85 Answers
Remove lid UN PLUG MACHINE FROM WALL SOCKET Undo motor bollts so it can be moved towards drum, GET OLD BELT AND LOWER IN YOUR HAND TOWARDS DRUM THEM MOVE BACKWARDS TILL CLEAR OF DRUM PULLEY ,get new belt and lower so it goes over rear of drum pulley (big wheel)make sure nothing is in drum,put one bolt of motor in loosely and roll belt over motor pulley wheel slowly forcing towards you if working from front a bit until ribs on belt are in grooves on both pulley wheels,Tighten up all motor bolts job done test it
Posted on Jan 18, 2009
2 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: replace belt wma64
Remove top cover, tilt m/c towards you, this gives you more space to work in, and slip belt over motor pulley first, then gradually ease belt over drum pulley turning the drum with the belt,until it is on.
Keep your fingers from getting trapped as the belt is very tight
Posted on Nov 25, 2008
My hotpoint washing machine wma64 will not spin
Dear Blaze,
Here is a link for a service manual Hotpoint WMA64 Installation And User Instructions Manual
The drum motor, its brushes, the belt, or idler arm roller, and the drum roller bearings can all be suspect. Here is a link that supports the statement Hotpoint Ultima Extra Wma64 Drum Not Turning E32 Fault Code Hotpoint...
Here is some conversation not relevant to your statement but maybe associated later on Faulty Hotpoint WMA64 DIYnot com DIY and Home Improvement .
I suggest when it is repaired to do a service wash to clear the drum of buildup.
Fare. Well.
Dec 28, 2014 | Hotpoint Washing Machines
Do you have to take the motor out to fit new brushes on a hotpoint wma64
Remove lower rear panel of washer.
Remove drum drive belt.
Unplug lead to motor, remove earth wire.to motor.
Locate and undo 2 screws securing motor to drum chassis.
Lever motor backwards to remove from mountings, keeping hold of the motor so it does not drop.
Remove old carbons at opp end to motor pulley.
Mar 13, 2010 | Hotpoint WMA64 Front Load Washer
Hotpoint washing machine barrel not turning all other functions OK. Motor, belt drive and bushes look ok new curcuit board replaced any Ideas? Model wma64
could be motor not rotating under pressure. When you say brushes have you removed them from motor to check them, also check they slide in and out thier holders ok, as they may be sticking
Feb 11, 2010 | Hotpoint WMA64 Front Load Washer
Hotpoint wma64, How to get drum out of its caseing ---unscrew?? knock out with hammer? thanks to anyone who cane help.
you need to remove the tank assembly from the cabinet,you will then find approx 15 torx headed screws around the middle of the tank assembly,removed these and the outer tank will then split into two halfs,remove the pully motor and belt,then knock out the drum with a copper mallet.
Jul 05, 2009 | Hotpoint WMA64 Front Load Washer
Installing the belt around the dryer drum and pulleys. I have a broken belt and a loose pulley at the bottom of the dryer. How to I get the pulley on? Where does the pulley attach to create the proper...
you will have to take the drum out to see where the tentioner was inserted , it is in line with the motor pulley, should be a couple holes it fits into.
putting the belt on is easy , with the lined side of the belt down on the drum take the slack at the bottom with a finger holding the belt , move the belt toward the tentioner until it touches the tentioner pulley
then with your other hand help bend the tentioner pulley with the belt on it until you can touch the motor pulley with that finger , slide it off your finger onto the motor pulley and the belt is on.
let me know if you have any questions.
Phil
Apr 14, 2009 | Dryers
Will not spin.
could be a couple of causes.First take off panel at back of machine and check that belt is in place.
Has it been noisy on spin lately?
Jan 29, 2009 | Hotpoint WMA64 Front Load Washer
Replace belt wma64
Sep 15, 2008 | Hotpoint WMA64 Front Load Washer
Hotpoint WMA64 Front Load Washer Logo
128 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
