Question about Robot Coupe Blixer BX6 Food Processor
Makes humming sound motor will not spin
Motor makes humming sound will not spin i put in new motor
    Scholar:
  • 81 Answers
Did you replace the start capacitor or start relay first ? This is the most common problem & a hell of alot cheaper than a new motor. Did you replace the motor shaft seal (around the shaft on top of the unit ? if not you will be replacing the motor sooner than you need to because the acids from veggies eat these things up & is the main reason why the motors fail, next in line is overloading or forcing product.
Posted on Jul 25, 2009
Motor humming but drive shaft not moving
I would suspect either the starting capacitor on the motor or worst case the motor itself. The capacitors are a fairly common item to fail while the motors are uncommon. Expect a new motor to be extremely expensive.
Jan 24, 2016 | Magimix 3200 Food Processor
How do I fix my Kitchenaid food processor? Motor hums but center shaft is stuck and won't turn.
Hi Eric, you are going to have to get the motor out and yes it will be because of the spilled liquid fusing/rusting the motor armature shaft into the bronze bush. Those motors are very expensive so worth a go to save it. You will have to get the plastic sleeve off that shaft first before you can get the motor out. Removal will destroy the sleeve. I drill a hole through the top of the sleeve, side to side leaving about 5mm of meat at the top. I shackle a chain through it and attach it to my bench leg and then accelerate the whole motor unit away in a straight line. The shaft needs to be pointing at the attachment point on the bench or it can slip from your hands creating more grief. It will only take 1 to 3 pulls, 1st one doesn't work do it harder, same with second pull and harder for the 3rd. The chain needs to have welded links or the chain will break. That is far the easiest removal method I have found, other methods could involve hacksawing it down one side being careful not to damage the metal shaft or melting a line down 1 side to split it open with a soldering iron. Once that is off then remove base, detach motor wires from pcb and remove the screws under the plastic caps on top of the top housing. Then it will be working away with levers and a spanner on the shaft and CRC, sweat and time. If you strike trouble after that email me
screaming_skull@hotmail.com Cheers Ross
Apr 03, 2015 | KitchenAid KFP600 Ultra Power 11 Cups Food...
My food processor blade keeps popping up (loose) when I put food into it.
You will probably need to replace the sleeve on the motor shaft and the blade. If overloaded the shaft can spin inside the blade which wrecks the connection between them. Replacing both together is the correct solution.
May 16, 2014 | KitchenAid Chefs Chopper KFC3100 3 Cups...
Kenmore garbage dispsal that made humming noise for like 3 seconds then completly shut down. it's not the power. could the motor be burned out? i already checked the wiring.
Hi there: hate to say but it sounds like the Garb D.'s motor has failed. Perhaps due to a jam up in the blades. The motor will cook before the circuit breaker if the breaker it is on is greater than 15amp. Solution... Turn the power off and try to turn the grinding impeller blades.. If they spin freely on first attempt, which I doubt they will, then the motor is K-put. Hopefully it has a built in thermal trip and will reset itself. But while you have the power is off, clean it out. If you do that and it hums only, you will need to replace motor. sorry
ash
Sep 24, 2010 | Kenmore Food Processors
I plug my cuisinart and it will not start. It worked the last time I used.
Put the work bowl, lid, and pusher on one piece at a time - handle of work bowl faces the front of the food processor, hollow feed tube faces the back, and the sliding lock switch on pusher sleeve faces the front. Should turn on.
If it doesn't, test the motor - remove the work bowl and other parts completely. Plug the base in and turn it on, and use a pen to push in the dark grey or black button on top of the base - if it spins, the motor is still good - you may just need a replacement part. If it doesn't make a sound, it needs to be sent in to Cuisinart for repair.
Mar 28, 2009 | Cuisinart DFP-11 Deluxe Food Processor
Hello
Somehoe the blade inside the jar ahs come loose, look on top of the blade you should see a nut if not you should see threads if you see threads then you have lost the nut.
Feb 26, 2009 | Wolfgang Puck BFPR0035CF Food Processor
Motor fails to operate - very hit and miss
Make sure you are using the dough blade for dough instead of the regular blade - dough will cause the regular blade/assembly to gum up. This is actually a VERY high quality unit w/ a 20-year motor warranty. I would see if you get better results with the dough blade. Don't give up on it yet.
Dec 14, 2008 | Cuisinart Limited Edition Metal MP14 Food...
My brand new Cuisinart 14 cup food processor won't turn on. All the components are locked in place and it's plugged in. Help
First, do a motor test by removing the work bowl completely and using a pen to press in the grey button on top of the base (with the food processor turned on of course), toward the back. If the processor spins, the motor is still good. At that point, I would inspect the work bowl pieces, lid, pusher assembly, etc for cracks/damage. If all appears well, insert ALL the pieces back into place and try again. If even one piece is out of place, the processor will not spin.
If it no longer spins, the motor has a problem.
-Tha Mp3 Doctor
Nov 23, 2008 | Cuisinart DLC-5 Food Processor
Robot Coupe Blixer BX6 Food Processor Logo
694 people viewed this question
Top Robot Coupe Food Processors Experts
ray gallant
Tom Chichester
Are you a Robot Coupe Food Processor Expert? Answer questions, earn points and help others
