Tally T6218 Matrix Printer Logo
alabi aziz Posted on Sep 15, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Platen opeo error
My printercomplains of platen open even though you close the platen
Swarnava Palit
Level 2:
New Friend:
  • Expert 114 Answers
  • Posted on Jan 30, 2009
Swarnava Palit
Expert
Level 2:
New Friend:
Answers
114
Questions
0
Helped
63936
Points
187
CLEAN THE PLATEN SENSOR IF NOT SOLVED CHANGED THE PLATEN SENSOR.
How can I fix Riso HC5500 error code S03-201?
  • Code: S03
  • Description:
  • Belt platen lock
  • Causes:
  • The belt platen elevation mechanism cannot be set properly.
    200 S03 Transfer belt motor timeout The motor shaft encoder of the transfer belt motor does not attain the specified pulse count within the specified time. The required movement does not complete even when the transfer belt motor operates for the specified interval. 201 S03 Transfer belt unit sensor error The three sensors that determine the position of the belt platen produced an abnormal detection result. 231 S03 Belt platen operation error The upper limit position sensor fails to activate when the belt platen rises. 240 S03 Belt platen operation error The upper limit position sensor fails to deactivate when the belt platen lowers. 241 S03 Belt platen operation error The lower limit position sensor fails to activate when the belt platen lowers. 242 S03 Belt platen operation error The lower limit position sensor fails to deactivate when the belt platen rises. 243 S03 Belt platen operation error The vacuum positioning sensor fails to activate when the belt platen operates. 244 S03 Belt platen operation error The vacuum positioning sensor fails to deactivate when the belt platen operates.
  • Remedy:<>Reset power, or execute [Clear error] in Test mode. <>Some errors (such as PCB disconnection) may not be cleared by executing [Clear error]. <>Even if an S error occurs, it may be possible to continue operations using another unit. Therefore, certain error types require a specific reset procedure (described in Error Point).
Take it in for service, or replace all the sensors if you can find them for sale.
https://www.google.com/search?q=Riso+HC5500+error+code+S03-201
Mp c5502. Why does it keep displaying 'door open' even though it's closed?
Sometimes Door open error shows in printer even if it is closed .
Follow This steps to Fix Open Door Error Message:-
*Close the cartridge access door completely.
*Check the cartridge door for obstruction.
*Reset the Printer
*Restart the Print Spool Device.
*Restart the computer.Restart the Printer.And If you are using Brother Printer And You Encounter With Brother Printer In Error State Windows 10 Issue then Read The Blog I Am Mentioning above.
The fax is received by the other party but we receive an error code J72. There is no jam
Dear
If you are sending the fax using ADF, there may be the document jam, Open the ADF cover check the path for any foreign objects.
Also you can send from platen glass without document jam.
Also this may happen to the other end fax machine, better you do a test copy from ADF and Platen glass. and confirm your fax machine is ok.
Thanks.
1helpful
I changed the ink in my Lexmark 3400 printer and I keep getting an error message "cover open" and it's not open. I tried everything....unloading the software then reloading the software, shutting it off...
The printer displays a 'Cover open, please close cover' error message, even though the cover is closed.
This can happen if the lever on the cover open sensor is knocked off the switch assembly.
1helpful
057 close platen
Load the paper and close the forms thichness guide. If the error does not clear, power off and unplug the printerRemove the paper guide assy or pedistal top cover. Disconnect connector P107from controller PCB. Check continuity of platen interlock switch from P107 to switch. Replace the platen intetrlock switch if it fails continuity
057 close platen error message
Its located in the adjustment section of the platen control or in the platen itself.
Lexmark may still be supporting this model printer.
Canon Pixma iP1600 Printer problem
Hi there
You can try this it some times works.
Super Canon User's method of resetting IP1600
1.Press Resume button hold for 1 - 2 minutes (count to 1 to 15-16)
2.Open the cover right away
3.Release Both cartridges out and then put cartridges them back again
4.Close The Cover
5.Turn Off Then Turn On again.
You can download the Resetter tools program from my website.
Click Link = http://www.4all2sell.com/reset-tools/ip1600st-RESETTER-TOOLS.zip
1. Download software for Canon iP1200, iP1600, 2200 Printers.
2. Unzip downloaded file by etc
3. Run GeneralTool.exe
4. Select the connected USB port number from USB PORT
5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION
6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selected waste ink counter will be reset. MAIN resets the main waste ink counter, PLATEN resets the platen waste ink counter.
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters.
Free WinZip http://www.winzip.com/downwz.htm
Please call back to vote
All the best: Pineworks
2helpful
Mf6530 always says platen glass dirty but I've even cleaned both sides
Found the solution at http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=239&modelid=13170&kbpage=yes , then enter "clean platen glass" in the search window, and select item #1 "ERROR LCD: PLATEN GLASS DIRTY, CLEAN PLATEN GLASS ". This gives step-by-step instructions on how to clean the area dealing with the platen glass.
2helpful
Close platen signal
When you open and close the platen lever you will notice micro switch that should be engaged... When the lever is down to A - C. looks like this... only 2 other things it could be besides the switch... 152417-001.jpg&w=70&h=39 152417-001 P5000 Platen Interlock Switch
If anybody has been in the printer where PCBA's are, check the two cable connectors holders... seated good... worst case,it would be very rare if its CMX Board(main logic)...
Top Tally Office Equipment & Supplies Experts
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
