Question about Apple QuickTime
QuickTime Problem QuickTime isn't playing any movies, what can I do to fix this?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 11 Answers
Check that QuickTime is installed correctly, go to this page:
http://www.apple.com/quicktime/troubleshooting/
It will check your QuickTime installation.
Posted on Sep 16, 2008
3 Suggested Answers
evelasco
  • 52 Answers
SOURCE: QuickTime Flicker
Remove and re install the program.
Posted on Oct 06, 2008
SOURCE: QuickTime Troubleshoot
I am having a 'problem' installing iTunes v8 - the install seems to go ok until I get to the part of the program which invokes the Quicktime software upload (v7.5).
Although I don't get a 'controlled' Error message, I am advised that
"A newer version of Quicktime is installed on your computer - Quicktime needs to close" a message then appears telling me that iTunes install has failed as "iTunes needs QuickTime" - no **** sherlock!!
Try as I might I am unable to get past this problem - can anyone out there advise me ?
I have uninstalled until I am blue in the face using all teh standard solutions i.e Regedit, MSConfig, removed Temp Files in Docs & Settings etc etc. To my mind there is still part of the system that has nested a piece of Quicktime code that is screwing up the install.
This is doing my head in and I have 2 iPods that requirev v8 that I cannot use!!
Posted on Nov 10, 2008
The file format is not supported
Hi driddle00...
This information came from the Microsoft WebPage:
"Cannot play back the file. The format is not supported. This behavior occurs because PowerPoint can play back only QuickTime movies (.mov and .qt files) that use compression schemes with corresponding Media Control Interface (MCI)-compatible codecs.
A codec (compressor/decompressor) is an algorithm or scheme that is used to record digital video or audio. For example, when you transmit video over the Internet, the video must be compressed on the sending end and decompressed on the receiving end. A codec can be chosen based upon the user's audio or image quality and image size preferences.
When you read a QuickTime movie, a Video for Windows decompressor decompresses the QuickTime files. If the decompressor does not support the compression method used by the QuickTime movie, the decompressor cannot display the movie on the screen.
To work around this behavior, use one of the following methods. uparrow.gifBack to the top Method 1: Create a hyperlink to the .mov file loadTOCNode(2, 'workaround'); Create a hyperlink to the .mov file, and then let the QuickTime Player for Windows play the file instead. To do this, follow these steps:
  1. Select the object or text that you want to assign the hyperlink to.
  2. On the Insert menu, click Hyperlink.
  3. Under Link to, click Existing File or Web Page.
  4. Select the QuickTime movie that you want to play, and then click OK.
    Note Under Look in, click Current Folder to see a list of files, click Browsed Pages to see a list of recently viewed Web pages, or click Recent Files to see a list of recently used files.
During the slide show, click the linked object or text to play the movie. If a valid player is available, the player starts, and then the player plays the QuickTime movie. uparrow.gifBack to the top Method 2: Convert QuickTime movies to AVI format loadTOCNode(2, 'workaround'); Note In the following steps, you must use QuickTime 4.0 Pro. You cannot follow these steps with the basic version of QuickTime 4.0. The steps are the same for both Windows and Macintosh versions of QuickTime 4.0.
You can use other QuickTime editing programs instead of QuickTime 4.0 Pro. To do this, see the QuickTime documentation for the relevant steps.
To convert the QuickTime movies to AVI format, follow these steps:
  1. Start QuickTime Pro, and then open the file that you want to convert.
  2. On the File menu, click Export.
  3. Set the Export file type to Movie to AVI.
  4. Click Options, and then click Settings.
  5. In the Compressor group, click the list of compressors, and then select one from the previous list. Cinepak is a popular format. Select the format that you think works best with the movie.
  6. Make sure that you change the extension on the file name to .avi, and then click Save.
uparrow.gifBack to the top Method 3: Recompress the QuickTime movies with compatible codec loadTOCNode(2, 'workaround'); Note In the following steps, you must use QuickTime 4.0 Pro. You cannot follow these steps with the basic version of QuickTime 4.0. The steps are the same for both Windows and Macintosh versions of QuickTime 4.0.
To recompress the QuickTime movies with compatible codec, follow these steps:
  3. Set the Export file type to Movie to QuickTime Movie.
  6. Click Save.
uparrow.gifBack to the top Verify that QuickTime movies are compatibleYou can use Microsoft Media Player to... loadTOCNode(1, 'moreinformation'); Verify that QuickTime movies are compatible loadTOCNode(2, 'moreinformation'); You can use Microsoft Media Player to verify that a QuickTime movie is compatible with PowerPoint.
Note Microsoft Media Player (Mplayer.exe or Mplay32.exe) is a different program than Windows Media Player. Microsoft Media Player is included with various versions of the Windows operating systems, and is an MCI-compliant device. Windows Media Player, however, is a new technology that does not rely on MCI to play various forms of media. Windows Media Player can play a wider range of video and audio formats than Microsoft Media Player can play.
To determine the compatibility of the movie, follow these steps:
  1. Click Start, and then click Run.
  2. In the Open box, type the appropriate command for your operating system:
    • In Microsoft Windows 98 or Microsoft Windows Millennium Edition, type mplayer.exe, and then click OK.
    • In Microsoft Windows NT 4.0, Microsoft Windows 2000, or Microsoft Windows XP, type mplay32.exe, and then click OK.
    Microsoft Media Player starts.
  3. On the File menu, click Open.
  4. Select the QuickTime movie that you want to verify. Click Open.
If the QuickTime movie is compatible, Microsoft Media Player opens the movie. If Microsoft Media Player opens the movie, but PowerPoint does not, there may be a problem with PowerPoint or with the MCI settings. If Microsoft Media Player does not open the movie, and then you receive an error message in Media Player, the movie is not compatible and cannot be played in PowerPoint. You may be able to make the movie compatible by using one of the methods described in the WORKAROUND section of this article."
Sep 06, 2011 | Philips GOGEAR SA6045 MP3 Player
Tip
Mac MXF to MOV Converter-Convert MXF File to QuickTime MOV on Mac OS X
Best MXF to QuickTime MOV Converter on Mac OS X <br /><br />MXF is a "container" or "wrapper" format which supports a number of different streams of coded "essence", encoded with any of a variety of codecs, together with a metadata wrapper which describes the material contained within the MXF file. MXF has been designed to address a number of problems with non-professional formats. MXF file format is not compatible with many programs. So you may have problem to play, edit or use these format. So are Panasonic HVX200/HPX300 MXF files, P2 MXF files. <br /><br />Apple QuickTime movie is stored in the format of Apple QuickTime (.mov, .qt) which is a file format for storing and playing back movies with sound. Though developed and supported primarily by Apple Computer, the format of Apple QuickTime isn't limited to Macintosh operating systems. Apple QuickTime is also commonly used in Windows systems, and other types of computing platforms. In Windows, QuickTime movies usually appear with the .mov filename extension. <br /><img src="mxf-mov1.jpg" /> <br />With Aunsoft <b><a href="http://dts-ac3-converter.com/2011/07/mac-mxf-to-mov-converter-convert-mxf-file-to-quicktime-mov-on-mac-os-x/">Mac MXF Conversion</a></b>, we can convert mxf file to QuickTime MOV on Mac with best quality, fastest converting speed, excellent A/V sync and so on. And we also can use the Mac MXF File Converter to convert mxf file to friendly video formats just like mpg, wmv, mp4, mov, mpeg, dv, etc for playing on iPad, iPod, iPhone 4, iTunes, PSP, Apple TV, Android Phones, etc so that we can watch our favorite mxf conversion file everywhere. <br /><br />Follow the step to <b><a href="http://www.aunsoft.com/video-converter-mac/">convert MXF files to QuickTime MOV</a></b> on Mac now. <br /><br />Step1: Download and install the <b><a href="http://download.aunsoft.com/video_converter_mac/videoconvertermac_setup.zip">best Mac MXF File Converter</a></b>, add your MXF file by clicking "Add" in the File menu or in the main interface. <br /><br />Step2: In "Format" drop down list box, you may select output format. The software allows setting different output formats according to different files. For example, I just set the QuickTime MOV as output format of the MXF file. <br /><img src="convert-mxf-to-quicktime-mov.jpg" /> <br />Step3: Now let's select the output folder by clicking the "Output folder" icon. <br /><br />Step4: Finally, click "Convert" in the main interface. After a successful conversion, click "Open" to check the QuickTime MOV files. <br /><br />If you're interested in converting MXF files to QuickTime MOV on Mac without losing quality, please visit: <b><a href="http://www.aunsoft.com/mac_mxf_to_quick_time_mov_converter_convert_mxf_files_to_mov/">Best Mac MXF to QuickTime MOV Converter</a> ; <a href="http://www.aunsoft.com/convert_p2_mxf_to_quicktime_mov_for_fcp_on_mac/">Convert P2 MXF to QuickTime MOV for FCP</a> ; <a href="http://www.aunsoft.com/edit_mxf_in_avid_media_composer_convert_p2_mxf_to_wmv_for_avid/">Convert P2 MXF to WMV for Avid</a> ; <a href="http://www.aunsoft.com/edit_mxf_files_in_adobe_after_effects/">Edit MXF Files in Adobe After Effects</a></b> .
on Jul 13, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Tip
How to Convert DVD to QuickTime
QuickTime is an extensible proprietary multimedia framework developed by Apple Inc., capable of handling various formats of digital video, picture, sound, panoramic images, and interactivity. It is available for Mac OS classic (System 7 onwards), Mac OS X and Microsoft Windows operating systems.<br /> QuickTime is integrated with Mac OS X, but it was once an optional component at install for earlier versions of Mac OS. QuickTime for Microsoft Windows is downloadable, either as a standalone installation or bundled with iTunes.<br /> QuickTime is available free of charge for both Mac OS X and Windows operating systems. Some other free player applications that rely on the QuickTime framework provide features not available in the basic QuickTime Player. For example:<br /> &bull; iTunes can export audio in WAV, AIFF, MP3, AAC, and Apple Lossless.<br /> &bull; In Mac OS X, a simple AppleScript can be used to play a movie in full-screen mode. Since version 7.2 the QuickTime Player now also supports full-screen viewing in the non-pro version.<br /> Would you like to convert your favorite DVD movies to your QuickTime formats, either for backup or for playback in case of carelessness scratch? Do you want to play with QuickTime, or to put DVD movies to iTunes, iPod, iPhone, iPad? In such cases, you need to convert DVD to QuickTime movie files on Mac firstly. Now the following steps will show you how <a href="http://www.dvdtoitunes.net/dvdtoitunes-guide/convert-dvd-to-quicktime.html">convert DVD to QuickTime</a>.<br /> Step 1: Import DVD Movie.<br /> Click "File" in menu list or "Open DVD" button, you are allowed to load DVDs from DVD Rom/Folder (data DVD)/IFO/ISO files respectively. Batch conversion is supported here, so you can add several files to enjoy the fast conversion speed.<br /> <img src="dvd-video-converter-2.jpg" /><br /> Step 2: Choose Output Format.<br /> Go to the "Output" panel. Click the "Profile" drop-down list to choose the output format. To convert DVD to QuickTime (.MOV), choose "QuickTime Movie (*.mov)" if you want to convert DVD to video file for viewing on QuickTime player.<br /> Step 3: Start Converting DVD to QuickTime.<br /> After making all necessary settings, click the "Convert" button to start to convert DVD to QuickTime (.MOV). After choosing a profile, you can adjust parameter values in the "Settings" tab, such as "Bit Rate", "Sample Rate", "Duration", "Start time", etc.<br /> More Related Guides: <a href="http://www.dvdtoitunes.net/itunes-to-dvd.html">how to burn a dvd from itunes</a>, <a href="http://www.dvdtoitunes.net/videotoitunes.html">free youtube to itunes converter</a>, <a href="http://www.dvdtoitunes.net/download-free-video-to-itunes.html">free videos for ipod touch</a>.<br />
on May 31, 2011 | Computers & Internet
I have quicktime player and I can't see the movie (I can only hear the sound) that has vlc mov codec and saved in quicktime program
I strongly recommend using VLC for watching any type of video. Programs like Quicktime player, windows media player etc often need codecs to play certain video types and formats like avi, flv etc. As for quicktime player, you propably need to download the proper codec for your movie format type
Aug 01, 2011 | Computers & Internet
Trouble playing MPEG 4 file in quicktime
try donwloading a different player like k-pack codec its free go here http://www.free-codecs.com/download/K_Lite_Mega_Codec_Pack.htm
May 09, 2009 | Computers & Internet
Tip
Quicktime to Flash Mac OS X, convert Quicktime to Flash movie for web
The issue for Converting quicktime movies to flash or post quicktime on website seems trouble many mac users. When I surf the Internet, I found many problems about how to convert quicktime movies to Flash, as the following:
Questions about quicktime to Flash conversion:
1. Can anybody suggest a good Mac program for converting QT movies to flash? Any recommendations for Mac software to convert high quality video from Quicktime to Flash?
2. Trouble converting quicktime to flash:
I’m on a MAC and I’m trying to convert a quicktime movie to flash so that it is easily downloadable on our website for PC users. When I import the .mov into Flash it loses all audio. Does anyone know how to fix this? I’ve played around with setting on importing in Flash and I’ve played around with different exporting options from FCP. Any ideas would be welcome.
3. how do i convert quicktime movie to flash movie for web: I have small video clips in QuickTime format and I would like to convert them in Flash Media (.fla) so I can post them on the website for easier viewing for the visitors.
4. I would like to know what program, I can use to do this? Is there any free ones? I know you tube can do this but their logo is on there. I have macromedia Flash software but don’t know how to convert.
5. Does anyone know any good software to convert quicktime movies to flash media? I want to post some clips on a website.
Does you have the similar problem bothering you? I have a good recommendation to solve this problem—–Doremisoft Quicktime to Flash converter mac. No matter whether you need put Flash movies converted from Quicktime files, it will be your good choice.
Why? Some reasons to regard mac quicktime to flash converter as best mac software to convert quicktime movies to flash for website are listed here:
1.Encode Quicktime(MOV, QT) to FLV, SWF
2.Generate an HTLM page embeded flash video player with customized control bar
3.Add image, text, hyperlinks, special effect, loading to flash video
4.Powerful flash editing features: Cropping, Clipping and Merging.
5.Take slide to make a video playlist with sliding function.
6.Easy-to-use, just need several steps.
More…
Steps to convert Quicktime files to Flash FLV SWF:
Step1. Import Quicktime to Flash converter mac easily
Download and Install and Launch according to its wizard. Then hit “Add Files” button to load all quicktime files you want to convert into mac Flash converter.
Step2. Get Quicktime to Flash conversion started on mac
Then you can start Quicktime to Flash conversion by clicking “Start” button. The speed depends on the speed of your mac processor and the quantity of your converting files.
If you want to get more vivid output flash videos, there are 8 tips to use Quicktime to Flash mac converter.
on Jun 22, 2010 | Computers & Internet
Panasonic tz5 movie files will not play in Windows only Quicktime
If the movies are recorded as .avi, then you will have to use QuickTime. One way to avoid having to select QuickTime each time is to hold the SHIFT key, right click over the video file and select "Open With". Now select QuickTime (otherwise select other programs) and scroll to QuickTime from the list and you should see a check box at the end of the list and make sure its checked. Here is a screen shot:
Now click OK and the next time you open the camera movie files, it will automatically open in QuickTime.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Sep 28, 2008 | Cameras
Sep 15, 2008 | Apple QuickTime
Cannot view the movies I made on my camera and downloaded to my Vista PC
I assume you can view them in you camera, right? If not, the following solution will not help.
The .MOV Apple QuickTime format Panasonic uses for its camera movie clips cause problem on with viewing, as seen from several other problem posts here and the net.
Some computer use a Win 32Bit operating system, other better ones use a Win 64. It is hard to believe QuickTime would let you load a 64bit version into a 32bit OS, or vice versa. But who knows. Rather double clicking on te file name itself, open QuickTime, then go to File Open and Browse to the file and select it that was. If this doesn't work, go to QuickTime website and try their User Forums first to ask a question or find a thread talking about movie files not playing. Else, CONTACT website and ask question. Post any solution here for readers.
Feb 12, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
QuickTime movie mode
The D-580 Zoom does play back sound in QuickTime® movie mode.
Sep 01, 2005 | Olympia OL-5805 Cordless Phone
Apple QuickTime Logo
82 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
