Question about Samsung DLP HL-P5663W 56" TV
JVC HDILA yellow hue in parts of screen
I have a 56 inch JVC HDILA rear projection screen and over the course of the last 6 months a yellowish hue, that started in the bottom left quadrant of the screen, is now in a rectangular ring around the screen about 6 inches in from the edge, but still most prevelant in the bottom left. Anyone know what this is? Do I just have to replace the bulb or is it more of a problem?
SOURCE: Right 2 inches on edge of screen are darker than the rest of the screen
I have a 20 month old Samsung HLR5668WX/XAA that except for the left vertical 20% of the screen, the rest became very dark. I can make out the images behind it, but just barely. For the next few days, I turned off/on the set after a few minutes every time it happened and the picture came back to normal. Then eventually the problem became permanent. Thinking it was the lamp, I replaced it, but the problem still exists. In addition, for a few months, the set has been making an intermittent grinding noise that goes away when I turn off/on the set as above. Its frequency seems to be increasing. Does it sound like the color wheel is bad? The fan perhaps? Something much worse (crossing my fingers)? Please let me know. Thanx in advance. Tom
Posted on Jul 07, 2007
SOURCE: Samsung DLP HL-P5674W Screen is stretched at the top and bottom...
did you ever find out the problem , mine is doing the same thing,
please email highltv3@aol.com if you can help
thank you so much
debi
Posted on Mar 07, 2008
SOURCE: 32" HD flat screen (160 lbs) screen display became too wide
bottom left and top right corners, the color is off almost as if a magnent is near the screen
Posted on Jun 21, 2009
rhozel2010
  • 269 Answers
SOURCE: 50 inch DLP Samsung screen freezes turns off then kicks back on
check the color whell alignment on the service mode
Posted on Jul 31, 2009
SOURCE: My 56 inch Samsung DLP keeps shutting off. I have
Once before I had this same problem and FixYa gave me the solution. When you replace the lamp door, there is a switch inside so be sure the door is put in at an angle so to hold the switch up. It solved my problem after numerous repairmen missed it.
Posted on Sep 05, 2009
JVC HD 56FN97 No RED color
Does menu have any red? Yes = digital video bad; No is light engine bad.
Mar 31, 2014 | JVC Hd56fn97 56-inch 1080p Hdila Rear...
No sound or picture
u need a new lamp and housing u can get it off of ebay.com from $35 to $90
Aug 24, 2013 | JVC Hd56fn97 56-inch 1080p Hdila Rear...
Tv keeps shutting off
lamp might needs to be change if not check to see if cord is all the way in back of tv and wall
Apr 23, 2013 | JVC Hd56fn97 56-inch 1080p Hdila Rear...
Jvc hd56fn97 56-inch 1080p hdila rear projection tv with convergence problem, how do i fix this
That set cannot have a convergence problem as it has no convergence circuit, It is a DLP set with a lamp.
Dec 11, 2012 | JVC Hd56fn97 56-inch 1080p Hdila Rear...
JVC Hd56fn97 56-inch 1080p Hdila Rear Projection Tv with all blue color green
Talk to JVC as I have suggested and this is likely a known problem: loss of any color, picture upside down etc requires a upgrade to correct and I have seen about twenty sets with their name like this with this kind of problem.
Toshiba 65H80 has yellow hue.
Check you HD inputs or source. Sounds like the red stream is missing; maybe a loose cable.
Nov 17, 2008 | Toshiba 65H80 65" Rear Projection...
Gray spots on screen on a JVC HDILA model HD 56G 787
The HD-ila sets accumulate a lot of dust in the light engine. The worst offender is the little fold mirror just under the lens. I take my set apart about every 8 months or so to clean all the dust from the light tunnel and all lenses, mirrors, diffusers etc. The picture really regains it's pop when this is done. Unless you are a skilled technician though, I would recommend against attemptimg this procedure as you need to disconnect the individual color lcds. Check with a local service center to get it properly cleaned.
Oct 16, 2008 | JVC HD-56FN97 56" Television
Samsung DLP HL-P5663W 56" TV Logo
Henry  Thomas
Henry Thomas
