Question about Casio Watches
Setting analogic time for the Casio HD wristwatch-4-button
  • 109 Answers
You have to push the mode button untill you get to the "HS" mode.Then I don't remember which button it is , but one of the other buttons (excluding the light button) will make the hands start to move.The pain in the **** is having to hold the button for the hands to go all the way around to the time!!! If you still have problems PLEASE let me know , and I will be glad to assist you further.
Posted on Sep 15, 2008
How do I set G-Shock analog time?
"H-SET" is the "0" hands position.To do this right,go to manual (link below) by using the module nbr found on the back cover (4 digit code in a frame).
Timepieces Watches Manuals CASIO
Nov 26, 2013 | Casio Watches
How to set analog time for casio SGW 400 h please help
Analog time follows the digital time on Casio watches.If this is not happening,try the hands "set to 0" procedure using the manual.
Mar 31, 2013 | Casio Watches
The brand new Casio watch Module No. 2747 does not allow the analog time to be decreased! I've reset the digital time to the present time. When I try to reset the analog time (watch hands) I cannot turn...
Assuming all Casio models have the same mode of operation, try this:-
Press the mode button until you see "HS" on the display (hand setting) and then use the 2 and 4 o'clock buttons to adjest the hands.
If this does not work and you do not have the manual for your watch,you can get
instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
y
Dec 23, 2010 | Watches
I have a casio ediface 5033 80W-M10008 how do I set the analog time
Thank you for contacting FixYa.
To set the analog time, press the lower left button 6 times. Next, press and hold the upper left button until the digital time starts to blink. This indicates that you are in analog time setting mode.
Analog time adjustment is completed using the lower right button. Every time you press the button, the analog time will advance 20 seconds. If you need to make a big change to the analog time, press and hold the lower right button to make the hands move faster. Once the analog time is set, press the upper left button to exit the analog time setting mode.
Best regards. Jewel
Sep 15, 2010 | Casio Edifice EFA109-7AV Wrist Watch
How to set the hands to match the correct digital display on my Casio wave ceptor 2734 wva-104h watch
Setting Digital Time
  1. The digital timepiece on a watch is set using the function buttons on the outer part of the watch face. To set the digital time, press and hold the upper left button until the seconds starts blinking. Press the lower right button to reset the seconds to "00."
    Push the lower left button to move to the Daylight Savings Time portion of the watch. Use the lower right button to toggle between "On" and "OFF."
    Press the lower left button twice. The hours unit will start blinking. To advance the hour, press the lower right button repeatedly until the correct hour is displayed. If you need to move the hours unit backwards, press the middle right button until the correct hour is displayed. When the hour is set, press the lower left button to switch to minutes, and use the same commands to change the minutes unit.
    After the time is set, press the upper left button to exit the digital time setting function.
  2. Setting Analog Time
  3. You may find after setting the digital timepiece that the analog display does not match. When this occurs, you need to set the analog time. To set the analog time, press the lower left button 6 times. Next, press and hold the upper left button until the digital time starts to blink. This indicates that you are in analog time setting mode.
Aug 21, 2010 | Casio Watches
How do you set the alarm for the casio baby g wr-10 bar?
mcdevito75 here, Contact Casio for a new manual at, 800-706-2534 Optn. 2
Jul 12, 2010 | Casio Baby-G Wristwatch
Analog time setting
On the assumption that my Casio watch works the same as yours, press the mode button (lower left), until "HS"appears, then use the buttons on the right to advance or ****** the hands.
If this does not do the trick, then go to the Casio web site "casio.com" select "support"then "manuals"; accept terms and conditions and the select "watch manual archive"
Insert the required number off the back of your watch and download the instructions.
Jan 30, 2010 | Casio Fishing Gear Watch
Cannot set the analog time on the Casio 2747.
In timekeeping mode press bottom left button 6x to enter setting mode.
Then hold down top left button until digital time flashes, which indicates your in analog time setting mode. press bottom right button to set the time.
If you hold down bottom right, it will set time at a faster speed.
Hope this helps
May 25, 2009 | Casio AW80-7AV Wrist Watch
I cant set analogue time on casio hd wrist
Follow this link:
http://world.casio.com/wat/download/en/manual/
Rate, please.
Mar 30, 2009 | Casio WVA430A-1AV Wrist Watch
1. Press lower-left button to enter hand-setting mode (you will see a H-S appear in the LCD)
2. Hold the upper-left button until the LCD starts to flash
3. Press the lower-right button to advance the minute needle by 20 seconds. You can also hold for high speed advance.
4. If you need to advance the time by a long way, and don't want to hold down the lower-right button, then press both the right buttons at the same time and the time will advance automatically. Pressing any button will then cause the advance to stop.
6. Once you have set the time, press the upper-left button.
7. To return to time-keeping mode, press the lower-left button.
Bloody complicated, but easy when you get use to it. I travel quite a bit and this really pisses me off when I have to change the time, especially so when the needle can only move clockwise.
-Bala
Nov 06, 2007 | Casio WVA430A-1AV Wrist Watch
Watches Logo
279 people viewed this question
Top Casio Watches Experts
Jimmy Accardi
k24674
Are you a Casio Watch Expert? Answer questions, earn points and help others
