Question about AT&T Cell Phones
LG AT&T SKU 64675 Display
The display is a plain blue screen and the phone has limited functionality. It rang but I couldn't answer. I can hear the shutter sound when I take a picture and I can hear the "whoosh" when it powers on & off. I pulled the battery for several minutes and it made no difference. Any suggestions?
SOURCE: Display dies, although phone still functional
hi The thing with the battery it really worked .so if you have problems with the display just change the battery and your black dead display will turn in a nice working one .you should try it is easy and with results.good luck! cristina
Posted on May 15, 2007
mixmaster
  • 626 Answers
SOURCE: White screen on Motorola RAZR
I use to work for Cingular Wireless and this happened often. Try opening and closing the handset a little forcefully. It should re-seat the screen onto the contacts. If that doesnt help, have it replaced since its new. Best of Luck.
Posted on Sep 06, 2007
  • 12 Answers
SOURCE: no picture is displaying
First try to check by pressing the keypad and fix whrther phone is booted. Else we have to try by s/w or hardware like ( UI Module has to be checked. Regds Bejoy/senthil 9901816888/9945084338
Posted on Sep 22, 2007
  • 10 Answers
SOURCE: black screens razr v3
Hi, Same problem as others are having. Check the Sep 30th solution that I submitted regarding opening the phone and sqweezing just to the left of the camera lens between the vol up/down and the lens The ribbon cable comes loose in that area, this technique usually restores operation to normal. Good luck.
Posted on Sep 30, 2007
Guitarguy1
  • 4 Answers
I had this problem too. My razrs screen would just go white every 15 minutes maybe, and i would have to turn it off and back on.There was a white line at the bottom of the screen also, so i went to http://direct.motorola.com/hellomoto/motosupport/source/SoftwareUpdateSummary.asp?country=&language=&web_page_name=SUPPORT&strCarrierId=US%20Cellular&strPhone=V3c&strCable=Mini%20USB%20Data%20Cable and downloaded thee software update. after it was finished the white line went away the screen never went white and it fixed everything!
Posted on Oct 08, 2007
I dropped my LG GT350 phone, it can be switched on and fully function, but the touch screen display is not showing. It can still be pressed and a dim blue back-light is on but nothing can be seen
The LCD screen may have been damanged, visit your celphone technician or phone provider to have it checked depending on the impact of how hard you dropped it, touch screen phones are very sensitive if you dropped it really bad the technitian may have to replace the screen.
Jul 07, 2011 | LG GT350 Cell Phone
Tip
How to know if the problem of nokia phone is LCD display or corrupted...
how will you distingguish if your nokia phones problem is LCD or corrupted software if it is in white scrren or blue screen status?
here "s how...
1.removed sim card
2,dial 112 or 117 ,it defends in your country if what is the emergency hotline..
3..if you hear something from an operator ,it is display problem...change a new one comes from working unit ,if still no display it must be display driver (a small chips that makes lcd display functioning)..
4..if you hear nothing ,its your phone software isa the problem...
on Jun 14, 2010 | Cell Phones
Lg chocolate touch screen not working
I have a LG Chocolate BL 40. It fell down and cracked its display screen from several loactions. So I got a the cracked display screen replaced with a new one. All seems to be working fine except that when the call comes the answer button which used to display as green gets greyed out and does not lets you answer the call. I have tried upgrading the software as well as a factory reset bit it has not helped. C
Can somebody advise how/if it can be fixed?
Aug 28, 2010 | LG Chocolate 3 Cell Phone
How do i stop the front display from flashing every 15 seconds. lg reveal.
Hello there and welcome here
Here you can find your phone manual, just select the state the phone is shopped at :
http://www.bell.ca/support/PrsCSrvWls_ClpGde_Interactive.page?brand=lg&model=reveal&sku=67206
You can find the manual here :
http://www.bell.ca/support/PrsCSrvWls_ClpGde_Interactive.page?brand=lg&model=reveal&sku=67562
Normally you find the screen settings in the settings section under the phone features
Hope that helps
IF NOT the try to return here
Have a nice time over there
Please rate my answer
Jan 10, 2010 | Cell Phones
Get blue screen when i turn on my Sony w705 phone
is there have a sound or functioning all while the screen is blue,this problem is in need to replace lcd but if there is no sound or no anyone can function and no display it means reprogram your phone.
Dec 26, 2009 | Cell Phones
Message reading change drum soon permanently on screen. changed the drum as no printing could be seen, ie paper blank. however, still got the change drum message on the screen. how do i get rid of this?
7 Wait until the time, date and answering mode appear on the display. Then press the SELECT FUNCTION key. ecblank.gif ecblank.gif ecblank.gif ecblank.gif 8 Press the 7/COUNTER DISPLAY One-Touch key. The display will show DRUM COUNT. ecblank.gif ecblank.gif ecblank.gif ecblank.gif 9 Press 2.413c?openelement&fieldelemformat=gif to clear the image drum unit
counter. ecblank.gif ecblank.gif ecblank.gif ecblank.gif 10 Press the SELECT FUNCTION key to finish. ecblank.gif
Dec 03, 2009 | OKIFAX 4500 Plain Paper LED Fax
My nokia 6111 screen goes blank
It is not a common problem. It seems that either the connection to the LCD is broken somewhere, or the LCD is going or the display IC has gone. It it is the last (display IC) then the phone has to be thrown away as even Nokia thinks it beyond economic repairs. Earlier two can be rectified by Nokia Care.
Aug 21, 2009 | Nokia 6111 Cellular Phone
Fax problem
Hi Fatimo25,
The screen on your fax machine displays how the machine is set to receive calls. TEL MODE means the machine will not auto-answer incomming calls and will operate as a normal telephone device, it will still however be able to send a fax in this setting.
Place your message on the original tray and pick up the handset, dial the number and when the distant machine answers press the start key or ask for their fax machine and when you hear the high pitched fax tone press start.
There is a button on the panel that will allow you to change the reception mode of your machine to the other settings.
Your machine is of a model that doesn't come into this country so I have no manuals to forward you. You can try however to access the SHARP web site www.sharp.ae
Hope this helps you
regards
Gavin
Oct 08, 2008 | Sharp UX CC500 Plain Paper Thermal...
Cell Phones Logo
905 people viewed this question
Top AT&T Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
