Question about Nakajima AE-710 Typewriter
AE-710 My AE-710 has been working great! Now, when I type, the print wheel isn't hitting the ribbon hard enough to get a solid impression. I have tried all the settings (low/med/high) and nothing makes a difference. I have tried three new ribbons and doesn't make a difference. When I type a word, it's not a complete strike and even when I repeatedly retype over the same word to darken the impression, nothing improves.
    President:
  • Nakajima Master
  • 3,594 Answers
First see if the ribbon is spacing a full space for each letter pressed if not you may be in the over strike ribbon mode, to get out of the mode press code and comma, period or slash i'm not sure which one So try them all.
If that dosen't help check to be sure the correction tape is not getting in the way, remove the corr. tape and try it.
Next remove the ribbon and release the hammer as if you were changing the P/W and see if the plunger in the solenoid is free, if not try a drop or two of WD40 on it.
DickyO
Posted on Sep 17, 2008
My typewritter wont impress even on hardest impression setting. I think the Ribbon might not be turning eventhough it looks like it is.
If it sounds like it is hitting the paper puy in a multi part form if the copy is OK then you have a ribbon problem, put in a new ribbon.
If there is no print on copy be sure the print wheel is properly latched in place.
DickyO
Aug 03, 2015 | Nakajima AE-740 Typewriter
My Nakajima typewriter prints too light - like the keys don't hit the ribbon hard enough to be solid.
Go to nadist.com you will find a manual there with impression control instructions.
DickyO
Feb 26, 2013 | Nakajima WPT-150 Electronic Typewriter
We type on address labels, the same ones we have used for years, but it is not printing well at all on those. It prints fine on paper. Changed ribbon, still will not print well on the labels.
Labels often have a glossy surface that correctable ribbons will not print well on.. Try these, move the impression control on the left to the largest dot, set up to print in bold, get a fresh ribbon not just another one off your shel.
DickyO
Aug 31, 2011 | Nakajima AE-710 Typewriter
Removed old ribbon cartridge. Unable to install new one. I snap it in place but it is not working. No print. Can you send a diagram of how it is supposed to be installed. I have a model AE-710. Thank you
First thing remove the ribbon turn the hand feed knob and see if the ribbonmoves if not you have a bad ribbon. The ribbon has 2 little feet thar hook on the ribbon deck and then it snaps down and latches into place. Go to NADIST.COM, Click on current models you will find a manual there.
DickyO
May 19, 2011 | Nakajima AE-710 Typewriter
The typewriter doesn't completely print the whole letter, only sometimes and sporadic and not all letters are affected. Cleaned platen, and checked print wheel . All letters seem to be raised. What could...
Fiest put in a milti part form and try it if the copies are good you have a ribbon problem.
Try it without the correction tape. Look at the ribbon to see if it has folds in it or the letters are overstriking on the ribbon
The L/O should be dry non tacky.
DickyO 216-241-0027
Dec 08, 2010 | Nakajima AE-710 Typewriter
Nakajima ae-710 does not give a clear print. I suspect the striker pin. How do I lubricate it?
You should not have to lubricate the "striker"....type some characters then remove the ribbon cassette and see if the characters are spaced properly or are typing on top of each other on the carbon ribbon. You may have put the machine into a "multi-strike" mode....you can get a manual at www.nadist.com
Nov 16, 2010 | Nakajima AE-710 Typewriter
Printwheel out of line
will not type letters dark enough
Mar 20, 2009 | Nakajima AE-710 Typewriter
AE-710 Letter Keys Do Not Work
Check the pitch selector switch if it is in PS this will cause this problem.
DickyO
Oct 29, 2008 | Nakajima AE-710 Typewriter
Nakajima AE710 typewriter
The forms obviously have a glossy surface, a fabric or multi strike ribbon will work. There is a impression control oh the l. side of the keyboard and also a bold feature, try max impression and bold.
DickyO
Mar 27, 2008 | Nakajima AE-740 Typewriter
Nakajima ae 710
you have to press code + either , or . at the same time, that function is for multistrike ribbon where the ribbon feed move slower.
Feb 27, 2008 | Nakajima AE-710 Typewriter
Nakajima AE-710 Typewriter Logo
109 people viewed this question
Top Nakajima Office Equipment & Supplies Experts
James Cagle
James Cagle
Ron Dufek
Ron Dufek
Jim Keysor
Are you a Nakajima Office Equipment and Supply Expert? Answer questions, earn points and help others
