Question about Intel Motherboard
Window related problem
When i start installing window service pack 2 after formatting drive after we enter key then time comes and network environment setting comes and time left displayed dont reduce and processing stops nothing happens...time only goes up to 32 mins....my mother board is of asus company and i m installing window fist time on this motherboard....
  • 67 Answers
Update the BIOS. There is an issue with some older ASUS motherboard and XP SP2. If the new BIOS doesn't work, you may have to work around the problem. I came about this problem last month. I couldn't install and new BIOS firmware doesn't work. I installed the system unto the harddisk using another PC, and place it back to the system unit, place the installation CD and chose the FIX OS option.
Posted on Sep 16, 2008
Blue creen with blinking cursor
you can do a clean install from your usb. i use this setup for all my flash drive boots.
WinSetupFromUSB - Install Windows XP from USB Flash Drive
This guide will show you, how to use WinSetupFromUSB to create a bootable USB Flash Drive including all Windows source files, plus the following installation of Windows XP. Compare to the different USB_Multiboot versions, WinSetupFromUSB comes with a Graphical User Interface (GUI) and is in my opinion easier to use.
Here you can get the latest version of the program and you will also find many detailed informations about WinSetupFromUSB.
I've tested this guide with a 32-bit version of Windows XP and a 64-bit version of Windows Vista and it worked flawlessly.
Prerequisites:
All you need is:
a USB Flash Drive with at least 1GB of storage
the original Windows XP Setup CD
WinSetupFromUSB
If you use nLite to slim down your version of Windows XP, please keep the following in mind:
DO NOT remove "Manual Install and Upgrade"
under Operating System Options!
I also recommend to integrate Service Pack 3 into your Windows XP source files.
1. Preparations
Download and install WinSetupFromUSB. Default installation path is C:\WinSetupFromUSB.
Create a new folder with the name WINXPCD in the root directory of drive C:\ and copy all files from your Windows XP Setup CD into this folder. Depending on your version of Windows XP, the content of C:\WINXPCD should look approximately like this:
Content of WINXPCD
The following files will show you, which Service Pack is already integrated into your CD:
WIN51IC.SP1, Sevice Pack 1
WIN51IC.SP2, Sevice Pack 2
WIN51IC.SP3, Sevice Pack 3
2. Start WinSetupFromUSB
Connect the USB Flash Drive to your PC and start WinSetupFromUSB. It should show up under USB Disk Selection :
WinSetupFromUSB - main window
3. Select your Source Path
Click on Browse under Windows 2000/XP/2003 Source and navigate to the folder with your Windows XP Source Files. It should be C:\WINXPCD:
Browse to Folder
Click OK and C:\WINXPCD should show up under Windows 2000/XP/2003 Source :
WinSetupFromUSB - source path
4. Format USB Flash Drive
PeToUSB or HP Format Tool are used to format the USB Flash Drive. There is no need to download these programs seperately as they are already included in WinSetupFromUSB.
USB Flash Drives up to 2GB should be formatted with PeToUSB in FAT16, USB Flash Drives with 4GB or more with HP Format Tool in FAT32.
I will use PeToUSB to format my Kingston Data Traveler with 2GB.
In the main window of WinSetupFromUSB click PeToUSB under Format target using to start the program. The USB Flash Drive should show up under Destination Drive. Check USB Removable, Enable Disk Format and Quick Format. Uncheck Enable File Copy under File Copy Options :
PeToUSB
Click Start and answer the following two questions "Continue?" with Yes.
All existing volumes and data will be lost!
If everything goes well, the message "Operation Completed Successfully!" should appear. Click OK and close PeToUSB.
The process with HP Format Tool is similar.
5. Copy Windows XP Source Files
To start the process of copying the Windows XP source files to the USB Flash Drive, click GO in the main window of WinSetupFromUSB. Depending on the write speed of your USB Flash drive it may take a while to copy all files.
WinSetupFromUSB - file copy
At the end the following notice about the Windows installation process should be displayed:
WinSetupFromUSB - notice
Click OK and close WinSetupFromUSB with EXIT.
6. Windows Installation - Part 1
Connect the USB Flash Drive to your PC and turn on the computer. Press ESC at the boot screen and you will be able to select the USB Flash Drive as your boot device from the boot menu.
The ESC key is used by ASUS for the Eee PC series.
Other manufacturers may use other keys, e.g. F8 or F12.
After booting from USB Flash Drive, the following menu should be displayed:
Windows XP/2000/2003 Setup - First and Second parts
Press Enter or wait 10 seconds to get to the next menu:
First part of Windows XP Home Edition setup
Second part of XP Home Edition setup+Start Windows for first time
First part of Windows XP Home Edition setup is already selected. Press Enter or wait 10 seconds to start the Text mode part of setup. During this part you can create, delete and format partitions and finally the setup files are copied to your hard disk. At the end the system will restart automatically.
7. Windows Installation - Part 2
After restart, boot the PC again from your USB Flash Drive. The same menu should be displayed:
Second part of XP Home Edition setup+Start Windows for first time is already selected. Press Enter or wait 10 seconds to start the GUI mode part of setup. During this part you will be asked for your product key, timezone, usernames and other necessary informations. At the end the system will restart automatically.
8. Windows Installation - Part 3
Second part of XP Home Edition setup+Start Windows for first time is already selected. Press Enter or wait 10 seconds to Start Windows for the first time. The Windows installation process will be finished and finally the Windows Desktop will appear.
DO NOT disconnect the USB Flash Drive too early!
At next startup you can boot into Windows from your hard disk.
Notes:
After successsful installation, the following boot menu will always be displayed during startup:
Please select the operating system to start:
Microsoft Windows XP Home Edition
USB Repair NOT to Start Microsoft Windows XP Home Edition
If you don't plan to use the repair option and want to boot directly into windows, you have to do the following:
Open the file boot.ini in the root directory of drive C:\ with Notepad:
[Boot Loader]timeout=30
Default=multi(0)disk(0)rdisk(0)partition(1)WINDOWS
[Operating Systems]
multi(0)disk(0)rdisk(0)partition(1)WINDOWS="Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
multi(0)disk(0)rdisk(1)partition(1)WINDOWS="USB Repair NOT to Start Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
Delete the following line:
DO NOT delete the wrong line!
Your computer may not boot the next time!
Save changes to the file.
At next startup the boot menu will not be displayed.
If you want to keep the repair option, you can reduce the time to display the operating system options from 30 to 5 seconds:
[Boot Loader]
timeout=5
At next startup the boot menu will be displayed only 5 seconds.
gd luck
Mar 09, 2014 | Computers & Internet
How can i format my pc& how change my os from ubuntu to windows xp
The following tutorial will help you reformat your hard drive and reinstall windows. I personally reformat my HDD and reinstall windows at least once every 3 to 5 months. After your first successful reformatting, you'll wonder why you didn't try this earlier. This is one of the first things I taught myself because I knew I was going to make a mess of my system...alot. Anyway, Please note, I am not responsible for any damage although I don't see how you can possibly damage anything whilst reformatting. Follow these steps exactly and you should be fine.
Step 1: Make sure you have your Windows XP disk. I personally delete everything I don’t need, and uninstall all programs that I don’t use. I then make a list of all the programs I still have installed and download all the installers I will need. Also download Spybot Search and Destroy and Ad-Aware but do not install them. I then backup all my important data and all the installers onto a portable hard drive – if you don’t have one you can build one (see HERE how to build your own external hard drive cheaply) or you can use DVD’s or CD’s. Make sure you have everything backed up and then disconnect the portable hard drive.
Step 2: Insert your windows disk into the Master CD drive (if you have more than one) and turn the computer off. Make sure you are disconnected from any networks. You will need to have your cd drive selected as your first boot device. If it not already selected, you will need to go into your bios and set the boot priority to cd/hdd, then with your Windows cd in your cd drive, save and exit bios.
Step 3:
Turn on your computer. A screen will come up saying “Press any key to boot from disk”. Press any key (where’s the “Any” key gone?!). Now wait about 10seconds for the setup utility to be loaded. When asked if you want to set up or repair, hit Enter to set up Windows. Read the license agreement and hit F8 if you agree. If the setup program detects an existing installation of Windows and asks if you want to repair it, hit Esc to skip the repair. The setup program will ask you where to install Windows. Highlight the existing "C: Partition1" partition and hit D to delete it. Hit L to confirm. Next, hit Enter to install Windows on the "Unpartitioned Space". Format the space as NTFS - You will get an option to choose full or quik format. My experience is that quick format is for disk that have previously formatted. If the disk has not been formatted, then you will have to use the standard format option. Usually you will get a popup message "This disk can not be quick formatted" or something along that line. Then continue the installation. Please note: During the installation process, your computer will reboot. You will then see a message to press any key to boot from cd. Do not press any key a second time, otherwise the installation will start from scatch again. Complete the next several screens on the setup process and make sure you do not leave the administrator password blank. After following these steps, setup should be complete.
Step 4:
Firstly you should install your antivirus software, Spybot S&D and Ad-Aware. Also enable the windows firewall by going to Start>Control Panel>Network and Internet Connections>Network Connections (icon on the bottom-right)>Right-click the Local Area Connection>Properties>Advanced tab>Check the box next to "Protect my computer and network...">OK. After this has been done, install all updates from the Microsoft website (including windows XP service Pack 2). Then install all drivers from your motherboard utilities CD. Now it is time to install your programs.
Step 5:
Enjoy the brand new feeling of your Reformatted PC
Hope this tutorial will help some people.
Watch this 5 minute video tutorial before you start...
Jun 24, 2010 | Computers & Internet
How to make pen drive bootable in winxp
Well you can please follow the link below -
http://www.intowindows.com/how-to-create-bootable-windows-7-vista-or-xp-usb-flashpen-drive-with-a-single-click-must-try/
Good Luck!!
Jun 15, 2010 | Microsoft Windows XP Professional With...
I want format my system ,i have windows xp i placed service pack2 in my cd drive and restarted my computer while booting takesplace i pressed the key F8 but didn't get the message that boot from cd or dvd,...
Hi there, you have to go BIOS set up first. From there you have to select the first bootable drive is your CD/DVD rom in place of your HDD drive. Then save the setting and restart the PC npormal way.You will see the PC reading your disk & ask for press any key to continue for booting. I home its helpful for you. Thanks.
Feb 28, 2010 | Computers & Internet
My acer laptop not working it is showing no hard disk present, but setup is showing 40gb, I wants to format.
You need your installation CD's for this:
An operating system software and the Laptop support CD.
So you want to start from scratch, just because you like the brand new feeling of a freshly reformatted pc? Or has spyware and viruses made your pc virtually unusable? Then the following tutorial will help you reformat your hard drive and reinstall windows. I personally reformat my HDD and reinstall windows at least once every 3 months. Please note, I am not responsible for any damage although I don't see how you can possibly damage anything whilst reformatting. Follow these steps exactly and you should be fine.
Step 3:
Step 4:
Step 5:
Enjoy the brand new feeling of your Reformatted PC
Nov 10, 2009 | Acer TravelMate 2300 Notebook
How to reformat acer travelmate 2480?
run install from windows cd back up drivers first if you don't have a drivers cd
Sep 17, 2009 | Acer TravelMate 2480-2153 Notebook
I want to install again the WINDOWS 2000 Professional and i can't do it because it shows a blue image and says that i've to put the win 2000 pro disk on the diskdrive and i put. when i go to the...
What is the boot order in the BIOS? Set that to 1=FDD 2=CD-ROM 3=HDD
While the PC is still on, put the Windows CD in the drive
Restart the PC, watch the screen for a prompt to boot from cd - press a key
The installation will start, you will need to choose where to install Windows
If you do not need to save any data, format the C: drive and install window there.
Follow the prompts the rest of the way through the installation.
You will need to enter the Windows License code at some point.
It is a good idea to change the regional settings to match your location and how you want the date and time formatted.
Most things should be detected and installed automatically, so you are safe to accept the defaults.
After about 45 minutes you will need to restart the PC and then you should be ready to enjoy Windows 2000.
Be sure to go to Windows Update and install all of the patches.
Good Luck and let me know how it goes.
~ Spoem
Mar 24, 2009 | Toshiba Portege 3110CT Notebook
XP service pack 2 Genuine problem
How to make your Windows XP Service Pack - 2 Genuine Hi all my users, I m back with lots of thing.
Lots of my students & Users ask me How to make Windows XP Service Pack - 2 Genuine, beacuse of security features, microsoft update, downloading software & installing some software like Windows Media Player 11 & Internet Explorer 7 and Many more facility.
Here some simple steps to make your Windows XP Service Pack - 2 Genuine----
1) start > run > “regedit” (without the quotes of course)
2) go to the key:
HKEY_LOCAL_MACHINE\SOFTWARE\MICROSOFT\Windows NT\CurrentVersion\WPAEvents\OOBETimer
…and doubleclick on it. Then change some of the value data to ANYTHING ELSE…delete some, add some letters, I don’t care…just change it!
now close out regedit.
3) go to start > run > “%systemroot%\system32\oobe\msoobe.exe /a” (again, dont type the quotes)
4) the activation screen will come up, click on register over telephone, then click on CHANGE PRODUCT KEY, enter in this key: JG28K-H9Q7X-BH6W4-3PDCQ-6XBFJ.
Now you can dl all the updates without activating, and the Genuine Microsoft Validation thingy won’t bug you no more!!
Dec 22, 2008 | Microsoft Windows XP Professional
Windows xp service pack 2
Hi 1. Click Start, click Run, type regedit in the Open box, and then press ENTER. 2. Locate and click the following registry key: HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\CDRom 3. To disable automatically running CD-ROMs, change the Autorun value to 0 (zero). To enable automatically running CD-ROMs, change the Autorun value to 1. 4. Restart your computer. NOTE: This method disables automatically running CD-ROMs. If you want to disable automatically running CD-ROMs depending on the CD-ROM that you insert in the CD-ROM drive, you can press and hold down one of the SHIFT key while you insert the CD-ROM. This may help. Good Luck
Sep 12, 2007 | Microsoft Windows XP Professional With...
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
