Question about D-Link (des-3526) Networking Switch
DES-3526 problem Hi, guys... Our environment has 2 D-Link DES-3526 linked together by high speed ports. This morning I had a weird problem... one of them (the second one in chain) had every LEDs blinking (of course, the connected ones) in amber. Such blinking did not seem to be communications signs. It had a constant slow blinking frequency for a while, then every LEDs went off for a while also, then start blink again. All communication were stopped, even with the first one. The only thing occurred to me was unplug the power cable, wait some minutes and plug it again. It worked! So, my question is: what happened and why? Marcos, from Brazil
SOURCE: no power led, wlan led blinking
remove the power adaptor for about 5 min. and plug it again.
reset the wifi router to its original setttings (factory default) and configure again the settings.
check your network card disable it and reenable it again
same thing with your wireless card
Posted on Feb 27, 2008
SOURCE: configuration
IWANT TO COMPLETE INSTALATION TO 24 PORT MANAGABLE SWICTH WITH DEMO
Posted on May 16, 2008
  • 5 Answers
SOURCE: D-LINK DI-514 LAN Ports not working
  1. Connect a cable from your PC to one of the four plugs. Not the WAN port.
  2. Setup the wireless the way you want it.
  3. Then give this router a different IP, like 192.168.0.2
  4. Then you have to disable the DHCP server in the router (keep in mind now you have to set your desktop or laptop that is conencted to it to a static IP to still communicate with the router)
  5. Once this is done just plug you existing network into one of the four ports. Not the WAN port.
  6. It will now act as a wirelessa access point.
Althoug this is doable it is not recommended as this router is a pile of **** and the wireless is crappy.
I would suggest a dedicated wireless access point.
Posted on Dec 06, 2008
  • 55 Answers
SOURCE: D-Link DS-G604T abnormal Flashing Leds
hello,
Please do the following on the pc with the wired card not working:
Click on start, then hit RUN, then type in it: cmd
and hit enter.
in the prompt that you got, type: ping 127.0.0.1
If you get a successful reply in the form of the below text, then your network card is working, if not, then the network card is burnt from the thunder storm.
Successful reply sample:
Pinging 127.0.0.1 with 32 bytes of data:
Reply from 127.0.0.1: bytes=32 time<1ms TTL=128
Ping statistics for 127.0.0.1:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
Posted on Mar 18, 2009
steinja66
  • 52 Answers
SOURCE: switch with 8 leds blinking (and not working)
You probably have to buy another switch. However, before you try that - the eighth most right cable - switch that out to see if it was a cable problem. That's an easy thing to try before you buy another switch.
Posted on Apr 03, 2009
I have forget the user name and password for the swtch i.e D link des 3526.kindly send me the procedure of how to reset the configuration
Connect a LAN cable from the D-Link to your computer's LAN port, open a browser and enter the D-Link;s configuration URL.
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter)
You can now go to the wireless settings.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Feb 07, 2011 | D-Link (des-3526) Networking Switch
I have a switch Dlink (DES-3026). All the status LEDs are blinking together with orange color. Is there any problem in that?
Blinking LEDs show data activity (Send & Receive) at the connected ports. So, there is no problem as long as the switch is performing well
Good Luck!
CreativeTECH
Feb 01, 2011 | D-Link Computers & Internet
How do i connect 2 d-link switches
i found that there is a MDI uplink port for cascading
Dlink DES-1016D 16-port 10/100 Switch
Product Features
  • 16 10/100Mbps ports
  • Full/half duplex support for each port
  • MDI uplink port for easy expansion Expansion is easy through a MDI uplink port. You cascade several switches together through this port to get more ports.
  • Auto-learning of network configuration
  • Flow control in full duplex mode for protection against data loss
  • Back pressure in half duplex mode
  • RAM buffer dynamically allocated for each port
What's Included?
  • DES-1016D Network Switch
  • Quick Installation Guide
  • CD ROM
Aug 27, 2010 | D-Link DES 1016D (DES-1016D) 16x10/100...
I have des 1008d switch running at 100 mbps.i want to get 200mbps speed full duplex.so please tell me how to configure this switch to get the full speed.
D-Link DES-1008D 8-Port Ethernet switch is unmanaged switch which can only support 10/100 MBPS.
You need to replace the switch and the network adapters with a gigabyte switch and adapters to get more bandwidth.
For more information on your switch please visit the link below:
http://www.dlink.co.in/products/?pid=183
Rashish
Aug 15, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
I interconnect a D-Link DES-10160 with D-Link Gigabit Switch DGS-1024D network and my network becomes slow
connect only DGS -1024D to your network....it will be faster...
because DGS supports 10/100/1000 speed.... but DES supports only 10/100 speed...
connect DGS directly to your network and work with that... if you wish to extend the number of ports then connect the DES to one of the ports of DGS
and dont connect DGS to one of the ports of DES
May 10, 2010 | D-Link DES-1024D Express EtherNetwork...
D-Link DES 1024D
There is no configuration on the switch, this is a dumb layer 2 device. Plug in you PC's etc.. and go. The switch will auto detect the speed and duplex of the device connected to it.
Dec 10, 2008 | D-Link DES 3225G Networking Switch
Configuration
The DES-3526 has a lot of features and it would be quite hard to teach you everything through FixYa.
I suggest you start by carefully reading the manual. Everything is very well documented:
ftp://ftp.dlink.com/Switch/des3526/Manual/des3526_Manual_500b27.zip
Then, once you have learned more about it, if you still have problems, feel free to write back and we will help you.
Apr 14, 2008 | D-Link DES-3526DC (DES3526DC) 24x10/100...
D-Link (des-3526) Networking Switch Logo
114 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
