Question about RIM BlackBerry Curve 8310 Smartphone
Roller ball The roller ball works except down wondering if this might be fixable
  • 7 more comments
  • allaurence Sep 17, 2008
    My roller ball stopped working going down????
  • Anonymous Sep 20, 2008
    My rollerball still moves down, but the phone doesn't register it moving, so nothing happens. Can still roll up and side to side, but down is a no-go, and it's like the most crucial direction.
  • mania44uk Sep 25, 2008
    same prob here.cannot go down,only up n left to rught
  • kchhajlani Sep 27, 2008
    same problem with roller ball and its a serious problem
  • Anonymous Nov 05, 2008
    same problem... phone is only a month old!
  • joscmt Feb 25, 2009
    My rollerball/trackball and cursor aren't really responding to each other. Going up is fine.....going down is the issue. The ball rolls down, the screen doesn't register it.
  • Anonymous Mar 02, 2009
    track ball will moves but it wont register down .
  • Anonymous Apr 19, 2009
    my ball works it goes up and down but it doesnt click
  • Anonymous May 20, 2009
    Rollerball would not scroll up.
Same problem, wouldn't scroll down. Lifted the ring pulled out the rollerball and cleaned it with alchohol. Used a cotton swab, soaked it pretty good and rolled it around a bit. Set it back in and it worked like new. Watch how you take it out so you can put it back in the same way.
Posted on Jan 30, 2009
You can lift the ring around the roller ball and try to clean.It worked for me.
Posted on Oct 18, 2008
I popped the ring off of the track ball assembly, removed the track ball unit and cleaned it with a swap and alcohol. Problem solved! Be sure you put the track ball assembly back the same way you took it out.
Posted on Nov 24, 2009
  • 846 Answers
The only way to fully get it up and running again is physically remove andclean (with alcohol) or replace the part. If you want somebody else to do it for you, goto Blackberry Trackball. If you want to do it yourself, here is a Blackberry Repair Guide that shows how, the part is available on Ebay.
Posted on Jul 19, 2010
You can purchase a replacement trackball assembly for as little as $6 plus shipping.
www.blackberry8100parts.com
www.dealsishop.com
Installation is fairly simple.
Posted on Oct 10, 2008
Can I fix the roller in my wireless mouse?
Open the mouse. (Slide the panel on the bottom that surrounds the ball, and pull the ball out. Clean the ball and the rollers inside the mouse with rubbing alcohol. Remove all debris, hair, lint, etc.
Voila!
Sep 26, 2014 | Computers & Internet
Using Brother Printer HL-2040, not so many pages printed, but have some dot in pages about 3 black dots and some fade letters. what should i do to clean drum?
Remove the cartridge and look carefully at the rubber roller. You have debris stuck on the roller that needs to be removed. Get a cotton ball and dab some rubbing alcohol on it. Then run the cotton ball back and forth over the rubber roller making sure to use a clean section of the cotton ball each time. Now advance the rubber roller and repeat with a new alcohol cotton ball. Do this until you made it all the way around the rubber roller. Allow to dry for 10 minutes and then insert the cartridge back into the machine.
Nov 12, 2010 | Brother HL-2040 Laser Printer
The Dyson roller ball vacuum I have is making me crazy because the roller bar wont turn. What gives?
Check that you dont have anything blocked in the roller, if all is clear there is a little red button on the side off the roller. Push this in and this will reset the roller... If that doesnt work, check that it is switched on with the switch next to the power button.. That should solve your problems
Oct 04, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
My roller ball does not scroll down, it goes all other directions but down, it makes it so hard for me to navigate.
take the roller ball out by poping out the silver ring at the top and look on the bottom of the ball and make sure that all of the black rollers will roll and if not clean them.
Feb 22, 2010 | AT&T Blackberry Curve 8300 Smartphone
Roller ball on blackberry won't work
Was it Like it when you bought it?? If not, then its probably broken.. it happens a lot with rollerballs.. if you take it back to the shop you bought it from they will probably send it away to be fixed.
Sep 05, 2009 | RIM BlackBerry Pearl 8100
Roller ball
All you have to do is take a sheet of paper with print on it. Take the battery out of you phone. Next do a figure eight motion with the ball side down on the phone about 10 times. There is something on the ink on the paper that will make this work again. good luck
Feb 12, 2009 | Verizon Communications BlackBerry Pearl...
Pearl roller ball
It might be a case where the track ball has some dirt or debris underneath it. First, turn the device off. Next, press down firmly on the track ball while at the same time rolling it in every direction. Hopefully that will knock loose any debris. Another tip to try is to wet your thumb with a little water and do the same thing.
If those two options don't work, you may try taking out the track ball and blowing out the slot with some compressed air. Below is a link that shows how to remove and clean the track ball:
http://www.blackberryforums.com/general-8100-series-discussion-pearl/113889-how-clean-trackball-your-pearl-8100-a.html
Oct 03, 2008 | RIM BlackBerry Pearl 8100
Roller ball will not work down.
Cleaning the roller ball with a lint free cloth seems to work pretty well. Lock the hand held and then just go to town on the roller ball with the lint free cloth.
Sep 17, 2008 | RIM BlackBerry Curve 8310 Smartphone
RIM BlackBerry Curve 8310 Smartphone Logo
3,734 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
David
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
