Question about Amana ARB2259CS Bottom Freezer Refrigerator
Amana defrost My Amana arb2259cs refrigerator is not staying cold. The freezer works fine. If I unplug it for a few hours and then plug it in the refrigerator works fine for about 5 days then it slowly warms up. Can you tell me what might cause this (defrost control?) and how to fix it? (The fan is free of debris and working)
    Guru:
  • 462 Answers
Hold the door switch closed like the door is closed for testing an inside fan. The fan could be so quiet you might not hear it. Wet your finger and feel for air movement. Like a Washington politician, you might be able to feel it.
The defrost circuit showing a completed circuit means the heater and safety stat are OK I believe.
I would be more inclined to believe the board its self is at fault if this is correct. Remove one or more of the wires going to the defrost heater and retry it. this way you have an open circuit your sure of and the result you get on the board means this part of the circuit logic is operating correctly.
And the test 2 "Compressor/Condenser Fan Test" is talking about the fan motor on the outside by the compressor not the inside fan. That is the evaporator fan inside.
Other things that may help you:
The defrost timer / or board will never be in the Freezer. Other than that it could be in the refrigerator section behind a plastic cover or metal cover on the back outside. It could also be under neath the front corners or center of the front kick plate.
A timer you can turn the cam clock wise til it clicks. A board will depend on the manufacturer as to how to send into defrost for a test. A sensor on the defrost type board may be required to by-pass into a defrost.
The freezer section has the only cooling coil. It sounds like it is blocked with frost and thus wont let the air circulate from freezer to refrigerator.
There is a defrost timer, (or board), a defrost heater, and a defrost safety thermostat. Any One of these or a combination of 2 can be your problem. If you have a energy efficient model that has electronic controls then you will have a board. The procedures for checking the circuit on a board vary by manufacturer of the board used and manufacturer of the appliance.
The defrost heater always has resistance and is attached to the freezer coil.
The defrost thermostat is also attached to the heater electrically, unless it is an electronic sensor type. Sensor types have a range of resistance that needs to be known to check and varies slightly with the temperature of the sensor.
If I haven't lost you here you maybe equipped with the life experiences that will allow you to do most of these checks. If its over your understanding I recommend you contact a reliable technician.
If this helps you please rate me as high as you can and thank you for using fixya.l
Posted on Apr 17, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: Amana BX20RW Refrigerator slightly warm freezer not freezing
Check the thermostat, to make sure that it is working properly. The theremostat is a long wire in the top of the freezer up near the fan. If that is bad it will not let your freezer cool correctly
Posted on Feb 08, 2009
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
had same exact problem - followed advice for fixing same problem in similar refrig. took of the back panel off the freezer section - 8 hex head screws - and found the cooling fins all frosted over.
Posted on May 31, 2008
Techsim
  • 59 Answers
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Posted on Nov 02, 2008
SOURCE: my amana bottom freezer won't cool both the fridge and freezer are warm
Ice build-up inside refrigerator and cycling switch not functioning. Requires technician to take apart inside of refrigerator, clear ice and replace switch. Took my repair man about half hour to fix.
Posted on Jan 15, 2009
heatman101
  • 43501 Answers
SOURCE: Amana bottom freezer working fine but refrigerator not/ warm since 24hrs.
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 25, 2010
I have an Amana ARB2217CSL. The freezer is working fine, but the refrigerator section is no longer staying cold.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jun 09, 2011 | Amana ARB2217CSL Bottom Freezer...
Refrigerator is warm, but freezer is cold and still making ice. This is a 3 year old Amanna Bottom Freezer model. There is frost in the top of the freezer drawer when I putt it out.
you will need to defrost it. the freezer is what keeps your fridge cool. the vent where the cool air goes up to your fridge is sealed or frozen.
unplug the fridge and open the doors and let it defrost.
plug it back in after a few hours and it should be working again.
Mar 20, 2011 | Amana ABB2223DEQ Bottom Freezer...
Fridge stopped working ..... just like that... what could it be?
did you try plugging something else into that plug to see if it works or is breaker off
Sep 02, 2017 | Amana ARB2259CS Bottom Freezer...
Freezer working but fan not on in fridge - where to locate fan?
May be ice build up - happened with mine. Had to defrost completely (unplug for 24+ hours) then it worked fine on restarting.
Aug 15, 2009 | Amana ABB1927DE Bottom Freezer...
Control board reset?
Amana version of adaptive defrost : Press refrigerator light switch five times in six seconds to initiate defrost cycle. Pressing five more times within six seconds will cancel defrost and go straight into the run mode. Similar operation on both bottom mount and SxS refrigerators. After the defrost terminator/thermostat opens, six minutes of dwell time occurs before the compressor and condenser fan motor will operate. After defrost terminator/thermostat open, 10 minutes of dwell time occurs before the evaporator fan motor will operate.
May 04, 2009 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Not blowing cold air
Most likely evaporator coils are iced near solid...few hours unplugged would have helped just a little...needs major defrosting though.
The automatic defrost cycle will never fix it when it gets this bad...if it's still working yet.
I have one of these and have had to use heat gun/ hair dryer more than once to defrost it.
Probably the cause...which will need fixed or it will do it again sooner or latter...is the melted frost/ice goes down a little drain tube and dumps into tray to evaporate above coils...this tube gets plugged first with dust and then when melted frost drains and stands in tube the tube get plugged with frozen water.
You see it is important to unplug or fridge will self destruct.
Mar 01, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Amana refrigerator warm
Chances are if they are getting cool but not cold-
1) the evaporator fan in the freezer is not running
2) Defrost heater has failed
3) Defrost sensor has failed
4) Defrost timer/refrigerator control has failed.
Check for ice build-up on the back wall of the freezer. If there is ice, unplug or turn the unit off for 6-8 hours with the doors open (put any food in a cooler with ice to maintain). Note water may come out of the refrigerator.
Plug the unit back in or turn it back on, close the doors, and check temperature after a couple of hours of operation. If all OK, you will need to have the above tested, or, if you know how to use a multimeter and can read a schematic/wiring diagram, I can instruct you on how to check the above.
Jan 20, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
My Amana AFD2535DEW freezer problem
Sound like the compressor is having trouble starting. You can purchase a RCO810 to assist the compressor's start winding. If the unit is under 5yrs there should be some warranty (no electrical parts) left in the compressor. It will need to be replaced.
Oct 16, 2007 | Amana AFD2535DES French Door Refrigerator
Freezer is cold but refrigerator is not.
If the fan is still working (and it sounds like it is, then the evap coils are frozen up. A typical failure is the defrost bi-metal t-stat but I've also seen LOTS of the adaptive defrost circuit boards fail on this model. I would lean toward the circuit board first as the culprit. See part 711 http://www.partselect.com/Schematics/Maytag/32266.gif http://www.partselect.com/xq/aspx/Inventory.51814/qx/PartDetail.htm?SourceCode=5&ModelNum=ARSE66MB
Jun 02, 2007 | Amana ARSE66MB Side by Side Refrigerator
Amana ARB2259CS Bottom Freezer Refrigerator Logo
244 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
