No Sound on a Philips 42PFL5332D
TV is one year old and I just connected Directv to the system. Worked great the first day. Turned it on the next day and no sound. I connect the DVD to the TV and again no sound. Went through the menu and checked everything and it appears to be set up right. Going through the configuration setup, I have sound coming out during the audio part of the set up. Can you help Me?
    Problem Solver:
  • 14 Answers
First thing to try is reset everything to default.
Menu arrow to installation press ok.
arrow to reset av settings press right then press ok.
If still no sound after this the tv likely needs service..even if the settings assistant
has sound.
Posted on Sep 15, 2008
Sound output to a sound bar
Most TVs have a menu setting that says internal or external speakers.Here are the instructions for yours.
Turning off the built-in speakers Use this feature to turn the TV speakers off when you connect an
audio system (see "Connecting an audio system" on page 11).
To turn off the built-in speakers:
1. Press MENU, then press x or • until AUDIO menu appears.
2. Press y or z to highlight SPEAKERS.
3. Press x or • to highlight OFF.
Feb 16, 2014 | Toshiba 36HF71 36" TV
I have a Sony Wega DLP with no sound through HDMI all of a sudden. Can't give exact model at the moment but it is a projection TV definitely 5years old at least. It has only 1 HDMI input and I've been...
The first step, and you hinted at it already, is to check cables and connectors. Especially with any electronics that old, connectors go bad if the wiring is moved, wiggled over time.
What you could try, since your WEGA is an older unit, is to connect your peripheral devices through the Component Inputs to your TV- at least one unit and see if the problem is resolved. Then you know for sure its either a cable or a connector.
Next step- try another HDMI cable and see if the sound comes back. If not, then its either the connector or the internal TV amplifier.
To troubleshoot the question on the amplifier, take a "Line Out" off your TV and run it to a stereo to see if audio is coming through. This is a lower level signal and doesn't rely on the higher power transistors required for a TV amplifier. If the Line Out audio works, then you know the TV amp needs repair.
Keep us posted!
Chad
Jun 25, 2017 | Televison & Video
Lost the picture and screen is black. Try pressing menu but does not appear, there is sound but no picture at all. this happend from turbning off one night to the next day when turning on. The TV is 2...
It is not used everyday but he power supply is running 24/7.
There two possibilties:
1) There is no 24vdc from power supply module for feeding the backlight inverter board, look for bad caps with elaking./bulging top.
2) Inverter board is bad, blown fuses, transistors, etc.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Philips+42PFL5332D+
Jun 14, 2010 | Philips 42PFL5332D 42 in. LCD Television
My new hdtv makes a loud buzzing sound. it is connected to directv.I used a video connection because when the hdmi is used the sound is lost when the power is turned off and then back on. The tv is a...
I have comcast and get buzzing from the box when everything is off. Do you have the option of unplugging it and having the t.v. on by itself or will the provider have to come reprogram it. If not, disconnect box to rule out t.v. before t.v. warranty is out.
Jan 31, 2010 | Philips 42PFL3704D LCD TV
Philips DSR708 DirecTV DVR hangs up after power up
Is this a new issue that has shown up on the receiver? If so then you might have a bad hard drive in the receiver causing it to hang on boot up. Also these units require two inputs from the satellite antenna so that could be another possibility.
Nov 17, 2009 | Philips DSR708 DirecTV DTV Receiver /...
No sound on channel 69 on my philips tv LCD
use youe remote and make sure sound setting are in Stereo mode Not SAP
Nov 02, 2009 | Philips 42PFL5332D 42 in. LCD Television
No picture
just an idea the t.v. is 10 years old ok. Now look at the back can you see inside if so chances are there is a build up of dust which makes a great t.v. wrecker. So vacuum the dust out and see if that helps.
Jul 23, 2009 | Toshiba CF27H50 TV
No video on Denon avr 688
After days of frustration the real problem was with the cable box. It needed a firmware update. Following forum advice I disconnected the cable box power cord for a few minutes, reconnected it, allowed the cable box to reinitialize. Turned off receiver and TV. Turned TV back on and set it to HDMI connection, turned on receiver and all worked fine. Great picture and sound.( Needed to buy an optical cable to go from the cable box to the receiver to get sound from the speaker system. )--the dirtybird
Apr 14, 2009 | Denon AVR-3300 Receiver
Televison & Video Logo
89 people viewed this question
Top Televison & Video Experts
