Question about Zanussi TC7102W Electric Dryer
Extremely low drum heat but setting is on HIGH.
Electric (Kenmore - 60931) dryer takes forever (several cycles) lately to dry clothes set on high heat (actual heat in tub feels low though). There are no obstructions in the venting and the 240 volt connection is fine. The timer rotates the dial (timer motor working). Help!!!
  • Anonymous Mar 16, 2014
    dryer only dries clothes on low setting
Posted on Oct 29, 2008
Gas dryer heats at first then take forever to dry, auto dry setting does not advance
If it works to begin with and fails afterwards then that can only be them solenoids mounted on the gas assembly. Here is my home video which shows how to check and replace:
May 02, 2013 | Dryers
Kenmore dryer 110.86864100 - Where is the moisture sensor?
Ain't no moisture sensor. This is is not an electronic sensing machine. It uses another method to determine dryness. An orange wire connects to the base of the heating element. The timer motor is driven by power from it in auto dry. The timer motor is VERY slow. Slower than most dryer timer motors.As the clothes get dryer the heat is not needed so the element is turned off by the control thermostat which is mounted next to the skinny white fuse on the blower housing. This allows for the turtle like motor on the timer to advance. Once the clothes get to the point of dryness the heater stays off way longer and the timer motor advances on over to the cool down and carry on over to the end of cycle. So the clothes won't always be dry due to factors like lint buildup in the blower housing, venting to outside and so forth. having said that my mom bought a brand new Kenmore dryer and I set it on 55 minutes timed drying. At the end of that them clothes is still damp. I then set it to auto dry high heat and that usually gets em dry. I think the main probo with this dryer is the thermostat ain't set as high as older models to keep the heat at a moderate temp so that the limits won't blow on models in apts and such. Just a theory.
Sep 16, 2012 | Kenmore 659 Electric Dryer
Dryer taking to long to dry
Overloading
1. One of the simplest problems to remedy could simply be that you are putting too many items inside the machine during the drying cycle. Avoid overloading your dryer, as this might cause your dryer to work extra hard to dry your clothing, extending the length of the dry cycle.
Wrong Heat Setting
2. A common issue with clothes dryers could be the wrong heat setting. Most home dryers feature several settings, from low heat settings to high heat and permanent press. Be sure the setting you choose is right for your needs. Another setting to check is the load size of your dryer. If you are drying a large amount of clothes, be sure the setting for large loads on high heat is selected. Choosing the wrong heat setting or load size can cause your clothes and linens to take longer to dry.
Lint Trap
3. One of the simplest fixes for drying issues might just be that your lint trap is clogged. Each time you use your dryer, lint will form in the trap. If the lint trap and vents are full, this could block air going into your dryer and slow down if not completely stop the drying process. After you use your dryer, remove this lint trap and empty it fully. Even if the lint trap is full, your other dryer vents might be clogged as well.
Clogged Vents
4. If your clothes are in the dryer for a long amount of time, but still not drying, the reason for this could be a clogged vent. A sign that your vent is clogged is if your clothes are warm or hot to the touch after sitting in the dryer, but still damp. To unclog your dryer vent, you may need professional assistance. This is especially necessary if your dryer vent leading out of the house is particularly long.
Heat Source
5. If the dryer is not getting enough heat to dry your clothes,something could be wrong with the heating system. After the drying cycle, touch your clothes to see if they are warm. If not, this means that the heating mechanism is malfunctioning. It will need to be repaired or replaced by a professional.
Feb 28, 2011 | GE Profile Harmony DPGT750GC Gas Dryer
Problem with Dryer Timer or heating element
The heat cycle must be working for the timer to advance in the Auto Dry setting.
Your heating element and or high limit thermostat is bad.
We need a complete model number to be more specific.
May 31, 2010 | Kenmore 600 6965 Electric Dryer
I just bought a gas dryer - takes forever to dry clothes
check the high limit switch/thermostat on the burner housing and if they are weak they will cycle the heat off too soon and it wont build the heat you have it set for,just bypass it with a jumper wire to test it,if this is the problem,dont leave it bypassed,replace it as it is a safety feature to prevent a fire
May 09, 2010 | Kenmore 95087 Gas Dryer
My kenmore dryer heat element goes on and off. The clothes take hours to dry.
It seems to run forever If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system. Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Dec 31, 2009 | Kenmore Dryers
Takes too long to dry or keeps running when clothes are dry
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
May 07, 2009 | Kenmore Elite Oasis 6809 Electric Dryer
Dryer produces low heat but not high heat
check the vent outside it seems to be getting too hot and cycling the element off and on your safety therm.
Oct 22, 2007 | Kenmore 62802 Electric Dryer
Zanussi TC7102W Electric Dryer Logo
719 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
