Question about SanDisk Sansa c240 MP3 Player
Repair system is unable to recognize the sansa
  • 2 more comments
  • Anonymous Nov 19, 2008
    i plug in the sansa and that wizard pups up and cant find any software. HHEEELLLLLPPPPP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  • Anonymous Dec 13, 2008
    it says computer cannot find software for sansa c240
  • Anonymous Dec 21, 2008
    Cant find it... no software, no new devices...
  • renez May 11, 2010
    What is your PC Operation System?
    It does not appears in any way ( as another disk or a "other device" list when you open the computer icon? )
YOU CANT HEAR A SONG OR TURN IT ON, ITS FREZZING
Posted on Nov 30, 2008
My sansa is not coming up on my computer. i have a 250 and it picks it up right away.
Posted on Sep 22, 2008
SanDisk Sansa e250 MP3 Player with Mac? Is there any driver to make it compatible with Mac platform? Thank you
NOTE: MAC computers do NOT support MTP modes of USB conectivity in a MP player. A Sansa player in MTP mode when plugged into a MAC computer will NOT be detected or recognized. MAC computers supports Sansa players in MSC mode Sansa players can only be recognized by a MAC if the USB mode on the Sansa player is set to Auto Detect or MSC.
Check in the System Profiler Open System Profiler from the Utilities folder, which is inside the Applications folder. From the Contents column on the left, under the Hardware header, select USB; the panel to the right will show all the USB devices that the computer recognizes. It may not identify them correctly by name, but it should have the right number of devices listed. . Navigate to USB Mode settings. Sansa View - From the Main Menu, select More > Settings/Options > System Settings > USB Mode.
Sansa Fuze and Sansa Clip+ - From the Main Menu, select Settings > System Settings > USB Mode.
Sansa Clip, e200v1 series, e200v2 series and e200R - From the Main Menu, select Settings > USB Mode.
2. Select Auto Detect, MTP or MSC. e200R - PlayforSure is MTP and Rhapsody is MSC
See this tip posted here on this site for a better explanation on the modes - MTP and MSC. Solve your MP3 Player Connection Problem.
Feb 05, 2010 | SanDisk Sansa e250 MP3 Player
My computer is not recognizing the sansa clip, I am unable to recharge the device anymore, and it does not appear in my drivers. I have retried loading the disk and nothing happens...please help!
Have you tried going to settings, then system settings and changing the usb mode? I have had some computers not recognize my device and this has helped. MSC should be he default mode and your device should show as a drive. The MTP is for DRM management. I have also had a clip that did this and my usb cable was bad.
Jan 04, 2010 | SanDisk Sansa Clip MP3 Player
Not recognized on my computer. running xp
go to settings on ur sansa, go to usb then change it to MSB. that should fix it
Aug 12, 2009 | SanDisk Sansa e270 MP3 Player
I downloaded a Sansa video converter and it keeps saying that my Sansa is not connected after i connect it. Can i have some assistance please?
do u have windows or mac system? if mac,
Although MAC OS is NOT a supported operating system, the Sansa player can still be recognized if the Sansa player is only plugged in MSC mode.
See answer ID 207 for instructions on how to put your Sansa player in MSC mode.
See answer ID 1141 for instructions on transferring music to your Sansa player using iTunes on a MAC computer.
Aug 01, 2009 | SanDisk Sansa e260 MP3 Player
My computer doesn't recognize my sansa fuze
On your Sansa Go to "Settings" then "System Settings" then "USB Mode," change it to MSC, now try connecting it. If that doesn't work try the other modes just in case.
Hope this helps!
Jun 03, 2009 | SanDisk Sansa Fuze MP3 Player
MY SANSA 250 NOT DETECTING MTP MODE AND IM UNALBLE TO UPLOAD
It's not to normal that it doesn't recognize the MTP mode. I think reading the minimal requierments should be useful. Thereafter untill I recomend you to use Windows Media Player. You put the music you want to be on your sansa in the WMP library. Then you go on the Syncronisation tab upwards to the vizualisation window. and the rest should roll on
May 21, 2009 | SanDisk Sansa e250 MP3 Player
Cannot get my computer to recognize my sansa e260 player
Hope this helps!
May 01, 2009 | SanDisk Sansa Connect MP3 Player
My XP system does not recognize Sandisk Sansa e260
The XP did not recognize the device because I used a after- marked USB expander board that did not provide enough power to the device. Plugging to the Motherboard - attached USB port solved the problem.
Mar 20, 2009 | SanDisk Sansa e250 MP3 Player
Unable to install software for sansa e 260 R mp3 player
Go to settings on your sansa and scroll down to USB Mode.
Change it to MSC.
Apr 11, 2008 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa c240 MP3 Player Logo
98 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
