Question about Linksys Wireless-G WET54G 802.11g/b (WET54GSUK) Wireless Bridge
I was asked about the password
I used to have no problem on the first time installation of wireless router model WRT54GC (Linksys). However, I format my PC and install again the XP professional. Then I install the wireless router, then I waas been asked the password. And the default is admin. I try to input the admin.... still invalid password...? How can I access again the wireless router...! thanks
  • Anonymous Dec 15, 2008
    I had the same problem with them and the online and phone support were horrible!!! Their support helped me get it up and running and then they told me to push the reset button in the back for 30 seconds, then unplug for 30 seconds and plug in again w/reset button pressed. I did, it didn't work and I couldn't get back in with either my password (which I used several times before) nor with Admin. I I eventually reinstalled it from scratch with the CD and had to go through the whole process of providing the Linksys settings (this time I saved it [.bin file] and then it ran fine.
  • 26 Answers
Hi rsmagdasoc,
Did you run the setup CD before? It might have been that you had change the password from there.
Posted on Oct 04, 2008
I am switching internet provider. What I should do to reconfig my linksys wrt54gc router?
If you will be switching to a different internet provider what you need is to get their network settings.Most of the time if its DSL or Cable connection all you need is just your account name and password from them for the router to talk to your modem. Thanks
Feb 21, 2011 | Linksys Wireless-G WRT54G Router
How can I know my router's security password?
Not quite clear as to your problem. Are you trying to access the web-based configuration page for the router (for which you need an administrator password)? Or are you trying to make a wireless connection to the Internet via the router (for which you need the wireless security key)?
Those are two separate passwords, and you may be able to retrieve them both. The administrator password would be stored in the computer that was used to configure the router. The security key should be in the computer which configured the router, as well as any computer which made a wireless connection to the router.
If the passwords are stored, you should be able to retrieve them by installing some additional software.
For the computer that configured the router, download and install this program:
RouterPassView by NirSoft
For a laptop that connected to the router, download and install this program:
WirelessKeyView by NirSoft
Feb 21, 2011 | Linksys (WRT54GC) Router
I want to put security password my router, but my cd installer was loose how should i do
Security password for WiFi?
Go to your browser and type:
Go to wireless security and choose WPA2 and put whatever password you like. save and exit. Done
Hope this helps!
Aug 22, 2010 | Linksys WRT54GC Compact Wireless-G...
The linksys network has disappeared from the list of choices on my computer. To try fixing the problem, I've reset the router via reset button but it didn't help. However, that did restore the router's...
You need enable wireless in router.
Connect your router to computer with ethernet cable then you can access it with following default link.
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Then click on wireless and enable configure it as AP mode access point mode.
Click on wireless settings then WPA Security then not down code .It is your password to connect wi fi..
Then you can connect your wi fi network with that code.
Aslo make sure WAN settings are perfect with your internet service provider.
Enable DHCP if you want ip from router.
Let me know if you need further assistance.
Thanks for using FixYa.
Jun 27, 2010 | Linksys (WRT54GC) Router
I need to set a new pass word on my router.
OK, you need yo remove from power and press reset button, now using a browser login, using default login & password
manual above, shows you how to do it all.
Apr 08, 2010 | Linksys (WRT54GC) Router
Linksys wireless router WRT54GC is not connecting to Internet
check by connecting directly your computer to modem, if still same, then contact ISP, might be a problem at thier end.
Mar 16, 2010 | Linksys (WRT54GC) Router
My Linksys wrt54gc quit working. I get amber
For that you need to reset your router to factory defaults.
Then reconfigure fix this problem.
First RESET your router to defaults.
for that press RESET button for 10 seconds RESET button is in back side of router.
Then connect your router to computer with ethernet cable.
Then you can access it with following link.
type user as "admin" and password as "admin" or blank or "password"
Set WAN settings as your internet service provider settings.
Enable DHCP .
Click on wireless and enable wi fi.
If you want secure router then enable WEP security then add new code it is your password key for connect wi fi.
Also change channel type in wireless option 4,6 and 11 channel are best.
Try 1 by 1 then save settings and restart router.
Nov 06, 2009 | Linksys WRT54GC Compact Wireless-G...
How do i set up a router? here's my model nummer(wrt54gc) thanks
Just click on the link below and download the manual. It covers detialed instructions on how to set up the router from scratch. Hope this can help you.
Best Regards
Nov 05, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
My Linksys WRT54GC suddenly stopped working. The router has no power light but the wireless and internet light are green.
Sounds like a PSU failure possibly.
If you can still get wired internet then its not dead. Its even possible the power LED is pooched if you can still use the wired connections.
Aug 11, 2009 | Linksys (WRT54GC) Router
Linksys Wireless-G WET54G 802.11g/b (WET54GSUK) Wireless Bridge Logo
79 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
