Question about Bosch Microwave Ovens
The door catch on my Bosch 8656 built in microwave has failed after only two years use. The catch itself is not broken but the spring mechanism inside the door no longer pushes the catch into the closed position. Is this a common fault?
  • Bosch Master
  • 9,086 Answers
Yes, for some brands and models.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
We have critical safety & disassembly info at our site, linked here.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Posted on Sep 16, 2008
Bosch integrated microwave doesnt start/close
Door latch settings are out because door slamming and abuse of unit
Dec 02, 2013 | Bosch Microwave Ovens
Door doesn't latch
Can you move the latch in the door? This is spring loaded, maybe the spring is broken
Mar 09, 2013 | Maytag MMV1153A Microwave Oven
MY 5 YEAR OLD BOSCH INNOWAVE BUILT IN MICROWAVE HMT 8656 HAS JUST DIED. WHAT IS THE LATEST MICROWAVE TO REPLACE IT
Here`s a little fact about microwave`s, they are not healthy - http://rense.com/general70/microwaved.htm
We threw ours out, food taste much better cooked on the stove, oven or grill.
Apr 15, 2011 | Bosch HMT8625GB Microwave Oven
The door on my bosch hmt8655gb wil not shut please can tell me the best way to repair rob
Door catches.
One of the latches may have broken off and is not lifting the other latch clear of the housing. Remove from any power source, remove the cover of the cabinet. Slacken off the clamp mechanism and ease the clamp over the guide to allow the door to open. When a new door lever is in place, the door may be easily adjusted by slackening off the screws that clamp the door catch/actuators in place whilst holding the door closed and then tightening the screws. The rear of the door may be adjusted by slackening the lower door hinge screws and adjusting as required.
I hope that helps.
Mar 01, 2011 | Bosch HMT8656GB Microwave Oven
Samsung microwave door popped open and now won't close. What happened?
The spring attachment to the moving latch has broken off either replace the latch or drill a small hole in the latch body and attach some heavy steel wire to make a new attach point for the spring. the inside trim easily pops off and the latch just slides off.
Jan 26, 2011 | Samsung Microwave Ovens
I have a Samsung SMH9187ST microwave, it is about 2 years old. The door won't stay closed. It is worthwhile to try to fix it or should I just replace it?
If you can lift the plastic door latch catches with no resistance, it is most likely the spring/plastic connector. I removed the door by lifting up, pulling the bottom forward, and lowering. I removed the inside black plastic bevel with a jewelers flat screw driver, prying from the latch side's external edge. Once it was started, I could pull it of with a gentle lift. I took out the black plastic latch, drilled a hole near the broken piece and all was good. Samsung is not on my radar for any future purchases. This is the 3rd major purchase that barely made it past warranty or not even thru warranty.
Dec 31, 2010 | Samsung SMH9187ST Microwave Oven
My boyfiend slammed the door shut and it has not worked since then
The door latch (on the door) or the door catch (on the oven) have most likely broken. The oven will not operate if the door is open or if it is not correctly closed.
Check the door latch. On most microwave ovens there will be one or two prongs. Make sure that they're not broken and that if neither of them is loose. Often one or both are designed to move upwards against spring pressure so if they move loosely with no spring pressure then the door must be dismantled to find out why. Often it's a broken spring anchor and sometimes it can be repaired, but the official fix is to replace the entire door assembly.
If the latch seems fine then it's almost certainly the door catch unit which must be repaired or replaced. They're not officially repairable, but sometimes all that has actually broken is a cheap and easily obtainable microswitch. If the catch has actually broken then there is no point in gluing it together as it won't hold. If the door catch assembly looks fine and the microswitch appears to be operable then use a continuity meter on the switch to confirm correct electrical function as the switch is pressed and released.
If that fails, then look for any fuses on the circuit board, the filament inside can break if they're subjected to too much physical impact. Test and replace any failed ones, but it's vital to use the correct type, the casing will indicate whether they're slow blow or fast blow fuses. These properties are independent of the voltage and current rating and simply regulate how quickly or slowly a fuse will fail if the limits are exceeeded. using a slow blow in the place of a fast blow is dangerous, but using a fast blow or a regular fuse where a slow blow goes will just mean that the fuse blows more often or even immediately in normal use, often when the door is opened.
If you need any spare parts then you'll have to find suppliers yourself, sorry. I don't know which country/state you're in and I'm based in London, England, where Emerson is not a known brand.
I hope that my answer helps you to either repair your oven or to decide whether to replace it. Please take a moment to rate my reply.
Sep 23, 2010 | Emerson Black Microwave Oven
Microwave door spring broken
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can order parts from Encompass here or you can call them toll-free at 866-779-5835.
Jun 05, 2009 | Microwave Ovens
Microwave Ovens Logo
508 people viewed this question
Top Bosch Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Bosch Microwave Oven Expert? Answer questions, earn points and help others
