Question about Rangemaster 110 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range
Both electric ovens do not work.
Turned on right hand oven, MCB tripped. Once reset, Cooker timer and top plates work but both ovens do not appear to have power (no elements, no fans, no red light on cooker oven controls). Common fault?
  • kirkpatw Oct 12, 2008
    Thanks for this. Helping out a friend who didn't have a user guide. Clock did need to be reset - by holding buttons 1 & 2 and pressing button 6. Cooker ovens then appeared to work although fan oven didn't get hot. Faulty fan oven element - changed. Good as new.
  • 99 Answers
Have you set clock time?
Posted on Oct 11, 2008
Rangemaster Ceramic 110 randomly trips the MCB.
Electric rangemaster tripping electric - what size mcb? ' DIYnot ...
www.diynot.com > Forums > How to... > Electrics UK
Apr 6, 2013 - Cooker occasionally trips the 'Wylex B32 MCB' when almost everything is going. ... http://www.ebay.co.uk/itm/Rangemaster-Leisure-110-Electric-Cooker-/ ... Find the total load via the site below, a ceramic nit is 14kw shock:
Oven or cooker tripping electric, what to do next? - YouTube
? 3:11
https://www.youtube.com/watch?v=O42p_tWYgAU
Dec 21, 2011 - Uploaded by Richard Saupe
Hi Richard, i recently bought a all electric rangemaster cooker second ... I'm asking because our oven trips the breaker when we try to turn it on, ...
Frequently Asked Questions ' Rangemaster
www.rangemaster.co.uk/rangemaster-owners/faqs
For earlier specification110cm models, remove the storage drawer and the silver ...Ceramic and Induction models may be connected to a suitable 6mm cable ...
http://www.diydoctor.org.uk/forums/electrics-forum.html 2015-12 ...
www.diydoctor.org.uk/forums/electrics-forum-f182.xml
Jan 19, 2016 | Rangemaster Range Cookers Kitchener 110...
I have an old belling farmhouse cooker the hob works fine but the oven isn't igniting manually or by the electric ignition The timer is manual and is stuck on the red patch I can't seem to shift it ...
Take the tiny screws of there are loads down right hand side then release screws on hob once you can lift hob plates up. Undo the covers on back of timer clock control . Make sure you un plug from mains . Take the neutral of back of timer clock. This will allow your oven to auto ignite again
Jan 07, 2014 | Belling FarmHouse 931 Gas Kitchen Range
SMEG OVEN BRAND NEW WON'T HEAT
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Sep 08, 2012 | Smeg Ovens
The oven was on and working..then the electric tripped and all power went off...after putting the switch back up on the fuse box everything on the oven started working but it does not get...
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
If this helped like us on facebook please How to Video Tutorials on Domestic Appliances
Mar 04, 2011 | Zanussi ZBF260 Electric Single Oven
Cooker oven not working - replaced bulb. Hot plates still work.
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Jan 07, 2011 | Zanussi ZCE611X Electric Kitchen Range
Have a new electric cooker but the oven and 1 of the hob plates isn't working dc5422 beko
hi chances are that the internal thermal cutout fuse has gone this fuse is situated on the right hand side of the cooker when you have taken the back plate off about half way down it has two wires attached to it and is screwed with a self tap on the right hand corner of the body of the cooker near the middle of the cooker. You can buy this part and have it delivered for about £6 so is a very cheap fix.
Sep 17, 2010 | Ovens
Beko dvc 62 ,all electrics tripped out ,put cooker
The element has blown. It will cost you around
May 16, 2010 | Ovens
Timer clock is not illuminated and oven will not work
This does have an internal fuse and there are probably 2 or 3 of them. They should be located right behind the timer or thermostat.
Feb 03, 2009 | Blodgett Ovens
Electrolux EOG7330 gas cooker - electric timer fails?
Pull off bottom knob of oven shine torch down at 45degrees u will see a red plate turn off power suply and use a small screwdriver to push the plate turn power back on job done.PS Check all vents are clear to stop it over heating good luck.
Jul 18, 2008 | Electrolux EOG7330WN Gas Double Oven
Cooker not heating up
removed broken element and replaced it. You have to access the fixing screws from the back of the cooker to remove it
Feb 14, 2008 | Smeg A2.5 Dual Fuel (Electric and Gas)...
Rangemaster 110 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range Logo
682 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Mike Carew
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
