Question about Lexmark Office Equipment & Supplies
Trying to reinstall lexmark 2500 and it says there is no usb port.
    Sergeant:
  • 320 Answers
For any computer there will be at least 4 usb ports. Printer can be installed through 2 types of ports. USB and Parallel port. To install the printer Please click on the below link or copy thr URL and paste it in your web browser. And follow the steps given in that link.
http://kb.iu.edu/data/aksl.html
To download the drivers for your printer Please click on the below link or copy thr URL and paste it in your web browser.And select the type of ypur printer and the operating system you are using. Click on Download to download the drivers.
http://downloads.lexmark.com/perl/downloads/downloads.cgi?ccs=229:1:0:0:0:0
Thank you......
Posted on Sep 15, 2008
Lexmark z2400 will not print, the comuter says document is pending. All connections are correct. Do I have to uninstall the printer, and reinstall with the CD? I rebooted the printer, and nothing. It is...
I am assuming you have it connected via USB to your computer. If you have an additional USB port on your computer then try powering off the printer, attach the USB connection to a new USB port, go to the Control Panel (Start, Settings Control Panel), go to Administrative Tools, go to Services, scroll down to Printer Spool, stop the service, start the service, and power on printer. Try to print a test page. If it fails, power off the printer and delete the print driver. Reinstall the driver using the CD.
Aug 30, 2010 | Lexmark Office Equipment & Supplies
Lexmark z45 not working with windows xp. i installed a lexmark z45 on my laptop that has windows xp and it will not print
Check the printer status:
1 Click Start > Control Panel > Printers and Other Hardware > Printers and Faxes.
2 From the Printers folder, double-click the Lexmark Z45 printer icon.
3 From the Printer menu, make sure:
– Default Printer is selected.
– Pause Printing is not selected.
Check the printer port:
2 Click the Ports tab.
3 From the list of ports, select the USB printer port. If the USB port is not listed, uninstall and then reinstall the printer software.
4 Click Apply.
5 Click OK.
Make sure you have not installed multiple copies of the printer software:
Windows XP: From the Start menu, click Control Panel Printers and Other Hardware > Printers and Faxes.
In the Printers folder, make sure there is only one Lexmark Z45 printer icon. If you have installed multiple copies of the printer software, uninstall each copy. Then restart the computer and reinstall the printer software.
If the printer port is incorrect or you have installed multiple copies of the printer software, uninstall and then reinstall the printer software:
1 From the Start menu, click Programs or All Programs Lexmark Z45 Uninstall.
2 Follow the instructions on your screen to uninstall the printer software.
3 Restart your computer.
4 Reinstall the printer software
Oct 27, 2009 | Lexmark Color Z45 InkJet
Lexmark Z35: Problem Communicating with the
Installing like this Lexmark are Plug in Play, Windows automatically detected such devices connected on it. If not then try to use another USB Connector to see which is the problem occur or might be your printer too...
Oct 04, 2009 | Lexmark Z735 InkJet Printer
Hi. I have previously downloaded the driver for the Lexmark X75 printer, but when I try to print -I get the following error message: "Incorrect Port Detected. The current print job has been...
I'm assuming you're using Windows XP. If not, these directions may differ a little.
  1. Click Start > Printers and Faxes.
  2. Right-click on Lexmark X75, and then click on Properties.
  3. Click on the Ports tab.
  4. Find Lexmark X75 under the Printers column (or look for which item under the Port column is checked).
  5. Chances are it somehow got changed to COM or LPT. Find any available USB port and check it. Click Apply.
  6. Try to print. If it doesn't work now, you'll probably get a different error, something like "Cannot Communicate". If that happens, go back to theProperties window and try checking any other USB ports you see there. If there aren't any more to try, you may have to uninstall and reinstall the drivers to get it working.
Aug 05, 2008 | Lexmark Office Equipment & Supplies
Lexmark 2500
i need a lexmark 2500 imaging studio...can anyone help me?
Jul 18, 2008 | Lexmark All-in-One Printer with PictBridge
Lost cd to install lexmark2500seriea
lost my cd to install lexmark 2500 series printer
May 28, 2008 | Lexmark X2470 All-In-One InkJet Printer
Printer(2500) does not print
Does it Say Cannot communicate ...if yes then
Check the USB cable..try different port...
Clear all the docs in the printer folder...
Remove the power adaptor and replung..restart computer..
When u unplug and replung the usb cable doesn ur computer give a pop up "found New hardware" ?
U can also try...
Uninstalling the s\w....disconnect the USB cable..reinstal the s\w and connect the cable when it prompts to...
Leme know if this fixed
May 26, 2008 | Lexmark All-in-One Printer with PictBridge
App4R.exe lexmark 2500
try uninstalling driver and reinstall driver
Feb 21, 2008 | Lexmark All-in-One Printer with PictBridge
Lexmark 1270 all in one
First try plugging into a different USB port. I have seen several machines have a port suddenly die for no apparent reason. If that dosent work, try a different USB cable. Assuming the printer is working, the only thing left is either the cable or the port you have it plugged into.
Feb 07, 2008 | Lexmark X1270 All-In-One InkJet Printer
44 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
