Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Broiler won't turn off. Error code F-3
Our oven's broiler turned on and won't turn off. Noticed an error code F-3. Can't do anything else.
We've turned off the circuit to the oven to be safe. When we open the circuit again, the broiler immediately comes back on.
  • rjohnson758 Sep 17, 2008
    Thank you for trying to help me.
    It turns out that the range is a Whirlpool, not a Fridgidaire. The model number is GR458LXLQ.
  • Anonymous Sep 18, 2008
    I have a Kenmore Elite having the same problem. It is on forever and we have to turn off the main power switch in the elctric box outside our house. When the power is turn on, the stove started heating again.
    Sergeant:
  • 409 Answers
can you provide the model # off your stove please?
Posted on Sep 15, 2008
Whirlpool Range model RF386PXGQ2 broiler won't shut off
Hi.
If the element does not turn off, possible faults are:
Shorted temperature probe.
Test temperature probe reading impedance. If impedance is zero or lower than 0.500 Ohms, the the probe is shorted. A good probe reads about 1KOhms.
Contact at element. A contact in element wiring harness may cause the element to stay on. Do continuity test between ground and element and on wiring harness.
Defective control module.
If problem is none of the above, then it is the oven electronic control(ERC). The ERC can be tested reading voltages.
Testing must be done by a trained technician.
Dec 13, 2011 | Whirlpool RBS305PD Electric Single Oven
Ran self clean now oven will not heat up
Turn the breaker off for 5 minutes then turn it back on see if this helps if not let me know.
Sep 27, 2011 | Whirlpool RBS305PRS Stainless Steel Oven
Broiler doesn't turn on completely
The top element should come on when Broiler is selected. If both ovens have a broiler mode, then look for something failed in the circuit for the broiler heating elements (it's unlikely both broiler elements would fail together.). If there is only 1 oven with a broiler, look for a failed broiler element.
Dec 17, 2009 | Viking 27" Professional Select Built-in...
F7 error built-in oven
F7 is a stuck keypad error. Sometimes you can push every pad at random several times each to unstick the keypad.
If that fails the ERC(clock) will have to be replaced.
Dec 04, 2009 | GE 30" Built-In Single Electric Wall Oven...
The broiler won't turn off even when you press the "Off/cancel" button? It sounds like the broiler control relay is stuck shut. The F3 code means the oven temperature sensor has failed, this probably happened because the oven got too hot when the broiler was stuck on. There is fail-safe thermal fuse that will blow if the oven gets too hot, so the oven won't melt down but you should leave the unit off so you don't blow the fuse.
To fix the relay, you will have to replace the oven control module. I think this is about $200 and not too hard to replace if you are somewhat handy. The temperature sensor is also serviceable, you can find parts at Appliance Parts Pros on the web. Hopefully you haven't thrown the range out yet, let me know if you need further assistance.
Nov 27, 2008 | Whirlpool RBS305PD Electric Single Oven
Kenmore oven does not seem to be turning off.
if the broil element was on and the door closed then the oven may have encountered an over temperature issue. i would need your model number and the error code
Nov 26, 2008 | Ovens
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
269 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
