Model: Philips 32PW9556/05R After pressing the power button, the power light keeps flushing (in red colour, never changing into green). The same problems existed two years ago; we got the TV repaired by a local TV repairing shop (I forgot their contact details). I understand the problem is: the (power switch) relay got bad; so that relay got replaced with a new one. I think, the same problem may appear again now; the power switch relay may need to replace with a new one again. It seems that the same problem appears agaion now by the relay; so, where can we buy such a relay? how can we open the TV case to fix the relay? If this is the problem, that means that that relay may cause the same problem again and again in the future; so, is it possible to remove the power swich relay all together and replace it with a normal power on/off switch? Any advice will be appreciated! Thanks, Shicheng
    Top Expert:
  • Televison & ... Master
  • 74,383 Answers
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Posted on Mar 11, 2017
SOURCE: philips plasma won't turn on first time
I have found this on a site and am in the proccess of trying to mend my plasma PF9964 as it started to take longer and longer until it stopped coming on. I've got the back off so I just need to un solder capacitors and replace. Here's the info I found. Bad power switch circuit General Comments If you have this problem with your Philips 32PF9964: When I switch the TV on, it appears as though it is going to start i.e the green light comes on, then after about 10 seconds it switches itself off and the standby light flashes red. It takes 10 /12 times before it starts and is getting worse. This is the solution: The problem is three caps. Change the cap 2663, 2664 both 100µ/25V and 2662,1000µ/25V. After you have changed them your TV will work again. You will find them easy if you unscrew the back on the plasma TV. Cheers, Mike
Posted on May 18, 2007
SOURCE: MITSUBISHI CRT TV MODEL CT-33AC2SL
check for dry joints in power supply
Posted on May 09, 2008
  • 46 Answers
SOURCE: Opening case of Dell 1907FP to resolve stuck power button
Go here for an instrucional video on opening the cases on DELL monitors.
http://www.lcdrepair.us/Installation.html
Posted on Jun 21, 2008
ginko
  • 19396 Answers
SOURCE: Gateway 42" plasma TV; model
Do you gate flash light blinking, if yes, how many times?
Posted on Jul 12, 2008
  • 2920 Answers
SOURCE: Purchased my Philips TV 2
there are 4 capaciters on the corners inside the back of the tv if they are popped up they need to be replaced
Posted on Nov 18, 2008
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
I RE FILL MY CANON MP145 USING INK MAN BUT MY PRINTER DID NOT READ THE INK STILL KEEP ON TELLING NO INK
Best solution i think
How to reset the Canon MP150 (also worked with my MP140 so it might work with others as well) after a refill (Step 10 concerns refill; instructions below the steps):
Method1 (Safe Factory Method):
1) Disconnect the printer's power outlet
2) Press and hold the power button while connecting the power outlet back.
3) While still holding down the power button, press the reset button twice.(red circle with a triangle)
4) Release the power button
Printer takes about 10 seconds to show the number 0.
5) Press + to change the value from 0 to 1.
6) When this value is 1, press colour button; this will light up two leds.
One is for plain paper and the other for photo paper. At this point is feed Printer with paper.
7) Press the power button twice and then press the colour button once. The printer will print a some stuff. Don't worry much about the printed material. I got some stripped lines and some numbers. I believe that my colour cartridge is clogged which explains why I got the green strips.
When you print this sheet the value in the display returns to zero.
8 ) Open Printer's cover cover (not the scanner cover) and remove the cartridges. With Printer still open, disconnect the power outlet.
9) Close the lid and turn on The printer.
10) Refill cartridges and place them back in their nice little abode in The printer.
Sep 16, 2010 | Computers & Internet
Black ink ran out and printed one photocopy without producing any black. Change the cartridge several times BUT still does samme thing - no printing in black. Colour is fine, just no black despite changing...
Canon IP 2000 / reset
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
All the best Pineworks
Feb 09, 2010 | Canon PIXMA iP2000 InkJet Printer
On off light blinkinking from green to red and I
Canon IP3000 INK counter reset
Can gave it a go may work
1. Turn off printer
Dec 14, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
I bought my son a 19" philips tv model # 19pfl340d/27.in order to turn tv on it must be unplugged for 10-15 minutes.The first one I bought did the same thing and I returned it.this one is exactly the...
The remote control will not operate the TV when the TV is in the OFF mode (No LED lit on front bezel). To change the mode from OFF to STANDBY or ON, press the POWER button on the side of the TV. Once the POWER button is pressed, the LED will change to either red to indicate STANDBY or green to indicate ON, whichever mode the TV was in prior to being turned off with the TV POWER button.
By pressing the POWER button on the side of the TV, the mode will toggle from OFF to either STANDBY or ON. If the POWER button is pressed and then the LED on the bezel is red, the TV is in STANDBY mode and will need to be turned on using the remote control. If the POWER button is pressed and then the LED on the bezel is green, the TV is ON.
Nov 11, 2009 | Philips 19PFL3403D/27 19 in. LCD TV
Change the colour
CLICK HERE for a PDF copy of your owner's manual.
Page 17 States to change the display color -
Setting the Multicolor Illumination
ILLUMI BLUE (Initial setting) / ILLUMI GREEN/ILLUMI AMBER /
ILLUMI RED
You can change the lighting color of the following four buttons:
SOURCE/POWER, BAND, (left << arrows) and (right >> arrows).
BLUE > GREEN > AMBER > RED > BLUE
• According to the lighting color of the above four buttons, the color
of the other buttons also changes. When the color of the four
buttons is AMBER/RED, the color of the others is AMBER. When
the color of the four buttons is BLUE/GREEN, the others are also
GREEN.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 20, 2009 | Alpine CDA-9847 CD Player
Philips Model # 30PW850H37A Won't turn on
Likely power supply failure. This could be on a separate board that can be removed and repaired or replaced. Look for a smaller board with larger components that look like transformers and accepts the incoming AC line.
Dec 21, 2008 | Philips Magnavox 51MP392H Rear Projection...
No black ink
Canon S330 Turn off printer
Press the Power button and the printer should turn off, if not, press the Power button once more.
Nov 22, 2008 | Canon S 330 InkJet Printer
Doesn't Turn On
this tv is exchange model through philips. no parts available. contact philips at 1-888-philips for in warranty or out of warranty information
Aug 18, 2008 | Philips 15PF5120 15 in. LCD Television
Error message
OK guys quite a simple one....
with the printer on press & hold both the small red button ( far right ) and the green, colour copy button. Whilst still holding press the power button wait till the unit powers off. Press the power button again, shortly after the unit powers on, the lights flash, let go of the two buttons your holding. The screen shoul dnow say "Init EEPROM" if it doesn't repeat procedure till it does. Now press the green colour copy button once, screen should now say "Push power sw" Press and hold the power button, the unit will power off and on again, now release the power button and your printer should be working again. Now you should change your waste pads......
Dec 05, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
