Question about Dell XPS One All-in-One TV Desktop with Intel Core 2 Duo Processor E4500 - (PRODUCT) RED
Dell XPS ONE desktop
I recently bought the XPS ONE and would like to upgrade the memory from 2 gb to 4gb. How can I access the memory (replace).???
  • 3Labs Dec 05, 2008
    Lots of places sale the modules but I see no where in Dell documentation on how to replace memory. Help.
  • 21 Answers
If you do this do not tell dell xps support that you did. remove the back cover. you will see two slots for memory. goto your local bestbuy or dell.com and get 2 2gb sticks of the same speed. install memory and replace rear cover.
Posted on Jan 18, 2009
  • Zeniff Hathaway Jan 18, 2009
    if you do this do not tell dell xps support that you did. remove the back cover. you will see two slots for memory. goto your local bestbuy or dell.com and get 2 2gb sticks of the same speed. install memory and replace rear cover.
Xps 400 6.0 gb/s hard drive upgrade wont work
Did you initialize the drive in control panel, administrative tools, computer management, disk storage?
Mar 03, 2014 | Dell XPS 400 PC Desktop
Can I add 4gb more RAM
see:http://h20566.www2.hp.com/portal/site/hpsc/template.PAGE/public/kb/docDisplay/?sp4ts.oid=5295969&spf_p.tpst=kbDocDisplay&spf_p.prp_kbDocDisplay=wsrp-navigationalState%3DdocId%253Demr_na-c03536888-9%257CdocLocale%253D%257CcalledBy%253D&javax.portlet.begCacheTok=com.vignette.cachetoken&javax.portlet.endCacheTok=com.vignette.cachetoken
probably no, 32 bit systems have an under 4Gb limit. looks like 2 memory slots 1,2,4 and 8Gb supported.
Memory upgrade information
  • Dual channel memory architecture
  • Two 240-pin DDR3 DIMM sockets
  • Supports DDR3 DIMMs
    • PC3-10600 (1333 MHz)
    • PC3-12800 (1600 MHz)
  • Non-ECC memory only, unbuffered
  • Supports 1 GB, 2 GB, 4 GB and 8 GB DIMMs
  • Supports up to 4 GB on 32-bit* systems
  • Supports up to 16 GB on 64-bit systems
Aug 29, 2013 | HP Pavilion P6 Intel Pentium Processor,...
Windows reports i7 and memory wrong
Your motherboard might not be compatible with these items
Apr 05, 2013 | Dell Studio XPS 435 PC Desktop
I put the memory stick in my dell but the computer does not upload the device. so I went to control panel in devices and printers and I can see the devices but when i say add to this computer it's
Memory sticks are not devices such as printers and
Installing RAM on a desktop computer is of moderate difficulty for most non-technical people. Before beginning any memory upgrade, make sure the proper RAM has been purchased. The Dell XPS 400 requires DDR2 RAM (240-pin DIMM).
Preparing the Computer b> The computer must be unplugged before any work can be completed and the proper precautions must be taken, such as wearing an anti-static wristband. Also, replacing the RAM on a Dell machine could void its warranty. To install the new RAM, the case of the computer needs to be opened. Replacing the RAM b> The motherboard has four RAM slots. Each slot takes one stick of RAM (up to 1 GB per stick). The XPS 400 can utilize up to 4 GB of RAM. If adding RAM, put the new RAM in an empty slot. If replacing the RAM, take out the existing one and then put the new RAM into the machine. Important Notes b> While the Dell XPS 400 has four RAM slots, if only two sticks of RAM are to be used, they must be inserted into slots 1 and 3 or slots 2 and 4 for optimal performance. A single stick of RAM should be inserted into slot 1. Always put the largest ram module closest the CPU central processing unit.
Start your computer Wait for Windows to load. Click on "My Computer" and select "Properties" using right-click in the Explorer window. This will open "Systems Properties." Click on the "General" tab. Here you can view the physical memory installed on your computer. The amount indicated is the total RAM installed on your computer. RAM is usually 32 MB, 64 MB or 128 MB in older PC versions. Newer PCs are usually equipped with 256 MB, 512 MB or even higher RAM.
b>If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. First you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system. You should always ask for a guarantee on the compatibility before making any purchase and try to buy for working pairs if possible.
Mar 01, 2013 | Dell XPS 400 PC Desktop
I bought a 4gb ram upgrade and its still running slow why?
If the upgrade was added to the 2 GB of existing RAM, your computer will run at the slowest speed. That's why some manufacturers recommend replacing existing RAM with the upgraded memory
Jan 02, 2013 | eMachines EL1360G-UW10P AMD Dual-Core...
AOD270-1824 can i put a 4gb ram in it
You can add 1GB of ram but that's it. Definately not a 2GB Stick or 4GB stick.
Sep 01, 2012 | Acer Espresso Black 10.1" AOD270-1824...
I recently added 2 sticks of 1 Gb Ram to my desktop, to now have a total of 4 1 Gb sticks. This newly added memory is PC2 @ 5300Mhz speed. The older 2 sticks of 1 Gb memory are PC 2 @ 6400 speed,...
It depends on what you would like the end result to be. If you need to multi-task, and have 10 windows running at once, go with the 4GB @ 5300 because while it might take a little longer your computer will still be able to handle all the information. However if you are just using it for light browsing and would prefer speed over bulk (when it comes to data processing) go with the 2 @ 6400. I don't think it would be worth it to get 2 more @ 6400, technology is advancing so fast. If you have 60 bucks you can upgrade to two 4GB @ 10600 (8GB total for $60) 1333MHz PC3. Lookup Corsair XMS3 4GB RAM.
Jul 29, 2011 | ASUS Computers & Internet
I have Dell XPS 420 , with windows home server running for some time. I tried to insall/upgrade RAM from 3 gb to 6 gb. So, i found the right RAM (2x2GB) and removed the two old 512 mb from the slot and...
According the the dell specification you can only install up to 4gb, so I don't understand you saying that you were upgrading from 3gb to 6gb. Make sure that all the ram that is installed is of the same brand and speed (667 / 800 MHz Dual Channel Dual DDR2 SDRAM). The fact that it is saying no boot device also would suggest that it is possibly something wrong with your harddrive, whether it was corrupted or damaged while you were changing the RAM, if you have a spare harddrive try installing and booting from it. If that doesn't work it could be a motherboard issue, which the BIOS should be update, all the jumpers on the board should be checked etc. Its rather hard to diagnose a problem such as this, and the fact that after you installed the new RAM, even the old RAM would not work, suggests that you may have damaged something while messing around in the computer.
May 19, 2011 | Dell XPS 410 PC Desktop
Upgrading memory to 4GB failure
try to see if that memory is supported with your motherboard. The memory has something to do with that problem.
Jun 16, 2009 | Acer Extensa 5620 Notebook PC
Dell XPS One All-in-One TV Desktop with Intel Core 2 Duo Processor E4500 - (PRODUCT) RED Logo
516 people viewed this question
Alun Cox
