Question about Miele Dryers
Miele novotronic t689 super
I have a fault on the above model its only blowing cold air any advice would be apreciated thank you
SOURCE: Not drying
I had the same problem with my dryer.
MAKE SURE THAT POWER IS OFF AND PLUG IS UNPLAGED AT WALL
On the back of the dryer there is a white metal cover in the centre with two philips screws. Once removed you will see metal box which has elements like a toaster built inside it.
You will see two sensors sticking out of top of metal box. The left one is the sensor for safety cut out in event of the dryer sensor on the right stopping working and letting the dryer overheat.
If you disconnect the left sensor 2 crimps and put multimeter on the left sensor two pins and if the meter beeps on continuety the sensor is ok. but if no beep the sensor is bad.
If sensor bad you can tempary bypass the sensor by joining the two cables together and try running dryer on a program and if heats up you know that you need to get new sensor.
WARNING! IF YOU LEAVE THE LEFT SAFETY SENSOR BYPASSED IF THE RIGHT HAND SIDE SENSOR MALFUNCTIONS THE TEMPERATURE WILL RISE AND CAUSE SERIOUS DAMAGE OR FIRE. THE PURPOSE OF THE RIGHT HAND SENSOR IS WHEN THE DRYER HEATS UP TO HEAT IT CUTS OUT AND WHEN DROPS DOWN IT HEATS UP AGAIN SAME AS AN OVEN.
You can maybe buy sensor from a meile dealer or RS COMPONENTS have the same sensor for £3.35 each.
NOTE: I ACCEPT NO RESPONSIBILY FOR DAMAGE OR INJURY IN MY ADVICE FOR REPAIR OF DRYER.
Posted on Dec 12, 2008
Why is my miele t220 novotronic have a burning smell when working
If lint material has collected around the heating element this will happen. Locate the element and clean out all debris, lint, etc.
Sep 01, 2015 | Miele Novotronic T220 Electric Dryer
How do you change a belt on a Miele Novotronic t220 tumble dryer.
You might want to post this in the dryer section. Have you checked youtube?
Nov 03, 2013 | Miele Novotronic T220 Electric Dryer
I need from manual guide on English for dryer Miele t565c
I have a t565c novotronic dryer,the light in the drum comes on but when i close the door and turn it on it want start .?
Dec 28, 2010 | Miele Novotronic T220 Electric Dryer
My miele novotronic t230c is not generating heat but work fine in all other areas. can you advise me please
Sorry to read about your problem. Their is a 80% chance you have a defective heat coil or coils. or the heat selector switch is defective. in addition you may have a clogged dryer vent.
I suggest you place a call to a service company.
I tried to help you. Please help me and vote/rate this response thanks.
If you live in Denver area, I can help you.
Dec 21, 2010 | Miele Novotronic T230C Electric Dryer
Miele T230C do no start
If start LED does not blink, most likely fault is your door lock.
Jan 04, 2010 | Miele Novotronic T230C Electric Dryer
Where is the reset button for the miele t200 novotronic special tumble dryer please
there is no reset button for this unit. if it is not heating you may have blown your thermostat
Oct 30, 2009 | Miele Novotronic T1570C Electric Dryer
No heat out Miele T234C dryer.
Most likely fault is filters have been clogged and tripped the safety stat on rear of appliance. Wash filters and replace stat Part No. 5432530
Jun 26, 2009 | Miele Novotronic T230C Electric Dryer
Miele T220 Novotronic
Miele is a top notch machine. Try checking your vent hose. It may be blocked in some way.
Jan 28, 2009 | Miele Novotronic T220 Electric Dryer
Dryers Logo
149 people viewed this question
Top Miele Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Are you a Miele Dryer Expert? Answer questions, earn points and help others
