No, what do you want to achieve? Hotter water or turn on at a lower flow? The flow shitches are are either weighted switches or resistors, depending upon who makes it.
Posted on Sep 15, 2008
Apr 25, 2016 | Water Water Heaters
Apr 03, 2014 | Bunn AXIOM AXIOM-DV-APS Coffee Maker
Because electric tankless water heaters have to instantaneously raise the temperature of incoming water to a selected hot water temperature, they require very powerful heating elements. To power the heating elements of this 27,000 Watt model, you will need to upgrade the electrical service you were using for your storage tank water heater. The PowerStar AE125 will require a 240V, 200 Amp service. In addition you will need to install three 40 amp dedicated double pole breakers in your electrical box. In Canada, you will require one 120 Amp breaker.
The PowerStar AE125 electric tankless water heater incorporates a very sensitive flow sensor, and three heating elements. The heat from the electric elements is electronically modulated on the basis of the flow rate of the water entering the water heater, and the temperature rise that the water heater must achieve. Through its electronic modulation system, the AE125 maintains a very precise hot water temperature. As a safety precaution, each of the three heating modules is protected by an electro-mechanical thermal cut-out. This device will cut power to a particular module if the temperature gets too hot.
This will help.Thanks.Helpmech.
Jul 02, 2011 | Heating & Cooling
May 23, 2011 | Bosch Water Heaters
Oct 04, 2010 | Rinnai Webstone The isolator EXP tankless...
Apr 04, 2017 | Bosch Water Heaters
Oct 27, 2009 | RTO Ariston Gl4.0 Instantaneous Electronic...
Mar 31, 2017 | Bosch Water Heaters
May 26, 2008 | Heating & Cooling
Nov 18, 2007 | Kenmore 46462 Front Load Washer
51 people viewed this question
