Question about Bosch HMT9626GB Microwave Oven
Bosch HMT9626GB / HMT9 / 0B 1000 Watts...
Door is jammed shut all owrking but cannot open the door!
  • Bosch Master
  • 9,098 Answers
What usually breaks is the door open lever.
On a counter top model, the outer cover will need to be removed to diagnose and repair this. On an over-the-range model, only the control panel needs to be removed.
Please unplug the oven first.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa.
Once it is apart, you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should open.
Posted on Sep 16, 2008
Door will not open 1999 model
The unit needs to be shut down by cutting power to the oven by either pulling the 110VAC plug from the receptacle or flipping the toggle on the house circuit breakers.
Dec 31, 2013 | Kenmore 63673 1000 Watts Convection /...
Primary interlock switch
My GE JVM1850 microwave turns on when you open the door and when the door is shut and you try to put in a time and hit start it blows the breaker
Jul 13, 2013 | GE JVM1850 1000 Watts Microwave Oven
Repair to microwave oven
The door interlock may be broken or may have gotten food jammed in it.
Sep 05, 2012 | GE JVM1850 1000 Watts Microwave Oven
Stops working after 20 seconds
The magnetron is over heating causing the thermal fuse to open to cut power, the only option is replace the part, but keep in mind it is the most expensive item to install.
May 07, 2012 | Bosch HMT9626GB Microwave Oven
I have a brand new Bosch microwave model HMV8051U It was installed for 1 day and the interior glass on the door shattered. What would cause this to happen?
It could be door alignment, damaged or chipped when installed, scratched and moisture got in the scratch and turned to steam under pressure or hit with something spinning around in the machine.
Almost anything.
Take it back and get it replaced.
Jan 03, 2011 | Bosch 800 HMB80 1000 Watts Microwave Oven
When i opened the microwave door the power went off. Main fuse seems to be ok
if you close the door, hit start, and it continues to work, then it's doing what it's supposed to do! safety feature!
if it 'pops' a breaker, then there may be a problem with the 'safety interlock' switch, which is engaged when you close the door! possibly cause an electrical "short' when you open it. then you need to get switch replaced!
contact a qualified repair person, or check if your warranty is still covered, and have retailer, or manufacturer rep. fix it! if it is a switch problem it may cost less to replace the microwave!! do the math!
good luck!
Oct 19, 2009 | Bosch HMT9626GB Microwave Oven
How to replace both door hooks on BOSCH MICROWAVE/GRILL
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Dec 23, 2008 | Bosch HMT9626GB Microwave Oven
Mircoave doesnt trun on
Check if you are getting power to the microwave by checking the plug, and the fuses in the plug.
Dec 17, 2007 | Bosch HMT9626GB Microwave Oven
Signs of burning on inside of plastic door surround .
replace plastic inner and check any rust is there, check inside body and compleat door.
Nov 12, 2007 | Bosch HMT9626GB Microwave Oven
Bosch HMT9626GB Microwave Oven Logo
222 people viewed this question
Top Bosch Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Bosch Microwave Oven Expert? Answer questions, earn points and help others
