Question about Epson LCD PROJECTOR, XGA, 3500 ANSI, 1024 x 768, 450:1 => Model POWERLITE 7850NL Monitor
Epson powerlite projector
When i start it up it makes a very loud noise for about 2 minutes. I cleaned all the filters. That didn't help
amanda.caudill@harrison.kyschools.us
5 Suggested Answers
  • 110 Answers
SOURCE: Epson PowerLite S1+
You have not set the port on the back of the projector settings.
Go into the projector menu and go into the IMAGE area. Somewhere in here you should be able to select computer.
Posted on Aug 22, 2008
zabolyx
  • 38 Answers
SOURCE: epson powerlite s4 projector is pink
I assume this is an LCD. I don't remember the s4 being a DLP projector.
This sounds like the LCD panel used for the red color has gone out. The image is made up of red, green and blue images layered upon the screen. If the red panel has gone out then there is nothing filtering out the red light in the image. This causes a nice red hue to the whole screen.
It could be a simple open and reconnect fix. I personally have never opened a projector, so I'm not going to walk you through it as I do not know how hard it would be to tinker with. It should eb a cheap fix for a true repair man though.
Posted on Apr 01, 2009
  • 103 Answers
SOURCE: Epson 83+ powerlite projector overheat
hi follow the link bellow the instructions are on page 83 \\files.support.epson.com/pdf/pl83pl/pl83plug.pdf
Posted on Jun 04, 2009
SOURCE: My Epson Powerlite 5350 has a ghost image. Any
I've got the same problem on two Epson EMP7300.
I believe (from reading about other projectors) that the ghost image can be adjusted with RS232 codes.
Does anyone know how to do this?
Posted on Feb 24, 2010
stecon3248
  • 57 Answers
SOURCE: Total factory reset Projector Epson Powerlite S5
This is an anti-theft device, you will need to contact Epson if you cannot recall your password.
Posted on Aug 15, 2010
Epson 7800P projector?
Please dont use cheap alternative Lamp Bulbs in Epson. There are issues where the cheap Bulbs draw more current and damaging the circuit board.
Apr 22, 2014 | Office Equipment & Supplies
Epson powerlite 200 overheating after 20 minutes of use then shuts off.
How's the filter, if it has one - cleaned out recently? Much dust in the airways? Tried setting it into "high altitude" (or simply "high fan speed") mode and seeing if that helps?
Jan 30, 2014 | Epson POWERLITE 74C Video Projector LCD,...
I changed the bulb on my epson powerlite 83+ and now there is a blurry spot in the middle of my screen. Is there anyway to fix this?
For anyone that may still stumble on this post, we have two of these and the blurry spot is most likely caused by the neutral density filter in front of the Green LCD element. We still haven't found a source for this part, but it seems to be caused when the bulb overheats and melts the plastic filter causing it to warp and wrinkle.
Jun 09, 2012 | Epson PowerLite® 83c LCD Projector
Epson PowerLite 410W projector (used for a smart board in a classroom) won't project anything or even turn on. Power button (maybe lamp indicator light? I don't really know anything about this...)...
It seems you assume that it is not an overheating problem.
The problem is, the bulb gets really, really hot when using the projector. It doesn't matter whether it has been there without any usage. As you switch it on, it will start to get hot.
But the lamp or other parts of the projector should not get too hot. To control the temperature, air is moved through the projector with the help of fans. Air enters through air filters and move through the projector absorbing heat from hot parts. This prevents these parts from getting overheated.
But what if air doesn't flow freely? Then the parts CAN get overheated.
First, switch on the projector and check whether you can hear the fans working.
Next, switch off the projector and remove power cable.
After about 30 minutes, remove the cover and check whether the air filters are blocked. If they are, clean them with a small brush.
This would probably solve your problem.
Sep 23, 2011 | Epson PowerLite 410W LCD Projector
One of our Epson PowerLite projectors was working
We found that the bulb was dim because it was about to burn out. The projector's filter han't been kept clean, causing it to run hot, which in turn shortened the bulb's life.
Dec 09, 2009 | Epson POWERLITE 400W Projector
How do I reset the lamp hours on an epson powerlite 7250 projector after replacing the bulb?
EPSON PowerLite 7250
Reset the lamp counter hours in 3 steps
1. Make sure, your projector is ON
2. Hold down the Help and Menu buttons for 5 seconds.
The "A.S." screen will appear.
3. Hold down the Tracking and Tracking - buttons for 5 seconds.
Dec 05, 2009 | Epson Office Equipment & Supplies
Epson PowerLite 83+ goes completely green or red
make sure the signal matches. you could reset the settings to factory default.
Nov 10, 2009 | Epson PowerLite® 83c LCD Projector
Jun 04, 2009 | Epson PowerLite® 83c LCD Projector
Projector Lamp is flashing Red
if you know how to open the unit, try fixing its ventilation. flashing bulb light sometimes mean an occurance of overheating. try to clean all the fans and the air vent.
Feb 21, 2009 | Epson (V13H010L34) Projector Lamp for...
52 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
