Question about Acer Computers & Internet
Acer aspire 5000 notebook keyboard froze - Acer Computers & Internet
    President:
  • 2,961 Answers
You may have a trojan, so run your anti spyware programme. or your keyboard driver is corrupt, see here for keyboard solution
Posted on Sep 15, 2008
Acer 5000 no keyboard and mouse uploading xp home
You might have a faulty keyboard or a key may be continuously pressed without you seeing it physically. When you get to that screen again, try running your hand across all the keys a few times and see what happens. If not, just go on ebay and find a cheap one and replace it.
Mar 03, 2014 | Acer Aspire 5000 Notebook
Tip
How To Replace Keyboard On Acer Aspire 5020 Series
We encourage you to use Tips and Tricks as a starting point for sharing your technical knowledge and know-how with other FixYa users.
on Mar 06, 2010 | Acer Aspire 5000 Notebook
HOW TO GET THE BACK OFF
Break it off..........
In order to take the Base Enclosure (Bottom Cover) off, you would have to break it off.
The Acer Aspire 5000 series of Notebook PC's, disassembles from the Top down. When you are done you are looking at an empty Base Enclosure,
http://www.ebay.com/itm/ACER-ASPIRE-3000-3004-ZL5-5000-LAPTOP-BOTTOM-CASE-COVER-LOWER-BASE-3AZL5BATN05-/181127078788
You have to;
Remove ALL power. Remove the AC adapter (Charger), and Battery.
Remove the Harddrive Compartment Cover, Harddrive, Memory Compartment Cover, Ram Memory, Wireless Module, Wireless Antenna wires out of laptop body, Optical Disk Drive, (DVD drive), Display Assembly, (LCD Module), Keyboard Cover, Keyboard, Palm Rest Cover, Motherboard, and so on..........
Then you have the Base Enclosure. (Bottom Cover)
WEAR an ESD wrist strap, and have it's alligator clip attached to a good ground source.
Acer Aspire 5000 series of Notebook PC > Service Manual (Free),
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-acer
Go to the paragraph that starts with Aspire 1200. (1200 in Blue)
Drop down to the 6th line (4920G), scroll across; and click on the blue -> 5000
For additional questions please post in a Comment.
Regards,
joecoolvette
May 02, 2013 | Acer Aspire 5000 Notebook
My mouse pad doesnt work and my login screen is froze
Hey,
This is a common fault in the acer aspire 5000 series.
Your keyboard and mouse are no longer functioning? Does usb keyboard work?
when you turn the computer on and it says on the corner of the screen to press f2 or this button to enter setup, are you able to enter setup?
If not, then you have a bigger problem on the laptop.
do you still have warranty on it?
Feb 22, 2009 | Acer Aspire 5500 5570-2609 Laptop
Keyboard going bad on myacer aspire 5000 . will cordless board work?? thanks!!
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Обычная таблица"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Yes it'll work. Try to clean up your keyboard by using pure alcohol. SHUT DOWN YOUR LAPTOP FIRST AND EXTRACT BATTЕRY
Sep 28, 2008 | Acer Aspire 3000 Notebook
Laptop froze
try to press the arrow up on your keyboard. if symptoms persist. try to pull out the battery. wait for 10 min. then refit the battery then power up.
Jun 29, 2008 | Acer Aspire 5315 Notebook
Frozen keyboard acer 5100
for aspire 3050, try to remove the battery, battery can cause many strange thing.
if you still got problem after removing battery, it's look like motherboard need repair.
Mar 02, 2008 | Acer Aspire 3000 Notebook
Acer Aspire 3004 keyboard and touchpad error
Just resolved same problem on Acer Aspire 5000 by removing the battery, then goto device manager and disable "Microsoft ACPI-Compliant Control Method Battery" you can then put your existing battery back into the latop with any problems with the keyboard and touchpad. Mad solution I know but it worked for me
Jan 22, 2008 | Acer Aspire 3000 Notebook
Computers & Internet Logo
96 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
