Question about Canon EOS Elan 7 35mm SLR Camera
Film indicator blinks, refuses to take picture
I took a picture, the film rewinded, as it should have. I reloaded the film, the automatic ISO registered, the film loaded, but the film indicator, simply flashed. I restarted the camera several times, unloaded the film, reloaded the same film and another roll with no success. The icon only blinks. I have also changed the batteries. Nothing registers on the LCD either, only the flashing film icon, even in Manual, unless there is NO film loaded.
    Top Expert:
  • Canon Master
  • 14,162 Answers
Posted on Jul 18, 2016
satscoop
  • 59 Answers
SOURCE: unloading my medium format camera
If i remember correctly there should be a button on the bottom of the camera opposite side of the film winder if you press that button it will release the tension on the film and allow you to reel the film back into the film canistor.BE CAREFUL when reeling it back in because you can reel the whole roll back into the film canistor, when you think your getting towards the end go SLOW you will feal the reel loosen up alot.that means that the film has let go of the other side STOP and you can open the case without exposong your film.GOOD LUCK if this helps rate me or leave some more info.Thanks.
Posted on Nov 18, 2007
  • 362 Answers
SOURCE: Nikon EM film winding lever is stuck. Can I repair this myself?
Bad news. I have an EM on the junk pile for a similar reason. In my case, the lever stuck and when I tried to advance the film, the plastic on the top of the camera body fractured and the whole mechanism separated. The current E-bay price on an EM body is under $30. Since the EM was made out of plastic, it is not repairable. If you have several lenses, it will be worth the low cost.
I have had Nikons of various models for over 50 years and in my opinion, until they fail such as your has, the EM is probably the most comfortable non-professional 35mm camera to hold and use that Nikon ever made.
Posted on Nov 22, 2008
  • 185 Answers
SOURCE: Loading/ Unloading the Film
anniehongx,
open the film door and charge the shutter. are the drive and take up sprockets turning? if they are then the film was not loaded properly. be sure to push enough film leader into the take up spool bars.
if the spools are not turning then a gear or spring ( advance lever return lock ) is broken.
there are no new parts for the ME Super however some camera repair shops have good used parts that can be used. get an estimate first.
Posted on Mar 02, 2009
pontelemon
  • 538 Answers
SOURCE: Auto rewind on my Minolta camera
Broken gears in Advance Assembly.
Needs service.
Posted on Apr 02, 2009
SOURCE: Powers on, wont load film, beeps constantly, Can't select a mode,
I had a similar problem today with my camera. I'm not an expert on Cannon cameras or any cameras for that matter, but this is what I did to fix the problem.
I removed the bottom cover(has 6 screws i believe) carefully sliding the cover up starting near the battery cover. Holding the camera still I checked what gears I could to make sure they were free, but one small gear that moves up and down was stuck. I applied a very small amount of force to the gear to free it, reattached the cover and all the screws, and BAM! I was back to taking pictures.
Hopes this helps.
p.s if you can't find one of the screws its under the battery cover flap :).
Posted on Jul 22, 2010
Film rewinds when loaded
Align film leader at mark, then close the camera back for prewind loading. Film rewinds as each shot is exposed. Built-in motor for automatic winding/rewinding. Film advance: Automatic. Single-frame and continuous (1 fps). Automatically rewinds film leader into cartridge when designated number of frames have been exposed (midroll rewind available).
sorce: http://www.canon.com/camera-museum/camera/film/data/1996-2000/1999_eos3000.html?p=2
Canon Camera Museum Camera Hall Film Cameras
good luck
Dec 20, 2014 | Canon EOS-AE-1 35mm SLR Camera
I have a 36 exposure film in the camera with 25 pictures taken and I want to remove the film without taking more photos. How do I rewind?
To rewind the film mid-roll, press the two film rewind buttons simultaneously for one second. The two buttons are marked with a red film symbol, and double as the Auto Exposure Bracketing button to the left of the viewfinder and the Aperture/Exposure Compensation button to the right of the control panel.
The film is completely rewound when a blinking "E" shows in the control panel.
Sep 08, 2010 | Nikon F65 35mm SLR Camera
The film has 36 exposures and indicator shows only 32 pics taken. Film is advanced and when I look into the view finder I have a blinking M and red circle on far right side. It will not let me take a...
You may be out of film. If you used too much leader to load the film, the counter would not know to keep up so you would be off a bit. On the rewind side, check to see if there is any slack in the film, If you can turn the rewind 2 or 3 turns then it is not loading error but mechanical problems.
Oct 19, 2009 | Canon EOS-AE-1 35mm SLR Camera
Camera took pictures to # 7, then the 7 just blinks off and on, then won't do anything else. I put in new batteries, thinking that might be problem. It isn't/ what to do????
Likely its the film tranport motor. If that goes out, the camera cannot advance film. Try rewinding film. I forget if the 7000 had 1 or 2 such motors. Could also be teeth broken/worn out on the gears, but sounds like a trip to the repair shop is in order. If it will not rewind, put the camera inside a zipped dark jacket. Fold the bottom of the jacket to block light. Put your arms in the sleeves and open the camera back. Pull out the film, rewind it into the can.
Oct 16, 2009 | Minolta Maxxum 7000 35mm SLR Camera
Need to take old film out of camera
Usually when the film is shot (you may get more frames than the indicated 24/36 or whatever on the film canister) it will automatically rewind. If not, there's a button in the bottom of the camera you have to press - or other switch-like thing with a symbol 'o__' for rewinding the film.
Beware not to open the back of the camera before you are surethe film is rewound.
Apr 09, 2009 | Photography
Wind film?
Behind the LCD screen on the back of the camera, is a a gray button marked "R", and a gray slide switch to the immediate left of that.
Press and hold the R button, while sliding the switch to the left, this can be easily done with one thumb. the display will blink 0 and the motor will stop when rewinding is complete.
-John
Feb 21, 2009 | Minolta Maxxum 7000 35mm SLR Camera
I have a canon rebel II camera and when i put my film in it rewinds it instead.
Sounds like it's stuck in rewind mode....remove the lens then turn the command dial to ISO then press both buttons on the top back simultaneously. This is a manual rewind to reset the counter. Now you should be able to reload film.
Jul 04, 2008 | Cameras
ERR sign keeps blinking in the lcd
First check the batteries. Are they fully charged? If you still have the same problem, try this:
Is the film (that which did not rewind fully) still in the camera? If so, open the film chamber door once in a dark room and close it again. Try to rewind the film again. This could possibly be the result of the film getting stuck somewhere, preventing the camera from rewinding it.
Mar 18, 2008 | Nikon F80 35mm SLR Camera
Rewinding nearly completed roll of film
You can do this by setting the command dial on the left side to the last position turning it clockwise. off,p,tv,av,m,a-dep,ISO, rewind. A second button must be pushed at the lower left rear of the display, the smaller button
Jan 11, 2008 | Canon EOS Rebel G-II 35mm SLR Camera
Canon EOS Elan 7 35mm SLR Camera Logo
121 people viewed this question
Top Canon Photography Experts
old marine
old marine
pontelemon
pontelemon
Are you a Canon Photography Expert? Answer questions, earn points and help others
