Part Number:
Aspire5535 Aspire 5535
Feature
Description
Part Number
Varies by specifications
Processor / Speed
AMD
Turion™ X2 Ultra dual-core mobile technology
ZM-80/ZM-82/ZM-84/ZM-86/ZM-88 (2 MB L2 cache, 2.10/2.20/2.30/2.40/2.50
GHz, DDR2 800 MHz, 35 W), supporting AMD HyperTransport™ 3.0 technology,
or
AMD Turion™ X2 dual-core mobile technology RM-70/RM-72/RM-74 (1
MB L2 cache, 2/2.10/2.20 GHz, DDR2 800 MHz, 35 W), supporting AMD
HyperTransport™ 3.0 technology, or
AMD Athlon™ X2 dual-core processor
QL-60/QL-62/QL-64 (1 MB L2 cache, 1.90/2/2.10 GHz, DDR2 667 MHz, 35 W),
supporting AMD HyperTransport™ 3.0 technology.
Core Logic Chipset
AMD M780G Chipset.
System Bus Speed
667 MHz.
RAM / Max RAM
Up to 2 GB of DDR2 667 MHz memory, upgradable to 4 GB using two soDIMM modules.
Video Subsystem
ATI
Radeon™ HD 3200 Graphics with up to 2048 MB of HyperMemory™ (256 MB of
dedicated system memory, up to 1792 MB of shared system memory),
supporting Unified Video Decoder (UVD), OpenEXR High Dynamic-Range (HDR)
technology, Shader Model 4.0, Microsoft® DirectX® 10.0.
LCD Properties
Display 15.6"
HD1366 x 768 pixel resolution, high-brightness (220-nit) Acer
CineCrystal™ TFT LCD, supporting simultaneous multi-window viewing via
Acer GridVista™ with 16:9 aspect ratio and 8 ms high-def response time.
Hard Disk Drive
120/160/250/320 GB or larger hard disk drive.
Optical Drive
8X DVD-Super Multi double-layer.
Battery, Primary
48.8 W 4400 mAh 6-cell Li-ion battery pack.
3.0-hour battery life.
2.5-hour rapid charge system-off.
3.5-hour charge-in-use.
Sound Subsystem
Two built-in Acer 3DSonic stereo speakers.
High-definition audio support.
MS-Sound compatible.
Built-in microphone.
PCCard Support
1 ExpressCard™/54 slot.
Pointing Device
Touchpad
Peripheral Subsystem
Integrated Acer Crystal Eye webcam.
5-in-1 card reader (SD™, MMC, MS, MS PRO, xD).
Three USB 2.0 ports.
External display (VGA) port.
Headphone/speaker/line-out jack.
Microphone-in jack.
Ethernet (RJ-45) port.
Modem (RJ-11) port.
(varies by model)
Modem
56K ITU V.92 PPT approved, Wake-on-Ring ready
Ethernet
Acer InviLink™ Nplify™ 802.11b/g/Draft-N Wi-Fi CERTIFIED® network connection, supporting Acer SignalUp™ wireless technology, or
Acer InviLink™ 802.11b/g Wi-Fi CERTIFIED® network connection, supporting Acer SignalUp™ wireless technology.
Bluetooth® 2.0+EDR (Enhanced Data Rate).
Gigabit Ethernet, Wake-on-LAN ready.
(varies by model)
Dimensions / Weight
15.1 x 9.9 x 0.6/1.5 inches.
5.94 lbs. with 6-cell battery pack.
AC Power
100-240V AC AutoSensing Adapt
Processor Type 754-pin (uPGA); 638-pin (uPGA)*
Support Processor
AMD Turion™ 64 X2 Dual Core
Processor,
AMD Turion™ 64 Processor
(25/35W series),
Mobile AMD
Sempron™ (25W series)
Those are the ones that your laptop supports
