Question about Navman GPS
I have not used my navman n401 for about a year i have charged it up and tryed to turn it on but it dosnt want to fire up ANY IDEARS
  • 3 Answers
Did you remember to move the tiny switch on the bottom from 0 to I ?
Posted on Sep 15, 2008
Saab 9-3 Petrol 2000 model wont start turns over but dosnt fire
immobilisor has come on from the sound of it caused by the flat battery ,dealer only iam afraid
Sep 13, 2012 | 2001 Saab 9-3
I purchased a Navman MY50T Christmas before last and do not use it on a regular basis. Yesterday when I went to use it after fully charging it, it ran out of battery power within 5 minutes and did so...
yes you need to replace the batt the reason for burn out so fast can be a number of things from moister getting into it during storage to simply bad line assembley
Jul 01, 2011 | Navman iCN 520 GPS Receiver
My navman won't charge or turn on, any ideas?
screen shows computer to navman all the time
Jul 25, 2010 | Navman F20 GPS Receiver
I have a Navman F15 that will not turn on. It is only a year old. It has not gotten wet and has not been dropped and is fully charged. Any idea what is going on?
i have the same problem.. i stopped using it for a while now it doesn't power up... when i charge it shows the lights on but if i unplug and turn on or reset no lights at all.
Jun 25, 2009 | Navman GPS
Bad starting
what do you mean "bad starting"
starter dosnt engage?(starter engauges but dosnt catch flexplate or flywheel, maybe dosnt engauge at all)
barely turns over? (like theres no battery causing hard crank)
you can test your battery by starting the car with the headlights on, if the headlights go dim the battery is bad. your battery could be out of date or the alternator could be bad and not charging the battery.
Nov 13, 2008 | Mazda RX-8 Cars & Trucks
Navman icn520
check the battery switch on the back. you will need a pen. Mine does the same thing. I believe this switch has to be set to ON for it to work. At least mine wont turn on unless the switch is turned on.
Apr 10, 2008 | Navman iCN 520 GPS Receiver
NAVMAN 570 PIN
maybe there is a flat or stuffed lithium battery or battery charging circuit in the pin 570.
fix:
leave unit to charge for 24 h
if the battery still dosnt charge because it is over discharged, then you may be able to push some charge in it after the battery is unplugged, after opening the case, and removing the circuit board
Jan 23, 2008 | Navman PiN 570 GPS Receiver
Can NavMan 520 charge via USB?
that is probably due to the battery being totaly dead,
try using a mobile phone charger (nokia),
usb is for data transfers.
Jan 04, 2008 | Navman iCN 520 GPS Receiver
Cant get the menu display on my pin 570
maybe there is no memory caused by a flat or stuffed lithium battery or battery charging circuit in the pin 570.
fix:
if the battery still dosnt charge because it is over discharged, then you may be able to push some charge in it after the battery is unplugged, after opening the case, and removing the circuit board.
Dec 03, 2007 | Navman PiN 570 GPS Receiver
GPS Logo
81 people viewed this question
Top Navman GPS Experts
Martin Murray
Are you a Navman GPS Expert? Answer questions, earn points and help others
